Question about Cameras
Have left manual for Vivitar 5105S at home and am in Australia - Help how can I delete images from the SD card ?
  • 78 Answers
Select "settings",browse to memory card,or stick icon,select it,then pick "format"and "ok".
this will erase the stick!!
also..
If you just want to delete chosen pikts,go to your "veiw-pikts"mode,while looking at the pikt or movie clip you want gone,one of your options (button,or touch-screen)will be to delete JUST that pikt!!
Posted on Dec 22, 2008
How to delete all pictures from vivitar 5150s
Page 34 of the user manual will show you how to delete the pictures. If you do not have the manual, send an email to LBrown18062@hotmail.com and I will send you the manual. Please put "vivitar vivicam 2050s" as the subject.
Apr 07, 2012 | Vivitar Vivicam 5105s Digital Camera
Need user manal for vivicam3340
The best would be to contact the manufacturer as free manual download is not available.
You can contact Vivitar through the following channels
* Email support@vivitar.com
* Phone US: 1-800-592-9541
UK: 0-800-917-4831
Australia: 1-800-006-614
Thanks
Proton
Mar 31, 2011 | Vivitar ViviCam 3340 1.3Mpx SD/MMC Card...
How do i delete all photos at once
In the playback menu select "Format" this will erase all images
Feb 28, 2011 | Vivitar ViviCam 8018 Digital Camera
I have a vivitar camera from a friend and she took her memory card out then i bought my own brand new memory card with nothing on it and new batteries too. then when i try and take a picture it says memory...
From the manual:
http://static.infoteldistributors.com/pdf/VC8025%20User%20Manual.pdf
Installing SD Memory Card
Your camera has a memory card slot that enables you to insert any "SD" compatible memory card up to 8BG. Adding a memory card will allow you to increase the capacity of your camera before you have to transfer photos and videos to your PC. Install the SD memory card as below:
  1. Locate the Memory Card slot within the battery compartment.
  2. Insert the Memory card into the slot in the correct direction. (see the sketch below)
7
  1. Push the card in until you feel it "click" into position. The top of the card should be flushed with the surface of the camera. An icon will appear on the LCD screen after you turn on your camera.
  2. Once the external memory card is inserted into the camera all the images taken with the camera will be stored on the card.
Note:
  1. Limited internal memory is provided for test images. The image will be deleted when camera power is turned off. Please download the images before power off .SD memory card is required for normal use.
  2. An external memory card is required for normal use. Your camera supports any compatible SD memory card (up to 8GB).
  3. If there is a photo in the internal memory when you insert the card into your camera, a "Copy to card" message will appear on the LCD with Yes or No options. On selecting 'Yes' the photo will now be copied to your card.
  4. Formatting will delete all data on the SD memory card including protected data.
8
  1. Don't remove the SD card during formatting as this may damage the card and render it unusable.
  2. When your card is full, download the media on the SD card to your PC and delete the photos and videos from it in order to continue using your
Dec 24, 2010 | Vivitar ViviCam 8025 Digital Camera
How to recover erased images from sd card
It is quite possible to recover the photos no matter deleted, formatted, lost or inaccessible from your sd card. All you need to do first is by trying SD card data recovery software tools.
Note: before those files are recovered, never should you attempt to save more data to the card. better stop using it for a moment. Regards.
Jun 18, 2010 | Vivitar DVR-550 DV Camcorder
How do i unlock an sd card to delete images used in a vivitar vivicam 5018 camera
SD cards have a slide switch along one edge. The position farthest from the contacts locks the card, protecting it from writes. The position nearest the contacts unlocks the card. If the switch is already in the proper position, slide it fully the other way and then back again.
Jun 06, 2010 | Vivitar ViviCam 5018 Digital Camera
How do I format an SD card for a Vivicam 3785?
You can format the SD card in your ViviCam 3785.
This utility formats the internal memory (or memory card) and erases all stored images and data. Make sure your SD card is in the unlocked position.
1. Press the button to turn on your ViviCam 3785.
2. Press the MODE button twice to enter Playback mode. Then press
the button to enter the Playback menu.
3. Select [Delete] by using the up/down arrow buttons, and press the OK button.
4. Select [Format ] by using the up/down arrow buttons, and press the OK button.
5. If you want to format your SD memory card or the internal memory choose
[OK] by pressing up/down arrow buttons, then press the OK button to confirm.
 To cancel the action, select [Cancel] instead.
 [No Image] pops up after the SD memory card or internal memory
has been formatted.
If you need a manual for your camera you can download a free PDF at
http://www.retrevo.com/support/Vivitar-3785-Digital-Cameras-manual/id/200ag818/t/2/
Please rate this solution. Thanks.
Jan 15, 2010 | Vivitar ViviCam 3785 Digital Camera
Vivicam 5105s Software CD
You don't need any Vivitar software.
The best way to download pictures from your camera to your computer involves removing the memory card from the camera and plugging it into a card reader (either built-in to the computer or connected via USB or FireWire). This is likely to be faster than connecting the camera to the computer, and won't run down your camera's batteries.
Once the card is plugged in, it will appear to your computer as a removable drive. You can use the operating system's drag&drop facility to copy pictures from the card to the computer's hard drive, the same way you copy any other files. Or you can use any photo cataloging program, such as Picasa.
Oct 30, 2008 | Vivitar Vivicam 5105s Digital Camera
AC Adapter
Where can I get a replacement charger for my Vivitar Vivicam 5105s digital camera.
Dec 31, 2007 | Vivitar Vivicam 5105s Digital Camera
Cameras Logo
Top Cameras Experts
Damen Wong
Damen Wong
Marvin
Marvin
Are you a Camera Expert? Answer questions, earn points and help others
