Question about LG DLE2514 Electric Dryer
How do I fit a new drive belt for my Kenwood KVT1W Tumble Dryer
Can't work out how to get it over the drum
Remove the piece of angle iron from the top back of the LG DLE2514 and slide the top back. This exposes the screws holding the control panel on.
The control panel is held on by two screws, but they are at an ackward angle. The pannel has plastic tabs, when disengaged the panel pulls up.
There should be enough cable to set the pannel on top of the machine without disconecting anything.
Taking off the front pannel is easy at this point. Under the control pannel are four screws holding the front on. The Door has two screw holding it on and two alternates on the other side. The last two screws are at the bottom of the door opening.
Posted on Jan 24, 2009
  • LG Master
  • 8,220 Answers
I am not familiar with this machine but most dryers have to have the front removed so that you can slip the belt over the drum. I would imagine they have the screws hidden pretty well. Perhaps their is a removable front panel. Some have a few screws on top then you raise the controlpanel exposing the front screws. Just a guess.
Posted on Dec 22, 2008
How do I fix a drive belt to a kenwood KVT1W tumble dryer please
Hello Linda;
My name is Peter. I am a retired field service appliance technician.
Go into the following web link. It is not for a Kenwood but the base tasks are there. Whirlpool Kenmore Dryer Repair How to Remove and Replace Belt 341241
Jun 08, 2015 | Dryers
How to fit belt on Creda Reversair 37643 Tumble dryer
New belt is very tight, so you have to use more strength. Put it on motor and all other on "drum". Spin it easily and slowly but with strength until its done.
Be carefully, use gloves.
Apr 13, 2013 | Indesit Hotpoint Creda Tumble Dryer Belt...
Simpson Maxidry Tumble dryer (Cloths dryer) How
Hi there, There is a switch at the bottom of the dryer. It has a groove for the spring to fit around. Then the spring goes through the metal tag with the holes in the pulley. The pulleys 2 prongs then fits into the slot near the motor. The belt goes through the pulley and around the motor wheel. When fitting the drum, tape the belt at three points on the drum with the machine door facing down making installation easier. Once installed remove the tape. The dryer now works like a dream. See the attached photo. Good Luck!8e72e75.jpg
Jun 21, 2010 | Dryers
How to change a belt on hotpoint tdl54 tumble dryer
The belt goes around the pulley of the motor after fitting it around the drum first.
Mar 23, 2010 | Hotpoint Dryers
Where is the driver belt for kenwood tumble dryer model kvt1w, my machine wont rotate and im told this is why? but i dunno what part of the machine it would be in
It is a long, narrow belt that runs from the motor underneath up and around the drum. You should be able to find an exploded view at www.appliancepartspros.com as long as you have the complete model number. Good luck.
Mar 09, 2010 | Dryers
Fit new drive belt to tumble dryer
I need to know more. like how to instal belt or how to find what belt fits your dryer . need more info like mod # there 5 different belts for hotpoint . and several different ways to install them so model # ______________ needed . **** . pls .
Jan 02, 2010 | Dryers
How to fit new drive belt to white knight tumble dryer
YOU HAVE TO REMOVE BACK AND EASE REARWARD - THEN SLIP DRUM BELT IN FRONT OF DRUM THEN REASSEMBLE - NOT EASY TO EXPLAIN
Apr 05, 2009 | Dryers
I Have A Kenwood KTV1W Tumble drier on which the drive belt has snapped. I have ordered a new one but don't know how to access the drum to fit the new belt and how to put it on the drive motor pulley.
There are 4 posidrive screws in the middle of the back plate of the unit, once these are undone the backplate can be removed leaving the drum and motor pulley open to fit the belt
Sep 20, 2008 | Dryers
Manual for KVT1W
http://www.espares.co.uk/parts/tumble-dryers/kenwood/kvt1w-1123-547-15000/p/1088/435/0/631602
Try this site and see if they can help you out. I would imagine that you are overseas somewhere, can find anything washer or dryer type for Kenwood here in the states. Let me know if they cant help you, will do a little more looking for you. JIM
Nov 21, 2007 | Dryers
LG DLE2514 Electric Dryer Logo
279 people viewed this question
Top LG Dryers Experts
Tim Whalen
Dan Webster
Dan Webster
Mike
Mike
Are you a LG Dryer Expert? Answer questions, earn points and help others
