Question about Sub-Zero 650 / O Bottom Freezer Refrigerator
Compressor very hot + water leaking
I have just bought a second hand maytag side by side fridge. Model number GC2225GEKB. It keeps cold in both fridge and freezer but when l change the temperature settings, water leaks from back left hand side. l have taken the back off and noticed the copper pipe going from compressor to freezer is iced up and the compressor is really hot to touch. Is this normal? l have a 28 day warranty with it so l want to make sure its working properly or should l return? Any advice would be greatly appreciated. Thanks
    Novelist:
  • 161 Answers
This is not normal. The coolant charge is low which means it leaked out some where. Return it.
Posted on Dec 22, 2008
Maytag side by side door slamming shut
what's the model number and what's happening with it,do you mean the fridge is on top and freezer on bottom?open the fridge door,look up on right hand side up near ceiling and send the model number and the first two numbers of the serial number
Jun 18, 2012 | Maytag Refrigerators
I have a model MTB1956GE Maytag Fridge, Frezzer
Can you feel air moving or hear the fan running in the freezer section? You said the freezer section is freezing well, but is it freezing really hard?
Regards,Richard
Dec 12, 2011 | Maytag MTB2156GES Top Freezer Refrigerator
My kenmore side-by-side refrigerator is less than 4-years old. freezer works but refrigerator stde does not get cold. ice accumulates on lower vent in refrigerator.
all it does is the evap fan blows cold air from the freezer into the fridge section and returns through the bottom air vent,so if there's ice there most likely one of the doors was left open,check the freezer for frozen water droplets on packages or on the walls and shelves of the machine,if you don't see that open the freezer door,if you don't hear the fan blowing you could have a bad evap fan motor.if the fan is blowing in the freezer from the bottom remove the second draw or bin and put your hand on the back inside wall of the freezer,if there's frost or like snow on the back wall you have a defrost problem,bad defrost thermostat,defrost heater,timer or board depending on what model you have,if the fan is blowing and you don't see any problems that i talked about you could have a bad damper,on some machines there's a damper door that opens and closes to let cold air into the fridge section,if it's bad it won't open and no cold air can blow in from the freezer,if you think the door was left open,remove anything that's in the way,in the freezer side and the fridge side,shut the machine down or unplug it and with a hair dryer melt out the ice,don't keep the heat in one place for to long,you can melt the vent if it's plastic or styrofoam,after you think it's melted out start the machine and put your hand up in the left hand corner in the fridge section and see if you can feel any cold air blowing in,there could be ice up there too,next time send the model number so i can look up your model,on a side by side you'll find the tag on the right hand side wall in the fridge up near the ceiling or on the ceiling near the light.hope this helps,if you have another fridge you could move the food and just shut the fridge down with the doors open and let it melt out on it's own overnight.good luck
Sep 05, 2011 | Kenmore Side by Side Refrigerator
My Maytag Plus side-by-side refrigerator model # MZD2766GES is not keeping anything cold. The freezer side seems to be working just fine.
Check out these tips...they can help you figure out what is going wrong withyour refrigerator and why it is not cooling
Refrigeratornot Cooling or Fridge not Cooling
How to Defrost Refrigerator DefrostTimer Problem
WaterRunning in refrigerator from Freezer
Refrigeratoror Freezer not Cooling or Getting Cold
heatman101
May 15, 2011 | Maytag MSD2756G Side by Side Refrigerator
I have a Maytag refrigerator similar to the current model (GS2625GEKS), I purchased mine in 2003. Serial number unknown. All of a sudden my freezer is way too cold and my refrigerator is not cold enough....
If the number is similar we will have to go with possibilities. Sound like the auto damper has frozen itself shut between the fresh food and freezer compartments. Some are controlled electrically some manually and others are controlled with a thermostat probe. Your thermostat for one side could be defective and not allowing the damper to open. Your refrigerator must have the correct model number to proceed. What I need you to do is look for the vent through the rear of the refrigerator compartment and sometimes leads directly from the same wall as freezer. Many Maytag brands fall under same series and model similarities. The serial number is not as important to the service Tech as the model number. Look around the door frame near floor and kick plate.I can help but I will need the correct model number, Thanks, Sea Breeze
Feb 13, 2010 | Refrigerators
Freezer is very cold, refrigerator not cooling on Maytag side-by-
Check out these tips...they can help you figure out whats going wrong with yourrefrigerator and why it is not cooling
Refrigerator not Cooling or Fridge not Cooling
How to Defrost Refrigerator Defrost Timer Problem
Water Running in refrigerator from Freezer
Refrigerator or Freezer not Cooling or Getting Cold
heatman101
s
Nov 25, 2009 | Maytag MZD2766GES Side by Side...
Maytag fridge
Without knowing the type of fridge(side by side, freezer on top etc.) all I can offer is this: Somewhere between the freezer and the fridge there's an opening thermostatically controlled to transfer cold air from freezer to the fridge. Most have a fan to move the air. So either the fan (if so equipped) stopped, and need to replace, or opening is stuck closed, or plugged.
If freezer is working fine, this is the only problem I can think of.
Hope this helps
Dec 15, 2007 | Maytag MTB1504A Top Freezer Refrigerator
Maytag model RTC17A
how is freeezer side doing? Do u have any frost build up in freezer back wall and is you fan in freezer blowing?
Aug 31, 2007 | Maytag MSD2756GES Side by Side...
Sub-Zero 650 / O Bottom Freezer Refrigerator Logo
188 people viewed this question
Top Sub-Zero Refrigerators Experts
Charles T Nevin
Charles T Nevin
Sal De
John Tripp
John Tripp
Are you a Sub-Zero Refrigerator Expert? Answer questions, earn points and help others
