Question about Garden
Lawn mower does not start up
My 7-year old VICTA 2-stroke lawn mower doesn't start. I cleaned the air filter, no luck, cleaned the plug, no luck, changed the plug, still does not start. Checked the
spark plug and it was soaked with petrol. Cleaned the new plug, and it still does not start.
When I pull the cord, it sounds like it wants to start but it just will not start up. Please note: I have not been using it for long time since it stopped working a while back. I now want to see whether I can get it working again.
Any one can shed some light on this?
  • 17 Answers
Lots of thing can stop a victa working!!!!!!!!!. Ok your plug is wet. Turn the fuel off. R&R tank renew fuel(no more than a month old it goes stale)Check for spark, be very careful it could catch a light.
Get the new plug open the gap to about the hex of the plug to the head, away from the plug hole ,the fuel will come out.
If it jumps gap when pulled it has enough spark to fire under load.If lots of fuel comes out its flooded.if so leave plug out remove a/f ,leave tap off, put throttle to full and pull till most fuel is gone.Refit plug and try. let me know how that goes. do this in well vented area. Fumes can build up in shed.
Posted on Jan 08, 2009
Engine starts. Why does it only run a few minutes, then stop?
a few things may cause this. it sounds like it is starving for fuel. the spark plug may be breaking down when it gets hot. try a new spark plug. if the fuel and fuel lines are in bad shape, old, soft or hard. the fuel don't smell right. fuel filter plugged up. the carburetor may need to be cleaned and a rebuild kit as they are cheap. if it is 30 years old. be sure the fuel lines, filter and carburetor are in good shape. hope this gives you an idea on where to start. good luck
Mar 14, 2016 | Garden
Victa2stroke cuts out after about 4 minutes of cutting grass
check the carb is clean and the spark plug is in good condition, also the air filters block up quite easily on those so remove it and blow it out. of course being a 2 stroke it could be that the piston /rings are scored up but you would need to remove the exhaust to inspect.
Feb 26, 2015 | Garden
Victa v160 runs for a while then stops
Ignition module is failing
Oct 14, 2012 | Garden
Have a 4.0 quattro Briggs and Stratton lawn mower. Starts up great and doesn't stall out. Has this annoying surge and slow down of motor. Removed gas from tank and sprayed some gum remover in tank and...
it does sound like a carb issue it may need to be rebuilt also check your fuel line and if you have a fuel filter check the filter clean the gov. assembly with carb cleaner
Jul 30, 2012 | Garden
How to fix a 3.5 lawn mower?
You can fix these yourself, all you have to do is to follow the instructions below,
1 Remove the spark plug lead from the spark plug and move away from cylinder head. Always do this before attempting any repairs to a lawnmower.
2 If your lawnmower is a "four stroke" mower (separate gasoline and oil), tip the mower so that the spark plug is pointing skyward. Never tip it on its side with the spark plug to the ground.
3 If your lawnmower is "2 stroke" (oil and gasoline mixed) turn off fuel tap. You can tip a two stroke mower any way that is suitable to you.
4 To change a blade, or blade disc, it is often easier to remove the spark plug and feed a length of string into the cylinder head to 'lock' the piston while trying to un-do the blade bolt(s).
5 Check the motor's "air filter" while doing this sort of maintenance as a dirty or clogged air filter will affect engine performance and increase fuel consumption of your mower. Symptoms of a clogged air filter include inability to start, starting and quickly stopping after several sputters, or a weak idle. You may also see oily or smoky exhaust.
6 If your mower is a "four stroke" model, change the oil at least once a year. When it is tipped over with the spark plug in the air, is a good time to remove the "oil fill" plug and drain oil into an old ice-cream container for recycling.
I hope this will help to solve the problem.....
May 31, 2011 | Craftsman Garden
Mower is old and not run for ages. now i can get it to start, but it cuts out after reaching top revs (about 2 secs0 victa panther 4 stroke
remove carb and clean it out. it may have dirt and grime in it. if need be clean fuel tank and put in new fuel, also check condition of air filter then you should be fine. have a good day !!
Mar 12, 2011 | Hammering
I have a Victa tornado 2 stroke lawn mower a VSX160 that would not start. i have replaced the spark plug and it is still not starting. I have been told to check the air filter but for the life of me i can...
Hi Mary, the air filter is on the carburator.There is a cover over it that just snaps off or is held on by a couple of screws. The carburator is where you can adjust for low or high speed with a lever or have a cable going to it to adjust the speed. It might also have a primer on it. That is the carburator. Remove the air filter take a look at it for dirt, grass clippings, etc. especially in the bends, clean it as best you can with air or tapping it on the ground. After doing that see how much is left on it. Air has to go through it so decide if you should replace it, they are not very expensive so I would buy a new one. Hope that helps you out. Best regards and good luck.
Jan 09, 2011 | Garden
Victa 2 stroke mower will not start
It may have a blown crankcase seal. How did you check the plug for spark?
you can remove the carbi and spray 2 stroke fuel directly into the chamber and try to start it.
If it starts you have a problem with the carbi or the fuel supply.
Take out the air filter as it may be blocked and restricting the air supply.
The float in the carbi may be full of fuel due to a hole in it or the fine fuel filter in the carbi may be blocked
Apr 04, 2009 | Garden
Masport Lawnmower won't start
you likley will need a new air filter and a carb cleaning. when mowers are turned on their side. oil will seep past the piston and if your intake valve was open it can pass thru into the carb and also spoil your air filter. I am assumeing you have a paper air filter. start by taking off your air filter. then you should also pull the spark plug, place a rag covering the hole. then pull the cord a couple times. chances are that you will blow the oil out of the cylinder.
Mar 31, 2009 | Garden
My lawn mower doesn't start
Hi Every 2 stoke engine needs three things to run:Fuel+oil/air mixture in correct proportions,compression and ignition.Remove the sparkplug and see if the spark appears when the piston in the cilinder is at top death point(almoust),if not check the flyweel key(not to be sheared).Check engine"s sealing(crankcase gasket,cilinder gasket,seals-crankshaft,carb gasket).Also the mufller(not to be clogged),disassembly the carb (check and clean it),fuel lines and fuel filter (check and clean them),gas cap tank vent(not to be clogged),the air filter.Please let me know. best regards savumihai71
Dec 22, 2008 | Troy Bilt 5.5hp Self Propelled Mower
Garden Logo
1,064 people viewed this question
Top Garden Experts
Dennis Key
Dennis Key
john h
