Question about HP LaserJet 2500 Printer
Can not print
I am not able to print, though I have tried to change ports ect
    Problem Solver:
  • 9 Answers
Are you trying to print via the LAN if so goto the www.hp.com
web site and down load the latest network print driver, also make
sure your windows has the latest drivers installed, Hope this helps
Posted on Dec 22, 2008
Why would my Trendnet Print server TE100-P1U not be seen by all computers on the network even though it can be pinged. I can't install it on these computers even though it can be pinged
May requires software loaded on every computer - software that will create the non-std print server "port".
More expensive print servers like the HP jetdirect print server use std tcp/ip ports.
Nov 13, 2013 | Trendnet 1-Port Print Server TE100-P1U...
Why would I be getting poor gas mileage on a 2000 vw beetle? I just bought with 68000 miles
well you could need a tune up new spark plugs wires , or coil on plug depending on vehicle change oil and air filter pcv valve check tire inflation level add air if needed also try adding a regaine fuel system treatment regaine isolates ethenol aka water and passes it though system and cleans injectors lits ports ect
May 05, 2011 | 2000 Volkswagen Beetle
Blank pages; new ink
You need to change your print setting preferences to print on photo paper and choose the correct type before trying to print pictures. While in the picture you want to print on your pc screen, go to file and then print and choose preferences. Then change the paper type to the type of photo paper you are using (i.e. glossy, matte finish ect.) and hit "ok". Then trying printing your picture and see if this solves your problem.
Sep 27, 2010 | Kodak ESP7 PP All-In-One Printer
Nat type is strict. how do i change it?
Go into your firewall and forward ports, and do the same in your router. Depending on what it is that your're trying to do. In the firewall permit what you need: ie: filesharing, ect, forward the ports, and then go into your router, and forward those same ports. EXAMPLE: 192.168.1.1 port 50095 ( both tcp/udp ) to port 50095 then do the same in the firewall.
Dec 02, 2009 | Computers & Internet
Nokia n95 doesnt let me send tx text messages
NOKIA N95 YOU HAVE GIVE TO NEW VERSION MOBILE SOFTWARE
Aug 22, 2009 | Nokia N95 Cellular Phone
D Link DP301U not working with a Canon MXF series printer
dont' worry about what the d-link site says. its because they haven't tested it. i got my dp-301u to work fine with my hp1020 on 2 different workstations with the following steps.
1. install printer locally via usb and test.
2. create a second printer as per the dlink manual creating a port. don't worry about the name as we will delete it.
3. once created go into the properties of the 2nd printer and change the port to something local - anything will do to free up the port.
4. go into the properties of the printer that was created in step 1. and change the port to that of the print server.
5. test print. should work fine.
cheers!!
Jun 23, 2009 | D-Link DP-301U (790069251979) Print Server
Can't print on home network
Well an unisall and reinstall of the printer drivers on the network would definately solve your concern.If you want further support you can avail free online technical support on http://tinyurl.com/m7ghqz
Jan 20, 2009 | HP Photosmart D7360 All-In-One InkJet...
Printer
How are you trying to connect? USB, Network, Wireless network ect. If it is USB make sure you install the print drivers before plugging the printer in to the computers USB port.
Dec 04, 2007 | Lexmark (12G4507) UPS System
Unable to print
If both printers are connected through a parallel switch, be advised that changes on the switch do not take effect until the computer is restarted. Those boxes worked fine under DOS, but Windows does not support them. Connect the Samsung printer to the USB port and make sure you use a good quality cable and not those thin and cheap cables.
Aug 30, 2007 | Samsung ML 1210 Laser Printer
Printer doesn't work
The answer is probably down to the usb port, they don't always like change, because you are trying to swap hardware in same port, they tend to want to stay with one or the other peice of hardware. If you have'nt got another spare USB port, which i assume you have'nt, invest in a 2 or 4 port USB hub(But make sure it's powered by a AC power lead and not just a usb powered hub, because some hardware will not be recognised e.g I Pods), this connects into your usb port and gives you 2 or 4 port more to use, and you won't need drivers for it. They are inexpensive and you simply plug it in. I think this will solve it for you
Oct 23, 2006 | Samsung ML 2010 Laser Printer
HP LaserJet 2500 Printer Logo
mukhtar21 shaikh
mukhtar21 shaikh
