Question about Samsung YP-F2 (512 MB) MP3 Player
Mp3 yp-f2 Please help i have just brought a mp3 yp-f2zw i only charged it a little bit and now it will not charge at all, when i plug it into the computer using the usb cable nothing comes up on either the computer screen or mp3 screen. it's a flash only mp3. PLEASE HELP Sandra
  • 4 Answers
SOURCE: Samsung YP-K3 MP3 Player won't start
Simalar problem to all above plus PC would not recognise the unit when connected. Solved however by going into Device Manager on PC, uninstalling it and then plugging back into PC. As it is all plug and play it took it as a new device and everything working perfectly again.
Posted on Aug 24, 2008
SOURCE: Samsung YP-U3 MP3 Player Problem connection
Found the solution on another site ( To quote user AFHavemann :
"* Plug in the player so the USB bus can see it.
* Once it’s recognized (i.e., the device screen reads "Charging" and "USB Disconnected"), go to the Control Panel and click "System"
* Choose "Hardware" then "Device Manager" tab.
* Look for the name of your device under “Portable Devices” in the list
* If the name of your player is under “MTP Device” then the correct drivers are probably loaded
* Right-click on the name of your device and click "Properties"
* Click “Update Driver”"
Then follow the prompts from there. The computer searches for the driver software, etc., and reinstalls/resets information related to the device, which fixed things such that the computer will now recognize the device. I'm not sure what causes the problem, but this solution seems to reset whatever's gone wrong.
Posted on Nov 17, 2008
  • 3 Answers
SOURCE: I can't seem to turn on my Samsung YP-T7J MP3 Player
on the bottom of the mp3 player there is a very little button that u need a needle to push its the reset button sometimes these mp3 freeze and u must push the reset button it u dont loose any music or saved files anything like that it just basically turns the mp3 player off for u so that u can then turn it on using the play and pause button on the side of the mp3 player if this doesnt work the i guess tuff nooges
Posted on May 13, 2009
  • 233 Answers
SOURCE: my mp3 doesnt connect into my usb it just disconnects and starts to charge can you help me
I assume from your description that either you are running a version of Windows older than XP/2000 or you need a special driver. Here is a link for the driver(s) you will need. Just enter your model number and select your version of Windows. Download and run the file and you should be up and running shortly.
Posted on May 30, 2009
SOURCE: cannot connect my yp-u3
i have installed wmp 11 and samsun media studio
Posted on Dec 20, 2009
  • 7 Answers
SOURCE: Samsung YP-U3 mp3 won't turn on!! help please
go to its got all you need to fix your mp3 player
Posted on Jul 17, 2010
0 characters
1 Points
Ok I have had my samusung yp-k3 player for about 2 or 3 years now but havent used it in a year so it wasnt charged and I put it on the charger and it fully charged so when I took it off to use it,it wont...
sadly and there might be another solution i hate to say the only thing that has worked for me is reset normally but you could plug it into the computer and copy all the files onto the pc reset the device and put the files back on i hope it helps you
Sep 16, 2010 | Samsung YP-K3 MP3 Player
The problem is with the battery or the USB cable.
Check the cable first if there is any damage replace it,if there is no damage then the problem is with the battery which is not charging get it replaced and ur problem will be solved..
If you have any other problems please feel free to ask..
Feb 10, 2008 | Samsung YP-K3 MP3 Player
My samsung yp-u3 is not charging. when i plug into
No its not broken try to hold it tightly then it will work. Thanks :)
Jan 02, 2010 | Samsung YP-U3 MP3 Player
how to power on samsung yp-u3qb tell me very soon
Nov 09, 2009 | MP3 & Digital Media Players
Ya i have same problem
You just keep it plugged into the computer (in usb 2.0) until it says "Fully Charged", and then take it out and then see what happens.
Hope this Helped!
Sep 06, 2009 | Samsung YP-K3 MP3 Player
How do I charge Samsung MP3 player Yp-U3 Samsung YP-U3 MP3 USB port not connected to the computer
The player needs to be charged via the USB connnection on your PC. If it doesnt fit, try the USB ports on the back. If its not working/not charging, please test the MP3 player on another PC.
Jan 21, 2009 | Samsung YP-U3 MP3 Player
Samsung YP-F2
Try resetting the device. Mp3 players have an extraordinarily high failure rate, regardless of how good the manufacturer is.
Dec 12, 2008 | Samsung YP-U3 MP3 Player
My mp3 YP-U1 is cannot read in my computer pls. help me :(
Device is charging once connected to USB-port.
Is recognised by the computer but cannot be accessed.
Sep 09, 2008 | Samsung YP-U1 MP3 Player
My samsung K3 wont turn on.
Maybe you have a USB 1.1 on your computer. YP K3 will charge much faster on USB 2
Nov 02, 2007 | Samsung YP-K3 MP3 Player
Can I cahrge my Samsung mp3 player using my ipod shuffle docking station
you cant't charge the mp3 like that because samsung and ipod are tow diferrent companies and if you could you might enup frying your mp3 so try buyng the car charger for the yp-z5.
Jul 04, 2007 | Samsung Yepp YP-Z5AB / YP-Z5AS MP3 Player
MP3 & Digital Media Players Logo
Top Samsung MP3 & Digital Media Players Experts
 Mike M
Mike M
Lawrence Oravetz
Are you a Samsung MP3 and Digital Media Player Expert? Answer questions, earn points and help others
