Question about Husqvarna 23 Hp 48" Deck Yard Tractor
Husqvarna ich 160 drive belt lack of drive
Hi doe's anyone have a diagram of the driving belt pulley system.
  • Sean C May 11, 2010
    I need the model# of your tractor
  • 405 Answers
Try this site. :) Merry Christmas! hope this helps.
Posted on Dec 23, 2008
I have a 52" Husqvarna LGT 2654 riding lawn mower and when I engage the blades, the belt does not turn the pulley system. What could be causing this, the pulley idlers, or the belt?
depending on the age of the machine, there could be several possibilities
1-- belts are not tight enough--- belt tension system is not correct, wrong length belts
2--bearings for the shafts for the blades are rusted up and seized - preventing the blades from moving--- switch the machine off , disengage the belt drive and see if you can turn the blades by hand
3--- if you have an electric pto system to drive the belts to the blades then that system is not getting full power to engage the PTO or the clutch is not working--worn facings
take it to a service dealer and have a proper diagnosis done
May 09, 2016 | Husqvarna Garden
Drive belt routing
Parts and Diagrams for Husqvarna LT 18542 954571748 2003 11
OH BOY, lots of information. one belt runs the DRIVE LINE. one belt will run the CUTTING DECK. check out the link.Hope this helps :)
Apr 12, 2014 | Craftsman 42 in. Deck 19.5hp Lawn Tractor
Husqvarna power belt loose how to tighten
Parts and Diagrams for Husqvarna 2042 LS 96043006200 2008 11 This link will provide diagrams of the drive belt and associated parts. The diagram shows the idler pulleys and tension springs. Inspect your mower to compare all drive parts to the diagram. Hope this helps....
Mar 23, 2014 | Husqvarna Garden
Diagram for 5 pulley belt 98 pontiac transport.
start from bottom crankshaft pulley and ac compressor turn belt tensioner counterclockwise or lift forward then run pulley belt around crankshaft pulley and around AC compressor,run pulley belt around power steering pump then around alternator,once drive belt around alternator you done make sure drive is center of crankshaft pulley and AC compressor pulley.and belt back is center against water pump pulley before releasing the belt tensioner.
Aug 27, 2012 | Pontiac Trans Sport Cars & Trucks
Diagram for drive belt pulleys for cub cadet 1045
Round the two outer pulleys on the deck. Round the the outer pulley in middle deck, round idle pulley inside, next pulley in center of deck to drive pulley
May 03, 2012 | Garden
The drive belt on my husqvarna yth20k46 is off at the pulley above the transmission. How do I get it back on? Do I have to remove the nut at the transmission shaft?
I would remove the nut and pulley. Get belt top of pulley. Start the edge of belt in broove on pully and run it around. You get easyer belt in pulley and install it. May have pull little against spring.
Mar 31, 2012 | Husqvarna Riding Lawn Mower 42 Inch Cut...
Need belt diagram on husqvarna lgt2654
Here is your manual. Please see Figure 5 on Page 7 for the deck belt routing. Other useful diagrams and pictures are in this manual as well.
http://weborder.husqvarna.com/order_static/doc/HOUS/HOUS2006/HOUS2006_O0602065.pdf
May 02, 2011 | Husqvarna Lawn Tractor - 54in. Deck, 26...
Drive (motion) belt has come off the rear pulley twice in a month
husqvarna yth20k46
drive belt came off
fix
transmission boltes were not installed
replaced fix problem
Jul 16, 2010 | Husqvarna 23 Hp 48" Deck Yard Tractor
Belt diagram
The deck drive belt makes an L shape looping to the the outside deck pulley that has 2 pulleys. The deck drive belt rides on the top set. X = pulley engine x
l l
l l
l l -
l l x x = outside deck pulley
back deck pulley =x
motor to idle to outside
motor to tension to outside back side of belt goes around idler
This is the most common belt to replace
idle pulley (x)
lx tension pulley
/ l_______
the deck running belt left deck (X ________________ ____ x)
Apr 29, 2009 | Husqvarna Lawn Tractor 48" Deck, 23 Hp,...
Husqvarna 23 Hp 48" Deck Yard Tractor Logo
570 people viewed this question
Top Husqvarna Garden Experts
Phil Walker
Phil Walker
Roland W VanLue
Roland W VanLue
Are you a Husqvarna Garden Expert? Answer questions, earn points and help others
