Question about Actiontec GT704WG Wireless Router (gs583ad3-01)
Port forwarding can someone please explain how to set up port forwarding on an actiontec gt704wg?
  • 3 more comments
  • Anonymous Dec 29, 2007
    error on my port opening
  • turtlepirate Jan 03, 2008
    How Do I Get Port Forwarding To Work?
  • wShannon Jan 19, 2008
    How do you port numbers
  • Anonymous Feb 27, 2008
    I can't get to the default gateway admin page 192.168.0.1 Please help me forward ports
  • Anonymous Apr 19, 2009
    The link posted is dead.
    Cannot get port forwarding to work.
  • 779 Answers
Its explaned in the manual - here on page 47 http://www.actiontec.com/support/broadband/gt704-wg.html which is probably simpler than repeating here - however, if you have trouble with the manual - post back a reply
Posted on Apr 12, 2007
  • wayne walker
    wayne walker Apr 17, 2007
    so you rated as poor - yet did not reply to say you still had a problem after reading the manual and what you needed to understand ....
I can not access my ip Foscam FI8918W camera from internet (dyndns.org)...port forward is not clear. I have a Verizon Router Actiontec GT704WG. I am supposed to access camera...
OK let me clear port forwarding for you, your router normaly has a firewall (to block of any requests from the internet to exploit any services trough any ports) so if you want access to a resource on the LAN side (side of the router where all the devices and computers are pluged) from the WAN side (side where the ISP's modem is connected for internet) you have to open a port or multiple ports to a specific device IP address (according to device manual).
for exemple:
assuming that the camera has an IP of 192.168.1.110 and it uses port 7777 for resources, in the port forwarding section of the router you ave to open port 7777 and direct it to 192.168.1.110 (save settings and VOILA)
enjoy!
Jan 04, 2011 | Actiontec (GT704WG) Router
Can I connect a GT704WG to a COMCAST SciAlt modem and have wireless
No. The uplink for the Actiontec is the DSL port. You would be better off purchasing a router from a retailer instead of a gateway modem/router combo like the Actiontec
I’m happy to help further over the phone at https://www.6ya.com/expert/susan_42b401e0b1603d8a
Sep 24, 2010 | Actiontec GT704WG Wireless Router...
Once i open my router how do i actually open the ports for xbox tcp80,udp88,exctra im using a action tec gt704wg wireless router
http://www.actiontec.com/support/product_details.php?pid=40&typ=doc
Your manual above it also shows you how to open ports in there.
Also if you go to http://portforward.com/, they will show you how to do it too. Go to the link below.
http://www.portforward.com/networking/staticip-xbox360.htm
Actiontec Gateways and Routers are compatible with the Xbox. However, it may be necessary to forward the ports used by the Xbox, in the Actiontec Gateway or Router. Without Port Forwarding, the Xbox Connection Test may report a "NAT" rating of "STRICT" or "MODERATE", rather than "OPEN".
It is also explained below...
Aug 21, 2010 | Actiontec GT704WG Wireless Router...
Actiontec Gt704WG wireless problem
fist try to enter modem config site at 192.168.1.1
admin user: admin
admin pws: password
wireless setup
check if wireless is on
check chanel
las step
try this with ips suport is you reset mdoem it returns to factory settings
try to reset it with a paper clip or pen hold it for 20 seconds
May 03, 2010 | Actiontec GT704WG Wireless Router...
Will The actiontec GT704WG work with frontier DSL
If DSL port is available in your GT704WG then must be work.
Mar 29, 2010 | Actiontec GT704WG Wireless Router...
I have a actiontec gt704wg trying to connect another router behind it .... iam not able to ...
your other router has to have the following settings:
1) it's IP must be on the same subnet as your actiontec. The subnet is the "third" number in the ip address. So if your actiontec has ip of 192.168.1.0, your other router must have IP of 192.168.1.XXX where xxx is some number other than 0.
2) the dhcp server of your other router must be turned off
3) you must run a lan cable from a lan port on the actiontec to a lan port on the other router. Note that the internet/wan ports are NOT used on either router for the purpose of daisy-chaining routers together.
Dec 07, 2008 | Actiontec GT704WG Wireless Router...
Trying to open gamer port on my actiontec router to play xbox360
It looks like what you need setup is port forwarding. You can visit this link for details specific to the router manufacturer.
http://www.portforward.com/english/routers/port_forwarding/routerindex.htm
Hope this helps :)
Kindly leave a good feedback. Thanks..
Nov 27, 2007 | Actiontec (GT704WG) Router
Fire Wall.
You will need to set a static IP on the Xbox in the Xbox live network settings. You will also need to forward ports 3074 both UDP & TCP, 53 both UDP & TCP, and 88 UDP if you run into DSL Resolution errors.
Oct 08, 2007 | Actiontec GT704WG Wireless Router...
Fire wall
Firewall issue?
Yes this is possible you can turn off the fire wall or you can open up the port your down loading program uses to communicate with its peers. in the menu I believe you will find a tab for port forwarding. They may even list the program you are using. in any event here is a link on port forwarding that may help: http://portforward.com/english/routers/port_forwarding/Actiontec/GT704-WGv2/BitTorrent.htm Subsittute your ports for the one on the web page and you should be connected in no time.
Sep 04, 2007 | Actiontec (GT704WG) Router
Actiontec GT704WG Wireless Router (gs583ad3-01) Logo
472 people viewed this question
Top Actiontec Computers & Internet Experts
Prashant M
Prashant M
Hollyecho Montgomery
Are you an Actiontec Computer and Internet Expert? Answer questions, earn points and help others
