Question about Compaq Presario Notebook
Pen drive not detected
My compaq CQ60-104 dual core lapy not detected pen drive .
when insert the pen drive in the USB port then lapy get hang , even remove the pen drive still it is hang.
So i kindly request to you plz suggest me some solution ,so that my lapy detect the pen drive and working properly.
  • Joseph Green
    Joseph Green May 11, 2010
    What Windows are you using? Windows XP? If so try updating to SP2, AKA "Service Pack 2" for thumb drives....
My both usb ports r not wrking n hangs when eithr card reader or pen drive is inserted bt works well when tata photon usb port or mouse port or key board port is inserted ?model- EMACHINES E275
Sounds like your laptop's USB ports are not capable of providing enough power to operate your card reader or pen drive. I suggest you buy an active USB hub (one with external power source, rather than the one which draws power from the laptop's USB port), & attach your card reader and/or pen drive to that USB hub.
Nov 28, 2010 | Acer Computers & Internet
System hangs by inserting pen drive
does other usb devices work fine on the same system please check if your pen drive is working fine on some other pc/laptop if it is working fine then you have to check with your usb ports.
Jun 09, 2009 | IBM ThinkCentre S50 8183 - P4 3 GHz...
Transcend 4gb pendrive gets detected bt says inserd disk
my pen drive Please insert a disk into drive problem
Jun 08, 2009 | Transcend (589307) Media
System hang when i insert pen drive
solution..
1) Check The USB Port for Damaged, Bend Or Broken Pins.
2) Check The Pen Drive For Physical Damage.
3) Try The Pen Drive In another USB Port. (i.e. if u r using the pen drive in the FRONT PANEL USB PORT than try it in BACK PANEL USB PORT)
4) Try The Pen Drive In Another System.
5) Tye Another Pen Drive.
6) If All Above Is Fine Then Format The PEN DRIVE.
7) Try The PEN DRIVE now.
8) Is Issue Still Persists Then..
9) Uninstall the CHIPSET/MOTHERBOARD DRIVER COMPLETELY and then clear %temp% & prefetch files and Restart Your System.
10) Install The Latest CHIPSET/MOTHERBOARD DRIVER and ANY AVAILABLE FIRMWARE for the motherboard..
May 22, 2009 | IBM ThinkCentre S50 8183 - P4 3 GHz...
Pendrive detected but stil cant open
Try to insert it in every usb on your pc maybe its your usb port the problem!
Mar 22, 2009 | Computers & Internet
Pendrive is detecting but not showing in my computer
when i plug my pen drive into usb port then usb mass storage show my pen drive without any drive letter like (F:). please help to save my pen drive
i am very thankful to all you
Feb 23, 2009 | Pen Drive IVO MP3 Player
Usb port
ive got a flash drive that does the same thing ,,one day it does ,one day it dont,, do you have vista or xp ,,because i think its got somethin to do with vista ,,and some of them flash drives,, goodluck
Aug 25, 2008 | Compaq Presario Notebook
My pen drive get detected and when click to open it shows the message: " PLEASE INSERT THE DISK INTO DRIVE I"
my pen drive get detected but i am not able to format and copy things to my pen drive
Mar 26, 2008 | Pen Drive IVO MP3 Player
Compaq Presario Notebook Logo
211 people viewed this question
Top Compaq Computers & Internet Experts
pankaj rautela
pankaj rautela
Alun Cox
Are you a Compaq Computer and Internet Expert? Answer questions, earn points and help others
