25 lites with 8 bars max pressure
Varem pressure tanks are simple pressure vessels. They have a chamber where the fluid comes in and a bladder that is pressurized on the other end that the fluid pushes against and compresses the air or other gas that is inside the bladder. When the pressure on the fluid line reaches the pressure switch setting, the pump shuts off and the gas pushes the water back out of the tank (if it is being used) until the pressure switch lower limit is reached and the pump kicks back on, pushing fluid back into the tank. This cycle continues until the fluid is no longer being allowed out of the system.
The bladder pressure is set when the system is empty of water and is set to a couple of pounds less than the low pressure cut on setting, that keeps the bladder from pushing all the fluid out of the tank before the pump comes back on resulting in a zero pressure moment which with some pump switches means it shuts down and has to be manually restarted.
Testimonial: "Thanks Wayne. "
A pressure vessel is a closed container designed to hold gases at different pressure. that involves parameters such as maximum safe operating pressure and temperature.
