Question about Olevia LT32HVM 32 in. LCD Television
NO SIGNAL are the only thing I see on my TV
Seems to me I may have pushed a few wrong buttons on my remote without knowing it. I have nothing on my TV screen accept NO SIGNAL!
I have re booted, unplugged, etc, but the only thing the TV responds to is off and on.
I have checked all plugs, wires,switches etc all are fine.
  • mrsphillips Jan 01, 2009
    my tv is telling me no signal. when i scroll through the different source options it skips over the channel that has signal and goes to componet.
    Habit-Forming:
    New Friend:
  • 95 Answers
Check the source button on the TV remote is to the correct input!
Posted on Jan 06, 2018
4 Suggested Answers
  • 191 Answers
SOURCE: TV won't turn on, please help......
change your power suply
Posted on Nov 02, 2008
MNfisherman
  • 11896 Answers
SOURCE: Same thing... suddenly will not "allow" one channel to be seen
go to tv menu, do an "autoprogram" and it will select all available channels.
You can also do an add/remove channel and manually delete the channels you know you don't have.
You can also change your tv from air to CATV (cable) On cable tv you can still get all the air channels and Fox just the numbers will be different, but you may have a better signal
Posted on Jul 10, 2009
bbl242003
  • 1637 Answers
SOURCE: tv will not power on using the remote or push
CERTIFIED TV EXPERT HERE, follow this information I provided 3 long solutions to this issue/s
Solution 1
Before we start taking things apart, lets try your simple remove power plug routine and power system back up. Also, please try your unit on a few different channels to see if your problem continues on each channel. Your Main Board, Power Board, T-Control Board are suspected problems at this time. Press and hold the power button for about 15 seconds, the unit should power down by itself after you have powered it on. If it does not, then do not be concerned. Let me know if the problem continues. Thefirstlink below will bring you directly to the troubleshooting guide if you need to continue forward with the same error. Additional information http://www.fixya.com/support/r5093881-lcd_flat_panel_tv_troubleshooting_guide Failed TV and Monitors: http://s807.photobucket.com/home/budm/allalbums http://en.wikipedia.org/wiki/Capacitor_plague Parts: www.shopjimmy.com
Lets focus on the external portion of the TV set first (95 percent of all TV problems are related to things EXTERNAL To the tv itself) Check the physical CONNECTION of all cables by removing each wire bare or RCA and reinstalling it (Each power cable as well), once you have removed one cable, check it for fraying, and if it is already bare, splice a new fresh connection for it. 5. Check to make sure there are NO OTHER uneeded radios, system nearby. these systems, when powered on, will cause electromagnetic interference and prevent more than just severe tv interference SURGE PROTECTOR Surge protectors account for more than 75 percent of electric faults to stereo equipment. Lets start with your AC Wall outlet. It is standard in america that 220 Volts from out of these outlets. This implies that each device will be using 220 Volts (From within that grid zone). If anything including an alarm clock is plugged into any AC outlet socket in the vicinity of the stereo equipment/TV, it will cause electric outage, and prevent electronics from even turning on! Your TV needs dedicated electric power. If your TV is located in the living room then unplug everything else in the living room. Lets plug the TV set into a Dedicated socket. Check all light switches to ensure that power is on for that outlet. Check the TV cable for Fraying both on the ac wall end and where it plugs into the TV. Check all GFCI outlets to ensure that all red reset buttons are pushed in, check the circuit breakers for proper connection and they are turned on. Now, lets try the TV set without it connected to any cable services, vcr, dvd, stereo system, etc. Please respond if we have found a solution.
Posted on Jan 22, 2011
I have 2 remotes to my RCA LED52B45RQ tv. both are RCA remotes and we are having the same problem with both... they randomly stop working (nothing works). power button lights but nothing happens.
You may have a stuck button and not know it. look at the led end of the remote with the camera on your cell phone. If you have a stuck button you will see the led flashing. If it isn't flashing. push a button to see the led flash. Keep pushing different buttons to see if the led will flash without holding a button down. If you push a button and the led doesn't flash, it can be worn carbon button or the ic in the remote is failing If this test procedure does not find why the remotes die. you may want to invest in a a remote that will never become obsolete or worry about codes to operate more devices. It's called a Harmony remote. It's awesome. Logitech Harmony universal home theater remote and app
Sep 13, 2016 | RCA Televison & Video
I pushed the wrong button on my remote and now my Akai flatscreen says no signal. But I don't know what button I pushed! Please help!
Unplug TV from power outlet ,wait 5 min and pluged back.Should go back to manufacture setup
Cheers
Aug 23, 2011 | Televison & Video
Lost the direct TV signal to the TV when nephew pushed a button on the remote (he doesn't remember which button) The other TVs in the house receive signals per usual.
Your nephew must have pushed the "Input" button on the remote. The TV is now looking for signal at a different input.
On the remote, press the input button until the TV switches back to the correct input. Make sure the satellite receiver is turned on so when the TV lands on the correct input, you will know it.
Dec 17, 2009 | Cars & Trucks
Buttons locked on AOC 24'
On the tv press and hold the + and - volume control buttons and the buttons should unlock.
Sep 20, 2009 | AOC L24H898 24 in. LCD TV
1999 RCA mm36100 TV The buttons on the front panel are all messed up sometimes they work and sometimes not. The menu keeps popping up from time to time randomly and sometimes runs though the menu items all...
Bad push button board, best thing to do is just unplag the board and use remote to operate TV, board is mounted under front cover where button are.
Aug 09, 2009 | RCA MM36100 36" TV
Lost the remote to the tv now it wont turn on manually
the remote has nothing to do with the tv not turning on or off you should be able to push the power button on front of the tv and turn it on that way.if its not staying on then theres something more wrong than just a lost remote
Jan 21, 2009 | Mitsubishi WS-55513 55" Rear Projection...
RCA TV Remote Malfunction
From your post I understand that the tv is not turning on even if you use the button on tv, if that is the case there is nothing wrong with the remote control, and from the blinking light shows that there is something wrong with the tv. Get it checked by a qualified service guy.
Jan 25, 2008 | Televison & Video
Olevia LT32HVM 32 in. LCD Television Logo
69 people viewed this question
Top Olevia Televison & Video Experts
Steve Allison
Steve Allison
Jerry Greenberg
Jerry Greenberg
Are you an Olevia Televison and Video Expert? Answer questions, earn points and help others
