Question about Refrigerators
Forgotten how to turn off child lock - Refrigerators
  • 37 Answers
Hi
press and hold the child lock button until it beeps...
Thank you
Posted on Dec 22, 2008
The child lock on my smart drum lg washing machine is on how doi turn it off please
To TURN OFF CHILD LOCK on your LG washer, press and hold the CHILD LOCK button for 3 to 5 seconds. The washer should now have CHILD LOCK mode DISABLED and all buttons will function properly.
PLEASE NOTE: ON other newer LG front load washing machines hold the PREWASH/CHILD LOCK button for 3 to 5 seconds to turn CHILD LOCK OFF.
Jul 28, 2018 | LG Washing Machines
Roncato suitcase forgotten my combination and cant open the suitcase
I have a Roncato hard shell with a 3 digit combination lock under the handle. I set the combination YEARS ago, had a young child play "horsey" on it, and turned all the numbers! The suitcase was locked and I had forgotten the combination. I followed the instructions in answer 2 above and it worked! I didn't have to add or subtract 5. I used a small sewing needle and a strong flashlight - the indentations were easy to see.
Feb 11, 2013 | Samsonite Photography
Child safety lock feature is on. how do you take it off
im not sure if your model of dryer but here is some instructions
Child lock
When activated, the child lock prevents the dryer from being operated by locking the control panel functions.
The dryer can be turned on but not started. The "Child lock" indicator will flash.
The door can be opened.
To activate the child lock
1. Make sure the dryer is turned off and
the door is closed.
2. Press and hold the "Anti-crease" and "DRYNESS" buttons at the same time, hold until step 5.
3. Turn on the dryer with the "On/Off" button.
4. Press the "OPTIONS" button 3 times. 5. Release the "Anti-crease" and
"DRYNESS" buttons.
The "Child lock" indicator will flash and the dryer is now locked.
6. Turn off the dryer using the "On/Off" button.
To deactivate the child lock Repeat steps 1. to 5.
The "Child lock" indicator will go out. The control panel is now unlocked.
Dec 15, 2012 | Bosch Washing Machines
How to remove child locks
If you have lost or forgotten the code, the default factory password is 0000. This should still work even if you have set another password and forgotten. You should also deactivate the lock fully from the menu if you no longer wish to use it or activated it accidentally.
Disabling the child lock (and/or other locks):
(This can be done from the remote or the buttons on the front of the TV)
1. Press MENU to open the main menu.
2. Press CH+ or CH- to highlight PREFERENCES.
3. Press OK to enter the PREFERENCES menu.
4. Press CH+ or CH- to highlight FPA Lock (Front Panel lock) .
5. Press VOL+ or VOL- to switch the lock on or off
6. Press MENU repeatedly to exit the menu
The menu will disappear if no buttons are pressed on the remote for several seconds.
Please let me know if you need further assistance.
Regards,
BElectric.
Jan 31, 2011 | RCA TruFlat 27F520T 27" TV
How to release child lock in seimens washing machine that is wash and dry D12-52 1200 rpm
Child lock will deactivate only in the original programme that it was activated in. If you have forgotten the orginal programme, try deactivating separately in each programme.
To deactivate child lock press the clock key for 5 seconds.
Nov 07, 2010 | Siemens WFXD8400UC Front Load Washer
What is the reset code if you have forgotten the child lock code for aquos 22" 6 years old
Press menu for the menu to appear. Press the Up or down button to select features then press ok to display the features screen. Press the up or down buttons to select child lock then press ok the pin input appears. Input (3001) with channel select. The child lock menu appears and the pin is cleared. You can then enter a new pin. Hey if this works give me a vote please so I'll know if I helped.
Mar 04, 2010 | Sharp Aquos LC-22SV2E 22 in. EDTV-Ready...
Prosonic manual child lock will not remove. I have forgotten my code
The factory-default password is '1234'.
Clear All—Resets all V-Chip settings to factory
defaults (unblocked)
Feb 25, 2010 | Prosonic PLTV-30 30 in. HD-Ready LCD...
Help unlock child lock on tv.
Try this website: www.usermanualguide.com there is probably a section in the user manual on how to reset a lost/forgotten child lock. Good luck.
Oct 01, 2008 | Televison & Video
Forgotten password
Your tv is switched on and locked , blue screen and shows keys. A tv with activated child lock can only be unlocked after an 4-digit code is punched in.
Reset of child lock is as followed :
Determain chassisnumber type on type plate on the back of TV.
example: CUC xxxx ( xxxx = 4 digit number).
TV's CUC 6300, 6301 and 6310: bullet.gif Press cursors (blue arrows ) in sequence : Right, Left, Down , Up, followed by OK
TV's with chassis CUC 2003, 2005, 1805, 1825 t/m 1827, 1842, 1894, 1952, 1962, 1983, 1984, 1806, 1828, 1829, 1830, 1836, 1929, 2020, 2021, 2030, 2031, 2033, 2050, 2058, 2059:
bullet.gif Punch in universal code 7038 in. This code ends the child lock
TV's with Chassis CUC 1832, 1930, 1931:
bullet.gif Punch in universal code 7038580. This code ends the child lock Greetz and good luck, and PLS let me know if it works
Arni
Jun 13, 2008 | Televison & Video
28p6515
Remember that 0711 is the default AutoLock
code. If your access code has been changed by
someone other than you (a child, for example)
or you have forgotten the code, you can always
get in by inputting the default code.
Feb 18, 2008 | Televison & Video
Refrigerators Logo
475 people viewed this question
Top Refrigerators Experts
John Tripp
John Tripp
Marvin
Marvin
