Question about Light Outboard Motor Boat Bass Fishing Saltwater Base
Hi,I have a evinrude 90hp 1998 motor and only recently had it serviced( 6 mnths ago).Its been going great guns ,starts easily but this morning it all turned to custard.The usual startup was fine and nothing seemed amiss until after about a mile out the engine cut out and we were unable to get it started from that point.We checked the gas lines and that seemed okay, pumped the gas until the bulge got hard and tried starting again.The motor would not ignite and it seemed like the bulge in the gas line had lost its hardness/compression??.Is this a possible major problem or can i do some trouble shooting things first off.Id appreciate any advice thankyou wally
  • ltbonrye Apr 05, 2009
    i had the same problem with my 90 ....check the in line fuse goinjg to the coil
  • Lakebolfing May 04, 2009
    I HAVE A 1988 EVINRUDE 40HP. NEW FUEL PUMP, HAD THE CARBS CLEANED, NEW PLUGS, HOWEVER WHEN I MOVE THE IDLE ARM UP, THE MOTOR REVES UP AND BACK DOWN AND KEEPS DOING THE SAME THING.?? IN THE WATER I NEED TO KEEP CHOKING..
    Brigadier General:
  • 6,966 Answers
Hi and welcome to FixYa,
Offhand your description "engine cut out" could only indicate two possibilities:
  • no fuel;
  • no spark.
Since you further described that the "bulge in the gas line had l...", then it can be assumed that there is fuel and it is getting to the motor. Assuming that this is the case, fuel present and reaching the engine, that would leave us with the spark.
A way of verifying spark presence in the plug(s) would be to remove one of the plugs, connect back the sparkplug wire and let it lay on any metal part of the engine, switch on and start. There should be a noticeable spark jumping on the electrode of the plug. If none, then the problem is narrowed down to the ignition system which could include the ignition coil, ignition module and the trigger pulse coil. Of the 3, most likelihood to be faulty would be the ignition module. Still, the coil could be tested with a continuity/VOM tester, same with the pulser. In some instances, it could just be the wire connected to the engine ON/OFF.
If there is spark, then we go back to fuel; is it reaching the combustion chamber at the right time and air/fuel mix.
Good luck and Thank you for using FixYa. Happy Holidays.
Posted on Dec 22, 2008
1998 evinrude 90hp no spark
The PDF i've posted is from CDI electronics. Search your engine type and follow the procedures.
I hope you'll get out and fix the problem.
Aug 01, 2017 | Boating
What is the idle timing for 1993 90hp evinrude
90 hp 1993 evinrude idle speed - MarineEngine
www.marineengine.com > ... > Johnson Evinrude Outboard Archive
Aug 3, 2008 - 2 posts - ‎2 authors
"How many rpm should the engine idle at,and where and how do you adjust it Thanks" 50 hp evinrude no idle and no top speed need assistance ...
Jul 6, 2013
1993 50 HP 2 cyl Evinrude stalls, runs at idle when ...
May 7, 2012
adjust carburators and idle speed 1993 48hp
Jul 29, 2010
90 hp stalls when going in gear
May 21, 2010
More results from www.marineengine.com
1993 Johnson 90-HP Runs Only At Idle Speed On Spring Start-Up
Johnson 1993 115 xflow Link and Sync - YouTube? 4:55https://www.youtube.com/watch?v=ReeuaVh8uZQNov 25, 2012 - Uploaded by Brian O'DellJohnson 1993 115 xflow Link and Sync. Brian O' ... Also if you can give me some details on how you got the ...DOWNLOAD Evinrude 90HP (90 HP) Repair Manual
Dec 14, 2015 | Boating
Doesn't seem to use oil? Oil reservoir never seems to go down?
The fuel to oil ratio should be 50:1, which means for every 50 gallons of fuel you use, you should use 1 gallon of oil.
You should see some smoke haze at starting and during running.
Having run an Evinrude that had had the auto pump disconnected in favour of pre-mixing fuel, I would take the boat to a marine engineer to check the pump and delivery. You know it is pretty disastrous when all the oil is burned out.
Sep 10, 2015 | Evinrude / Johnson 135-150-175-200 HP...
Evinrude 1998 power trim doesn't go down when on plane?
take it back to dealer that installed .
Jul 01, 2014 | Boating
Evinrude 15HP Outboard - Vent Holes
have a problem , check impeller pump
Sep 07, 2017 | Boating
Have 90 hp evinrude 1982 What rpms should it be running on idle?
You can get rpm data by searching your browser using "90hp Evinrude Specs" or "1982 90hp Evinrude idle specs". Changing the jets usually costs you performance on one end or the other. If you have needle rods, a narrower one will have the same effect as a bigger opening in a jet. But you have rpm limits that you should not exceed. Changing the prop can give you more power over the sacrifice of top end speed.
Jun 13, 2009 | Boating
Light Outboard Motor Boat Bass Fishing Saltwater  Base Logo
294 people viewed this question
Top Light Boating Experts
ray gallant
fordexpert
Ian Summerfield
Ian Summerfield
Are you a Light Boating Expert? Answer questions, earn points and help others
