Question about HP PSC 500 All-In-One Printer
Printing from black cartridge is illegible. Color cartridge OK
The message on the printer said: "verify cartridge 15 (06615A). The printer would not work. I replaced the cartridge with a new one (hp15 (06615DN), the same number as the cartridge I had been using, and the printer worked, but the print was illegible. This is true when printing from the printer, and from my computer.
This is a new problem that I have not experienced before
  • 2 more comments
  • janelle987 Dec 22, 2008
    How do I access the utility page in the HP print driver to flush it out? (This was Bubbabear64's solution to my problem.)
    I have tried Jithin4043's suggestion to try and reposition the cartridge. It did not help.
    I have performed a restart and partial restart procedure on my printer. The print, when printing from the printer, is a little clearer, but still not good. One line is missing the bottom half of the print, and 50% of the lines are faint, but legible.
  • janelle987 Dec 24, 2008
    I have changed my black cartridge (two times), and finally have good print, but a couple of lines still show only the top part of the print. Any suggestions on this one?
    Scholar:
  • 61 Answers
You are experiencing what we call a clogged print head.
The simple solution is to use the HP utility program. If you are on a mac hit the Apple and the F key to do a find for HP, if on a Windows or Vista machine go to the search area on the bottom right and look for HP or go to programs and look under Hewllet packard and you should see the program.
Run the program. Inside you will find an area where it says to clean your print head. Put in some scrap or fresh paper. Run the flush or clean print heads part, then check your print. If it still has faint lines, run it again and repeat until the print looks good.
Posted on Dec 24, 2008
    Guru:
  • 449 Answers
In order to allow you to do this, go to the "start" menu on your computer. Then click on "settings" or "control panel." Navigate your way to your "devices" and then "printers." Right click on the printer icon for your printer and click on "properties." Then click on the "color" tab. Check the box that says "grayscale" and check the box that says "black cartridge only." This will allow you to print using only the black print cartridge in your printer without a color cartridge. At least this works for my printer. The process should be the same for yours, or something similar. do this with the old color cartridge still install. happy holiday
Posted on Dec 22, 2008
    Genius:
  • 1,199 Answers
This sounds like a bad ink cartridge replace and try again!
    Brigadier General:
  • 6,966 Answers
Hi and welcome to FixYa,
With the indulgence of the others....
Often, symptoms as you described would indicate a corrupt printer driver. If the printer is printing but the printout is unrecognizable and not a true reflection of the Print Preview, then somewhere, the print data is not interpreted correctly. This could be at your computer side or the printer's side.
Initial course of action would require that the old drivers be un-installed and an updated version suitable for your Operating System be installed. Should this not address your concern adequately, then it could be assumed that the printer is at fault.
Should the printer be deemed at fault, pls try to do a reset by unplugging the AC mains connection and the connection to the computer. After an extended period of time, plug in the printer and try a self-test or print a test page on the printer alone. At this point it must not yet be connected to the computer. If the printer does not have a self test/print or fails, then connect to the computer. Perform partial reset as detailed here.
Good luck and Thank you for using FixYa. Happy Holidays.
  • Louie  Role
    Louie Role Dec 23, 2008
    Hi again and appreciate your postback.
    "50% of the lines are faint, but legible" is 50% towards the solution. Now that the partial reset has been performed, cleaning then has to be accomplished. Pls try:
    • if you are using Windows XP, goto Start, Printers & Faxes;
    • if you are using Windows Vista goto Start (orb), Control Panel, Printers;
    • right click on the HP PSC 500 icon;
    • click on Properties;
    • on the pop-up HP PSC 500 Properties window, pls look for any tab that refers to Utility or Maintenance or click on the Printing Preferences button;
    • click on the Features tab;
    • look for any button/selection that refers to Utility or Maintenance or click on the Printing Services button;
    • look for and perform any cleaning function as shown.
    Cheers.
  • Louie  Role
    Louie Role Dec 25, 2008
    Your recent post describing "a couple of lines still show only the top part of the print" indicates a big improvement on the initial problem "print was illegible" and the previous "50% of the lines are faint, but legible".
    Your recent description would still be a partial print head blockage/clogged. And again could be resolved by cleaning. Other than performing the same cleaning routine, an alternate is to see if there are cleaning solutions available. These cleaning solutions are contained in ink cartridges similar to the regular ink cartridges. However, their purpose is for cleaning and diluting, softening hardened clogged, dried up ink deposits in the print head.
    It would seem that this is your last but best option to fully clean a stubborn print head.
    Pls see if you can acquire this cleaning solution.
    Merry Christmas.
  • 365 Answers
It can be also due to the improper fixing of the cartridge on the case.try to connect it properly. thank you
  • HP Master
  • 2,794 Answers
You can run the utlity program in the HP print drivers to flush it out. Sometimes if the cartridge is refillable, this result can happen.
  • Tim Babcock
    Tim Babcock Dec 23, 2008
    I don't know what operating system you are running. Go to printers and faxes. Move the mouse to the printer. Press the right mouse button and select properties.
    Press the printing preferences button. Press the services tab. Press the service this device button. Select clean the print cartridge button.
    Make sure that your HP Software updater is on as well to check for updates to the drivers as well. If it's on it should update them automatically.
Color printing
You risk you ruined the cartridge with alcool.
Jul 19, 2008 | Lexmark X5150 All-In-One InkJet Printer
Black stopped printing out. Dell 922 all-in-one ink jet.
