Question about Sony ACY-BR81/OB
Overlapping image I have a psp 2000 slim the screen started to go when i noticed a small vertical line to the left of center now the right side of the image is starting to overlap on that line shifting the image onto itself leaving the right edge grey where the image used to be. has anyone had thins problem and know how to fix or do I need to replace the screen
namzyanzy
  • 435 Answers
SOURCE: sony wega kde-61xbr950
Go to this link. This should help you resolve the issue.
Vertical lines troubleshooting
Thanks
Posted on Aug 30, 2008
  • 104 Answers
SOURCE: KV36XBR400 fragmented picture horizontal overlapping lines
this will continue to degrade, almost any failure that can be affected or temporarily cleared up by hitting the set is caused by bad solder joints.
A good shop should be able to find and fix the bad solder connections for probably a little under $100
if you bring it to them and pick it up.
Posted on Feb 12, 2009
SOURCE: green line running vertically along the edge of picture
If its a LCD projection TV (such as Sony Wega, Hitachi, Epson, Philips, and some Panasonic, some Mitsubishi), and the green image is in the whole screen or just one part as a blob or a line. Is most probably that one of your LCD Color Filters is damaged (burned out or starting to get busted), I don’t know if you can just replace the color filter, I believe you need to change the whole light engine system or the optical block. There are some places around, I found some on ebay but you should definitely try on discountdashmerchantdotcom their price range $260.00 - $330.00
Posted on Jun 25, 2009
AndystUK
  • 131 Answers
SOURCE: My Sony bravia 40
other than a software upgrade. it probably a graphics chip malfunction and will need replacement.
These can be replaced but costly. Does it do the same if you use screen as a pc monitor?
AndystUK
Posted on Aug 31, 2009
  • 453 Answers
SOURCE: I have vertical flashing thin lines of both the
u have a bad disply panel (screen) the only way to fix this problem is by replasing the all screen , this part cost about $1700 , part #9-885-059-67 or u may want to try to install the disply control panel part # 9-885-056-77 (logic board) , but this is only 50% chance , $400
Posted on Dec 02, 2010
Why comes white vertical line on my t.v?
Horizontal scan output fault. Check the connections to the deflection yoke from the main board. If you wish to get some details; check the site linked here. Pull up older posts. Surf the site with patience. http://electronicshelponline.blogspot.com/
Jan 27, 2015 | LG Televison & Video
Vertical black bar on my LG 47" LCD shifting the image to the right
Two possibilities are there. The first one is, with loose LVDS cable, that connects the T'Con board to display panel. The second is the fault with its main digital processor board.
May 21, 2013 | LG 47LC7DF 47 in. LCD HDTV
Hi, Expert: I have a 52" Sony LCD TV (
Hello
If I send you its schematic diagram and give you instructions, can you follow me?
Oct 18, 2011 | Televison & Video
My PSP has a grey line in the right side. Once my PSP turns off, It also disappears but in a delayed time like 2 seconds.
screen is damaged, you can replace the screen for like 30$ and you can find them on Ebay or Amazon,
and then google how to replace a psp screen, it takes time and eaze but its pretty ez.
plz understand you must put the psp back togehter properly or else it wont go back together
Dec 30, 2009 | Sony PlayStation Portable (PSP) Slim...
How do u use play station network on a psp?
You need to have quite new firmware, and if you do, it is on the far right of the start-up menu. You can update your firmware on the far left of your screen! Good Luck!
Nov 10, 2009 | Sony PlayStation Portable (PSP) Slim...
Samsung HCN4727W Rear Projection TV, green screen, audio works
These sets need to have all three colors - RED - BLUE - GREEN - lined up correctly on the screen in order for the picture to look normal. This is called convergence.
When its out of alignment the video will look 3-D, wavy, distorted, etc. Most of the time you just need to adjust your convergence in the menu. If you cannot adjust it in the menu - then your convergence is broken and needs to be repaired. Convergence problems are very common on all Projection TV sets including Sony, Samsung,JVC,Philip Magnavox,Panasonic,Akai2_bing.gif,Pioneer, Hitachi,Mitsubishi,Zenith and others.
You can get more information and a DIY convergenece repair kit with instructions from the link below.
Here are some of the most common problems with these sets...
Problem #1) Convergence
Yours may have one or more of the following symptoms...
*Screen Looks 3-D
*Colors wont align
*Screen may look distorted or warped
*No Audio/Video - TV Shuts down - May also make a constant chirping sound
Problem #2 - Another common problem is dull or washed out video.
Your set may have one or more of the following symptoms....
*Dull looking picture
*White looking picture
*Halos around objects
*Red/Orange looking picture
bb0cf99.pngYou can see some more examples and find a fix using this link on Fixya http://www.fixya.com/support/r2861467-solution_video_looking_whiteish_dull
Jul 10, 2009 | Samsung HL-R4667W Rear Projection...
Thin vertical line on screen shows what another part of screen is
Ah, the "line of death."
There sure is & best of all, it's FREE. You will need a piece of tin foil rolled up to a pencil's thickness. You will also need some patience to watch THIS video, which shows you the placement for the tin foil. As pointed out in the video, you only need to remove the face plate & NOT all of the buttons, D-pad.
Apr 08, 2009 | Sony PlayStation Portable (PSP) Slim...
PSP Slim making click sounds when UMD is in
it could be a problem with the inside mechanisms of the UMD dock. Better make sure that the insides are clean and free of dirt or small particles.
Feb 08, 2009 | Sony PlayStation Portable (PSP) Slim...
Vertical colored lines on left half of screen.
I had a similar issue. Took it in and apparently i had 4 bad capacitors and after replacing those, my tv was perfect. But I think I lucked out on this one. :) try it.
Nov 02, 2008 | Televison & Video
Computers & Internet Logo
46 people viewed this question
Top Sony Computers & Internet Experts
Alun Cox
Computer Links
Are you a Sony Computer and Internet Expert? Answer questions, earn points and help others
