Question about ASUS P4B-M (P4BM1400WOLTINY) Motherboard
Could not detect HDD on my Asus P4B-M Motherboard
A had a replacement of HDD on my Asus P4B-M Motherboard with a old pre-formated HDD (Segate 40 Gb) with Windows XP professional already installed on it, but the bios could not detect it. I just want to know if there is a solution to it. Would I able to run Xp professional Service Pack II with this mother board.
    Mentor:
    An expert who has written 3 tips or uploaded 2 video tips.
  • 163 Answers
try removing with jumper behind the hard disk. and the see the cable or plugged in properly and do automatic detection of Hard drives in Bios
Posted on Dec 22, 2008
Sir, Im having P4BP-MX Motherboard 2GB DDR 40 GB HDD, CAN I GO FOR 1TB HDD for my Motherboard. I bought 1TB its not identifying Is my P4BP-MX Motherboard support 1TB or Not ?
There's two things wrong:
1. You can't simply install a hard drive and then use it. You have to format it and/or install an operating system on it.
2. Your motherboard is a very old model. While it is new enough to support LBA48 mode (which is necessary to fully use hard drives above 127 GB), it is possible that it has an old BIOS version that does not support it. You should check ASUS' website to download and install the latest BIOS update.
Dec 11, 2014 | Samsung Computers & Internet
I currently use 256 mb ram,I want change 1 gb ram,pls ur opinion
Upgrading RAM on your ASUS P4B-MX Motherboards is easy, we carry compatible RAM Upgrade for ASUS P4B-MX Motherboards, the ASUS P4B-MX Motherboards takes the PC100/133 SDRAM DIMMs.
Supports ECC RAM Type, and comes installed with 0 MB (removable) of RAM. You can upgrade your ASUS P4B-MX Motherboards to up to a maximum of 3.0 GB RAM, the Motherboards has 3 sockets to install RAM, already with 0 MB (removable) standard RAM installed. For best Motherboards performance use the maximum amount of allowed RAM per slot for your system.
Buy our Motherboards RAM with confidence, we provide lifetime warranty on all RAM Modules purchased, backed with an excelled customer support. Choose the following RAM Upgrade for ASUS P4B-MX Motherboards.
If you're not sure if a module is right for your system, use the Crucial Memory Advisor tool for a list of guaranteed compatible modules
hope this helps you
Mar 20, 2012 | ASUS Intel 845 Chipset P4B-FX Motherboard
Hi, I'm having K8V-MX Asus mother board with AMD 3000+ processor wih 1GB DDR ram, with 80 GB PATA Segate HDD connected. After adding 500GB SATA HDD to this mother board, my system performance is very low....
Thanks for the details. I have used K8V-MX Asus motherboard and found it very reliable with quite reasonable performance. It definately supports 500 GB Sata drive and there must not be any issues after increasing just the storage. However, Operating System upgrade may result in sluggish performance. Drivers dont seem to be an issue to me either.
I suggest to review a few points detailed as under: -
- K8V-MX Asus Supports RAID, so, check for any RAID Drivers/ settings. (You dont have to use RAID for two Hard Drives of different make, capacity and speed). Try using one disk at a time having same Operating System (e.g. Windows XP) and compare the performance.
- Infact SATA Drives have better data transfer rate than IDE, which results in enhanced performance.
- Some Programs (that you may not be using with 80GB drive) Like antivirus may result in decreased performance.
- Please Review you Operating System environment and software installed. Make sure that the new drive & Operating System are free of any virus, which results in CPU Utilization upto 100%.
- Also, motherboard supports Max 2GB RAM, so you may consider adding more RAM.
Let me know if any further clarification/ assistance is required.
Hope it helps! Good Luck!
CreativeTECH
Jan 27, 2011 | ASUS K8V-MX Motherboard
Hi, I'm having K8V-MX Asus mother board with AMD 3000+ processor wih 1GB DDR ram, with 80 GB PATA Segate HDD connected. After adding 500GB SATA HDD to this mother board, my system performance is very...
You can get free online remote Support by mailing this problem to googolplexcorporation@gmail.com .
This may be due to two problems
1. Due to Virus
2. Due to Insufficient RAM .
You can mail for free remote Support for Viruses
ASUS M2N MX SE Motherboard
Check the BIOS settings at boot up to see if you can select the primary hard drive there. Several motherboards have this option and it's buried in the boot settings. Let us know how it works out and good luck...
Jun 18, 2009 | ASUS M2N-MX Motherboard
Segate SATA HDD Cannot perform properly
Go to BIOS at machine startup. check the device, make sure hte SATA is set not at IDE.
Apr 09, 2009 | ASUS K8V-X Motherboard
Hard disk stops copying
sir,
first you scan pendrive with anti virus Soft ware why mens i think virus probalm your pendrive ok check pendrive witch company pendrive sir give me details full ok have a nice day by sir
Mar 14, 2008 | Computers & Internet
Cannot install windows xp
sounds like a bad usb device or memory. try eliminating unnecessary things.
Nov 07, 2007 | ASUS Intel 845 Chipset P4B (P4B WOA)...
Format 320 GB HDD problem
Have tou tried the mangement in windows, My computer> right click>manage, then disk management and then right click on your hard drive and then one of the options is to format. Although only 127gb will show and the rest should show as a seperate partition, do the same with this to implement it. If no other partition shows you may have to upgrade your motherboard bios to suport large capacity disks.
Apr 23, 2007 | ASUS P4PE/L (ASU49J) Motherboard
ASUS P4B-M (P4BM1400WOLTINY) Motherboard Logo
154 people viewed this question
Top ASUS Computers & Internet Experts
Alun Cox
Are you an ASUS Computer and Internet Expert? Answer questions, earn points and help others