Did you already run the head cleaning cycle from the utility?
Apr 23, 2008 | Dell 922 All-In-One InkJet Printer
Factory reset
This type of problem is typically caused by one of the ink cartridges which is suffering from marginal electrical performance - either the HP92 (black) or HP93 (color) ink cartridge.
Can you perform the 'Self Test Page' test (see below). If this test is successful then this demonstrates the printer is 'generally operational', but if normal printing is still not permitted then either the HP92 (black) or HP93 (color) ink cartridge is likely electrically damaged and may need to be replaced*.
Perform Self Test Page:
1. Press and hold the CANCEL button.
2. Press the COLOR COPY button. Release both buttons.
3. The self test prints. The printed pattern will verify printer is generally functional. Inspect color bars to verify proper nozzle/jetting health.
-- Inspect printed nozzle stair step patterns - verify all ink nozzles are properly firing. Generally, if the Self Test Page prints ok then the printer is functioning correctly and the problem is with the ink cartridges - replace the suspect ink cartridge and retest. Refer to 2nd video procedure at the following link on how to read the Self Test page test (NOTE: HP74/75 cartridges are electrically identical to the HP92 thru 98 cartridges).
http://inkjet411.com/?page_id=579
*Many cartridges eventually do encounter problems or failures. Severe cartridge errors are primarily caused by an electrical breakdown at the cartridge's nozzle plate. Ink *********** or corrosion into the nozzle plate will cause a failure of the tiny micro-electronics resulting in a variety of different error messages being displayed - see picture at bottom of this page: http://inkjet411.com/?page_id=1216
It is suggested to install a new HP92 and/or HP93 ink cartridge in it to resolve the current issue.
May 02, 2013 | HP PhotoSmart C4180 All-in-One Color...
I have an HP color printer. When printing the black does not print well even though it shows that the black print cartridge has plenty of ink in it. Is there a way of: 1. Diagnosing if it is the print...
Black printer ink in HP Printer may fail to be recognized by the printer. Most times an error message will be sent indicating that something is wrong with the black print cartridge. Sometimes the printer may accept to print with the black ink, but the printouts may have horizontal lines and very illegible letters. In such a case a manual cleaning of the print head should be carried out. In doing the manual cleaning, one should spray Windex heavily on paper towel and wipe off the surface of the print head.
http://en.kioskea.net/forum/affich-40171-printer-not-printing-black
Nov 11, 2010 | HP Deskjet F340 All-In-One Printer
Black cartridge is not working and blinking
Oct 27, 2010 | HP Deskjet D2660 All-In-One InkJet Color...
1. Replaced Color and Black ink cartidges on my HP D5160: Color cartridge - NEW Black cartridge - REFILL SYMPTOMS> Red flashing exclaimation LED, black ink cartridge appears empty (0 dots in the...
Oct 26, 2010 | HP Photosmart D5160 InkJet Printer
Not printing black
Black printer ink in Printer may fail to be recognized by the printer. Most times an error message will be sent indicating that something is wrong with the black print cartridge. Sometimes the printer may accept to print with the black ink, but the printouts may have horizontal lines and very illegible letters. In such a case a manual cleaning of the print head should be carried out. In doing the manual cleaning, one should spray Windex heavily on paper towel and wipe off the surface of the print head.
Jun 22, 2010 | Brother MFC 490cw Color Inkjet...
Printer not printing photos with all colors
  1. Lift the printer access door, then remove the ink cartridges from the printhead.
  2. Verify that the label on the ink cartridges is intact, and that the cartridges are not damaged.
  3. Verify that the KODAK Ink Cartridges have not been refilled.
  4. Insert the ink cartridges into the printhead, then press down firmly until you hear them click into position.
  5. Close the printer access door.
  6. Check the printer status monitor on your computer (or the LCD screen on the printer) to determine if there is sufficient ink available for your print job.
  7. NOTE: Once the "Black ink cartridge is low" or "Color ink cartridge is low" message is displayed, print quality can be affected.
  8. Reprint the picture or document that had the quality problem
If still same quality then...
  1. Load inkjet paper into the paper tray.
  2. On the control panel, press Menu.
  3. Select Calibrate Printer.
  4. Select Print Calibration Page
  5. Press Start.
  6. When the print is complete, press Cancel to end the calibration process.
  7. Check the six color bars on the printed calibration sheet.
Are the color bars completely filled with solid color?
If no then:
  1. Press Menu.
  2. Select Clean Printhead, then press OK.
  3. Select Deep Clean, then press OK. The On/Off light flashes green during the cleaning procedure.
  4. When the On/Off light glows steady, press OK.
  5. Select Calibrate Printer.
  6. Select Print Calibration Page
  7. Press Start.
  8. When the print is complete, press Cancel to end the calibration process.
  9. When the print is complete, press Cancel to end the calibration process.
  10. Check the six color bars on the printed calibration sheet.
If again No...
then printhead needs replacement... call Technical Support to get it replaced
May 25, 2010 | Kodak EASYSHARE 5300 All-In-One InkJet...
"Expired color cartridge" message blocks black printing - nothing works
Hello merelU. I'm afraid you may have to replace the empty color cartridge as there may be problems with the printer while an expired cartridge is installed on the printer (even though some of the cartridges are still under warranty) and also, HP cannot guarantee the quality or reliability of expired ink cartridges.
all the best.
thx
Oct 07, 2008 | HP Photosmart 3310 Printer
18 people viewed this question
Ben Johnson
