Question about Hotpoint WMA46 Front Load Washer
DOOR WILL NOT LOCK
I HAVE A HOTPOINT WMA46, I HAVE CHANGED THE RUBBER DOOR SEAL AS IT HAD A LEAK. BEFORE THE LEAK THE WASHING MACHINE WAS ON A WASH CYCLE AND TRIPPED THE RCD. NOW I HAVE REPLACED THE DOOR SEAL THE DOOR LOCK LIGHT IS FLASHING INDICATING THAT THE DOOR IS NOT LOCKED. PLEASE HELP
    President:
  • 1,462 Answers
Assuming that you didfi not unwire ther door lock, the problem is probably just that the door seal just needs bedding in and you should be able to start by closing more firmly and pushing in till the door lock catches. did you properly seat the door boot on the cabinet?
Posted on Apr 07, 2007
Water leaks on spin cycle
Water can leak if there are gaps on the front door gaskets and must be checked but this will happen only during the cycle and not on the drain cycle end.
Tips for leak: http://www.espares.co.uk/advice/washing-machines/a/7/1461/do-you-have-a-leaky-washing-machine.html
Replacing Door seal: http://www.espares.co.uk/advice/washing-machines/a/7/1464/how-to-replace-the-door-seal-on-a-washing-mac.html
Feb 01, 2013 | Hotpoint Aquarius WD63 Front Load...
Hotpoint WMA46 door problem
From the symptons you describe, it could be a broken or weak spring in the door handle, which ca be fixed relatively inxpensively, that is where i would start, you can purchase one directly from hotpoint, or possibly a local repairer. if that does not cure the problem, then the odds are it will be a faulty programme module.
Hope this helps.
Jan 13, 2010 | Hotpoint WMA46 Front Load Washer
My hotpoint wd420 is leaking water from out the dispensor and door on a rinse/spin cycle.
You ne to get yure rubber seals checked and changed it sounds like they have perished
Nov 27, 2009 | Hotpoint Ariston Aquarius WD420 Front Load...
Water is leaking from the door especially when on fast spin
you need to get a new rubber door seal u can get it from this website http://www.4hotpoint.co.uk/cgi-bin/home.pl?gclid=CMKHz4OM05wCFZMU4wod5HwDKw to replace it you take the clip off the front of the washer the peal off the seal off the frame and the do the same off the drum then but the new one on.hope this helps.
Apr 13, 2009 | Hotpoint WMA48 Front Load Washer
Door lock light flashing
could be a faulty belt. May need replacing. Or in the worse case scenario the bearings may need replacing.
Sep 21, 2008 | Hotpoint WMA46 Front Load Washer
WMA46 Door Seal
turn off at mains
remove clamp that holds door seal to cabinet. peel door seal off cabinet.
remove worktop
undo clamp that holds seal to tub. pull seal away from tub.
to refit
lubricate slot in seal that goes on tub rim with washing up fluid
starting at top, fit groove in seal onto rim and work your way round in both directions pushing seal on to tub rim - requires patience and you amy not suceed first time round.
refit inner clamp
fit seal rond cabinet -0 this part is easy
refit outer clamp.
test for leaks on rinse as the water level is higher
Sep 07, 2008 | Hotpoint WMA46 Front Load Washer
How do I replace the door seal on a Hotpoint WF860
unless you are really bored don't try it ..front side not bad but inside where it mounts onto outer tub can be a big black bear ..little space to work and rear band even tougher
Aug 29, 2008 | Hotpoint Ultima WF860 Front Load Washer
Door Lock Light - flashing
does the door still lock? becasue it sounds like a faulty lock. It may need to be replaced.
Aug 25, 2008 | Hotpoint WMA46 Front Load Washer
Hotpoint wma46 door lock
make sure door seal is fitted correctly to the cabinet. you may find that all that is required is to push the door harder than usual till the seal beds in
Mar 29, 2008 | Hotpoint WMA46 Front Load Washer
WMA46 stopped woking power off mid cycle
hi there the problem you have sounds like the motor has shorted out causing the pcb to blow, sadly this is a costly repair and is usualy not worth repairing as you will need a new motor and pcb
murdozzz
Dec 09, 2007 | Hotpoint WMA46 Front Load Washer
Hotpoint WMA46 Front Load Washer Logo
192 people viewed this question
Top Hotpoint Washing Machines Experts
vince
Eric Taylor
ptpumpman
Are you a Hotpoint Washing Machine Expert? Answer questions, earn points and help others
