How to replace bearing in lg washer wm0532hw
Need to replace bearing in my washer LG wm0532hw.
stradeteox
  • 88 Answers
SOURCE: replace bearing
You can try a puller but typically it is recommended to replace the entire rear outer tub half (which comes with the bearings already pressed into it). You will also need the tub seal that goes between the front and rear tub halves. Hope this helps.
Posted on Jan 08, 2009
  • 279 Answers
SOURCE: LG WM0532HW
I found a part number for a switch: http://www.partstore.com/Part/LG+Electronics+Incorporated/LG+Electronics%2fZenith/WM0532HW/LG+Electronics+Incorporated/LG+Electronics%2fZenith/6600FA1704X/New.aspx To see the full list of parts for this model: http://www.partstore.com/Model/LG+Electronics+Incorporated/LG+Electronics%2fZenith/WM0532HW.aspx
Posted on Sep 03, 2007
SOURCE: lg bearing problem
Good instructions from SteveSays. Used his instructions and service diagrams from:
LG CS Academy - Just select washer model for respective service manual (mine WM2032) http://136.166.4.200/contents/Laundry/WM2032.htm
Once disassembled, I found main problem was shaft on spider assembly had corroded and was now rotating freely.  So I ordered spidershaft assembly.  While I had machine apart, I also ordered and replaced both rear bearings and seal.  Parts can be ordered from:
LG Service Website for LG Parts Distributors http://us.lgservice.com/index_b2c.jsp
I ordered all parts from Andrews Electronics due to parts being in stock there.  Good service and quick delivery.
Rear bearings can be pushed out using hammer and long punch.  You must be careful not to damage bearing insert that bearings fit into.  New bearings were driven back in using large socket to only push on outer race of new bearings.  Care must be given not to damage.  Best practice is to put new bearings in freezer for an hour or so prior to installation.
Posted on Mar 18, 2009
SOURCE: "le" on the LG WM0532hw front load washer errror
try unpluging for 45 seconds than hold in the selector knob for 10 sec. & plug back in
Posted on May 18, 2009
  • 108 Answers
SOURCE: Lg WM0532HW washing machine control panel say OE
"OE" means that your drain pump is blocked, or possibly broken, and that water isn't emptying so that the machine can spin. (I think Outlet Error is what it stands for). If you have a wet dry vac, you can use it to vacuum out the water from the drain hose behind the small door on the lower left side of the machine. If not, you can try using a large pan to catch the water, but to be honest, it will take forever and won't really get all the water out. Try to borrow a wet vac if you don't have one.
Next you will have to open the pump trap (the cap thing next to the small drain hose). With the wet vac on and in position, loosen the trap and pull it out slowly (there will still probably be a bit of water in there). Hopefully you will find a bunch of junk in the trap like lint, coins, a sock, whatever... however you may find there isn't anything in the trap. which means we have to go in deeper.
You may just want to get a pro in to do this, but it isn't really all that difficult for the adventurous type. You have to remove the top of the machine (three screws at the back release it so that the top panel can slide back a couple inches and lift off,) pull out the dispenser drawer completely, the control panel (you don't have to disconnect the wires, just pull it away from the frame of the machine so that it reveals the screws that hold on the front panel) Then you have to remove the front panel, which includes pulling off the spring clamp that holds the gasket to the front panel, and the wire which activates the door lock. There is also a screw behind the plastic piece where the drain hose is.
Once you can get to the pump, unscrew the motor on the left side of the pump and remove whatever is blocking the pump impeller from turning... even a tiny nail can do it.
Posted on Jul 19, 2009
LG wm0532hw starts it's wash cycle then stops with the code LE flashing. Tried to reset the washer already and it did it again after reset. Tried no laundry in the cycle to see if it was to heavy and same...
check out youtube.com, repairclinic.com or appliancepartspros.com search for motor sensor replacement or hall sensor replacement. easy repair. $20 part. 30 minutes time. a know issue on earlier lg washers. lg has enhanced the part to make it more durable. make sure you get an lg part, not an oem equivalent part. part no. 6501KW2002A
Mar 18, 2015 | LG Washing Machines
Hi, we have a lg wm0532hw tromm front loader washer, the latch on the door seems to be broken, it slides all the way back into the door frame and washer will not lock. Can this be fixed? thank...
I'm sure it can but you will need to call a local service engineer to do it. Sorry we cannot call one for you.
John C
Mar 10, 2011 | LG WM-0532HW Front Load Washer
How can I make the water drain from my LG WM0532HW washer with an LE code. BTW- it's had the hall sensor and the main board replaced already.
You can turn the power on, and hit the spin speed button, and then start it. It should drain out.
If your still getting an LE error, and already have replaced the Hall sensor, it's most likely the Stator. If you know your date of purchase, this is most likely still under the 7 or 10 year warranty. Meaning LG pays for the part (over $100.00+),
Mar 07, 2011 | LG WM-0532HW Front Load Washer
Lg tromm front loader washer wm0532hw shows oe error
that's draining error. check the filter cleanout behind lower left panel on front of machine; of course drain 1st via small drain hose. if thats o.k the drain pump itself may be jammed with debris or the drain hose could be clogged.
Jun 24, 2010 | LG WM-2277HW Front Load Washer
Drum on LG front load washer does not turn.
something is caught in between the two tubs.and that is no fun! call the tech.ps there is no belt on most lgs.
Aug 07, 2009 | LG Washing Machines
Lg wm0532hw leaks from bottom
You either have a loose hose on the drain pump , the main tub is leaking at the joint or the bearing on the main shaft is starting to go out.
Feb 11, 2009 | LG Washing Machines
Feb 02, 2009 | LG WM-0532HW Front Load Washer
Removing drum bearing on a LG wm0532hw???
Remove motor stator and push in the drum shaft as far as you can. Try to put a hook in between the shaft and the bearing and pull rotating in every direction and keep pulling outward.
Good luck
Jun 04, 2008 | LG Washing Machines
Lg wm0532hw front load washer
LG wm0532hw, can not turn on washer, it's not the plug, i try to reset it by unplug for 2min then plug it back. help
Dec 12, 2007 | LG WM-1832C Front Load Washer
LG WM0532HW
Sep 02, 2007 | Washing Machines
Washing Machines Logo
549 people viewed this question
Top Washing Machines Experts
Marvin
Marvin
paul
paul
