Question about Princeton Digital VL1812 18.1" Flat Panel LCD Monitor
Princeton VL1715-1 no display
LIght stays green when power button is pushed but there is no display on the screen even when I shine a flash light on it.
    Problem Solver:
  • 9 Answers
From what you say there is probably not much you can do with it, the parts inside are SMD, to small
to work on. If you could still see txt on the screen when you shine your torch, it could be fixed by
replacing the back lighting PCB.
Hope this helps
Have a nice day.
Posted on Dec 22, 2008
When i push the power button on my nikon coolpix L5 the lens comes out and the screen flashes on then off
sounds like grit in the lens mechanism..... but is it worth enough to get it serviced?
Apr 17, 2014 | Nikon COOLPIX L5 Digital Camera
Blank screen
Sounds like you got took to the cleaners . nothing fixy can do for you.
Oct 28, 2017 | Televison & Video
Describe your (VL1916) 19" LCD
Did you try this monitor with another PC and already verify that the VGA cable is OK.
Common problem with Princeton monitors are due to bad DC filter capacitors in the power supply board, see example here:
http://s807.photobucket.com/albums/yy352/budm/PRINCETON/
Sep 10, 2011 | Princeton Digital VL1916 19" LCD Monitor
VL1716 Monitor screen black
they are using java and possibly dhtml scripts, your browser may not work properly with their site, but this is the link
http://www.sonyrewards.com/en/home/base/?ref=http%3A//www.sony.com/index.php
Aug 20, 2009 | Princeton Digital LCD17D (Graphite) 17 in....
Canon ip1800 printer not working
when the yellow led flashes is never a good signal... you should check the manual's printer to find out the error code meaning "4 yellow flashes and 1 green)
Usally it's the waste tank that is full, in this case you need to:
  1. Push “resume” for 5 seconds for canon IPXXXX.
  2. Push Power switch then remove power cord.
  3. Insert plug power cord while pressing “power switch” at the same time.
  4. Push Start/reset by step 2 continue Wait display shown “0′
  5. Push + change display from “0′ to “1′
  6. Push color button 2 times
  7. Push Power switch again , Printer will print 1 page
  8. Open cover
  9. Unplug power cord
  10. Take out ink cartridge #40 and #41
  11. Insert plug again
  12. Push power switch
  13. Open cover (scan cover)
  14. Insert ink cartridge #40 and #41 again
Jul 18, 2009 | Canon PIXMA iP1800 InkJet Photo Printer
Same problem
Check the Inverter card Connector which goes to pannel,Next Panel to AD card signal Cabble,..
Jul 10, 2009 | Princeton Digital VL1918 Monitor
My laptop don't turn on but the green light in
you have power but no screen? try swipping your finger over mouse pad or pushing keyboard....also try a power cycle...unplugging battery but leaving the the poewr adapter in..push power button down for 1 minute....then press poewr button again...it might solve the problem...if not shine a flash light at screen see if you can see a faint image..there might be a problem with the inverter or backlight that lights up the screen...also try external monitor ifyou hvae one...and make sure computer power adapter is good and the battery is good...if this doesn't help you might have to get it serviced...if under warranty call warranty companie...if not under warranty call local computer repair shop
Apr 16, 2009 | Acer Aspire 5520-5908 Notebook
Monitor will not display
Hello, tech support online at Sony was able to help me correct the problems.
Mar 08, 2008 | Princeton Digital VL1812 18.1" Flat Panel...
Wont stay on
IF there is no display even with a flashlight, the P/S board is malfunctioning. Bad capacitors or LCD driver board circuit. Mine did this and it was bad caps, 4 of 8 were bad and a burned out chip on the P/S board.
Oct 20, 2007 | Proview PL913S 19" Flat Panel LCD Monitor
PRINCETON LCD-15BLK MONITOR
Looks like one of your backlights is bad, first indication is the red or pink tint, replacement of the lamp is fairly easy. If one lamp is bad the inverter will not work. You can get a replacement lamp from Mouser electronics for about $12
Sep 27, 2007 | Princeton Digital VL180 18.1 in. Flat...
Open Questions:
Princeton Digital VL1812 18.1" Flat Panel LCD Monitor Logo
188 people viewed this question
Top Princeton Digital Computers & Internet Experts
jairo sanchez
Josh Whitehead
Josh Whitehead
Daniel Dollive
Daniel Dollive
Are you a Princeton Digital Computer and Internet Expert? Answer questions, earn points and help others
