Question about Frigidaire FEX831CS Top Load Stacked Washer/Dryer
Washer overflowing Our washer was overflowing when on large cycle....so we started using medium cycle then small now it is overflowing all the time....it appears to be coming from underneath the machine...not over the top
  • Anonymous Nov 18, 2007
    My Frigidaire GLGT1031CS1 just recently started over-flowing as it begins it's cycle.
Make sure you are using HE (high efficiency) clothes detergeant if you have a front load or he machine, and then only about two tablespoons per load. Otherwise, oversudsing will run over the tub and water will leak out the bottom once the bubbles recede causing it to appear like you have a leak. Just something to check before you have to pay a service fee to a repair man.
Posted on Jul 11, 2007
Clean out the peat trap by the front right side of the machine.
Posted on Apr 07, 2007
SOURCE:
I HAVE A MAYTAG PERFORMA WASHER MODEL#pav3240. the washer continues to fill during rinse cycle and overflows the top. If i turn to spin cycle water drains out and machine goes through cycles. it seems like...
Clean out the water-level switch air dome tube AND the the connection to the tub where the tube connects. It may well be full of gunk and not allowing the water level switch to react quickly enough.
Jun 06, 2017 | Maytag Washing Machines
The whirlpool washer overflowed and flooded the apartment
Need new pressureswitch or the pressure switch tube is not connected to tub or pressure switch itself!!! where it connects to tub at airdome might be plugged with dirt,soap ect!!!
Mar 15, 2013 | Whirlpool Ultimate Care II LSQ9564J Top...
I have a whirlpool washer in my rented apartment. My daughter turned the water fill switch and instead of placing it on a level, like say large or medium, placed it in between cycles. Basically, the
report the problem to the landlord and ask to have it fixed
the machine belongs to him and repairs are his responsibility as is excess water and damaged carpets after you inform him
might be best if you place his machine in a safe place and install your own machine
Apr 06, 2017 | Washing Machines
Washer just keeps filling and never advances on large and medium loads only
Your drain hose is pushed too far down into the drain so when you select the larger load sizes the water is being siphoned out as it goes in due to the pressure differential.
If you need further help, I’m available over the phone at https://www.6ya.com/expert/jason_4570d45317834dd3
Jun 01, 2012 | Electrolux Washing Machines
Overflow
Check water valve may not be shutting off .
Check water level switch , or hose going to it from tub must be air tight may have pin hole in it.
Water level switch is the one that says small , medium or large on some washers.
Jun 10, 2009 | GE WBSE2090A Top Load Washer
Fill will not stop
you may have a problem with your pressure switch. or sometimes they call it the water level switch.
try to use it in the small level and see if it would stop filling around medium or large quantities of water.
if it would stop filling , then replace the water level sensor.
tnx 4 using fixya,
drcool
Oct 18, 2008 | GE WBB4500EWW Top Load Washer
Overflowed on Large load size
i think the water level sensor tube got filled when you had it on it's side, then after the first spin and drain cycle, the tube was again cleared out and ready for real action.
Oct 29, 2007 | GE WJSR1070A Top Load Washer
Over filling
pressure switch pipe is either blocked or damaged, the weight of the water pushes air up the pipe to activate the switch to stop the water filling, for some reason its not doing so,
this is a small thin pipe that goes from a point in the machine low down, to a little round flat object (normally) up near the top of the machine inside up near the top
drain the machine and clear out the pipe at the bottom where it joins  the drum or whatever, make sure joints are made good
if i have helped please rate me
Oct 10, 2007 | Kenmore 88732 Top Load Stacked Washer /...
Frigidaire FEX831CS Top Load Stacked Washer/Dryer Logo
281 people viewed this question
Top Frigidaire Washing Machines Experts
Gerry Harvey
Gerry Harvey
J. Bradshaw
Archie Ferrarini
Archie Ferrarini
Are you a Frigidaire Washing Machine Expert? Answer questions, earn points and help others
