Question about Troy Bilt 5.5hp Self Propelled Mower
My lawn mower doesn't start
My 7-year old VICTA 2-stroke lawn mower doesn't start. I cleaned the air filter, no luck, cleaned the plug, no luck, changed the plug, still does not start. Checked the
spark plug and it was soaked with petrol. Cleaned the new plug, and it still does not start.
When I pull the cord, it sounds like it wants to start but it just will not start up. Please note: I have not been using it for long time since it stopped working a while back. I now want to see whether I can get it working again.
Any one can shed some light on this?
  • 1 more comment
  • alfixya Dec 22, 2008
    This is quite technical... are you saying I remove the plug, with the wiring intact, then pull the cord to start the mower, in order to see whether there's spark on the plug ? Also, do I need to adjust the gap of the new plug ?
  • genelb Jan 19, 2009
    I have a Troy Bilt 6.75hp mower I have put new gas in it and a new air filter.I have also put in a new spark plug. When I pull the cord the mower sounds like it wants to start and smoke come out of the muffler. It will starin for 15-20 secinds and die never getting to full speed. I removed the spark plug and it was soak with gas.
  • Anonymous Mar 17, 2014
    starts when cold when I empty bag it will not start again, replaced coil, plug, cleaned carb, could it be carboureter fault?
  • 211 Answers
Hi Every 2 stoke engine needs three things to run:Fuel+oil/air mixture in correct proportions,compression and ignition.Remove the sparkplug and see if the spark appears when the piston in the cilinder is at top death point(almoust),if not check the flyweel key(not to be sheared).Check engine"s sealing(crankcase gasket,cilinder gasket,seals-crankshaft,carb gasket).Also the mufller(not to be clogged),disassembly the carb (check and clean it),fuel lines and fuel filter (check and clean them),gas cap tank vent(not to be clogged),the air filter.Please let me know. best regards savumihai71
Posted on Dec 22, 2008
  • Savu Mihai Dec 22, 2008
    Hi
    A new sparkplug does not need to adjust the gap.Just buy the correct sparkplug(the same or echivalent as the old one).Now priming the engine(put some gas in the sparkplug hole,back the sparkplug and start the engine to see what is happening.Let me know.
    cheers savumihai71
2 Suggested Answers
hunter19_46m
  • 7482 Answers
SOURCE: I've inherited an older Victa 2 stroke 80 mower.
Hi anastasialou...
Sounds like you have dirt/debris in your carburetor jets,fuel passages or a diaphgram that is becoming non-flexible.
Be sure to check your fuel tank for water and dirt/debris, if there is water/debris then you need to clean your tank.
Also check you fuel line condition after a while they will degrade and need replacment.
Make sure you are getting spark at the spark plug, to do this:
Remove your spark plug and check to be sure you are getting fire at the spark plug.
You do this by grounding the plug on the head of the engine and pulling the crank rope, if you are getting spark then:
Check/Clean/Replace your fuel filter if you have one, normally they are located in the fuel tank of weedeaters.
When you remove your fuel lines from the carburetor be sure to make a drawing to how the lines are connected to the carburetor.
Normally the big line will be the line the fuel filter is connected to inside of the tank.The smaller of the two lines is the return to the fuel tank from the carburetor after it is pumped thru the carburetor by the primer bulb.
Also make sure you are using fresh fuel...and oil mix if your using a two cycle mower or weedeater with the oil to the right mixture and not too much oil as it can cause hard starting.
If the mower/weedeater is over a couple of years old, then I recommend that you buy and install a new carburetor repair kit,because the diaphragm will get hard and that will cause it to be hard to crank.
Sounds like you will need to clean the carburetor or replace your carburetor internal rubber parts like the diaphgram and O rings.
I recommend that you use a laquer thinner type cleaner to clean and dissolve the laquer build-up in the float and needle jet passages.
Be sure to remove all plastic and rubber parts before using the laquer thinner because it can dissolve the plastic parts and render them unuseable.
Be sure to use compressed air to blow out all the fuel and air passages.
Be careful when blowing out the passages, because there are sometimes small rubber type seats in the bottom of some of the passages.
Sometimes you can get by with priming the carburetor or using starting fluid and letting it run a few times like that and it will flush the gunk out of the jets,but most of the time you will need to rebuild the carburetor.
Keep in mind that the float (if you have one) for the carburetor must be level when you go to reassemble the carburetor or follow the instructions you get with the carburetor kit.
When you clean your carburetor and remove the jet screws, you will first need to lightly seat the jet screws.
But before you lightly seat the jet screws count the number of turns it takes to seat the jet screws from their original position.
Be sure to mark the turns down on a piece of paper.
That way when you put the jets back in, you know to lightly seat them first and then turn them back out to their orginal position before you started.
Once you have your carburetor rebuilt that should solve your problem.
This is a FREE answer,Please take time to rate me
Posted on Jun 19, 2011
Engine starts. Why does it only run a few minutes, then stop?
a few things may cause this. it sounds like it is starving for fuel. the spark plug may be breaking down when it gets hot. try a new spark plug. if the fuel and fuel lines are in bad shape, old, soft or hard. the fuel don't smell right. fuel filter plugged up. the carburetor may need to be cleaned and a rebuild kit as they are cheap. if it is 30 years old. be sure the fuel lines, filter and carburetor are in good shape. hope this gives you an idea on where to start. good luck
Mar 14, 2016 | Garden
Victa2stroke cuts out after about 4 minutes of cutting grass
check the carb is clean and the spark plug is in good condition, also the air filters block up quite easily on those so remove it and blow it out. of course being a 2 stroke it could be that the piston /rings are scored up but you would need to remove the exhaust to inspect.
Feb 26, 2015 | Garden
Victa v160 runs for a while then stops
Ignition module is failing
Oct 14, 2012 | Garden
Have a 4.0 quattro Briggs and Stratton lawn mower. Starts up great and doesn't stall out. Has this annoying surge and slow down of motor. Removed gas from tank and sprayed some gum remover in tank and...
it does sound like a carb issue it may need to be rebuilt also check your fuel line and if you have a fuel filter check the filter clean the gov. assembly with carb cleaner
Jul 30, 2012 | Garden
How to fix a 3.5 lawn mower?
HELLO,
You can fix these yourself, all you have to do is to follow the instructions below,
1 Remove the spark plug lead from the spark plug and move away from cylinder head. Always do this before attempting any repairs to a lawnmower.
2 If your lawnmower is a "four stroke" mower (separate gasoline and oil), tip the mower so that the spark plug is pointing skyward. Never tip it on its side with the spark plug to the ground.
3 If your lawnmower is "2 stroke" (oil and gasoline mixed) turn off fuel tap. You can tip a two stroke mower any way that is suitable to you.
4 To change a blade, or blade disc, it is often easier to remove the spark plug and feed a length of string into the cylinder head to 'lock' the piston while trying to un-do the blade bolt(s).
5 Check the motor's "air filter" while doing this sort of maintenance as a dirty or clogged air filter will affect engine performance and increase fuel consumption of your mower. Symptoms of a clogged air filter include inability to start, starting and quickly stopping after several sputters, or a weak idle. You may also see oily or smoky exhaust.
6 If your mower is a "four stroke" model, change the oil at least once a year. When it is tipped over with the spark plug in the air, is a good time to remove the "oil fill" plug and drain oil into an old ice-cream container for recycling.
I hope this will help to solve the problem.....
May 31, 2011 | Craftsman Garden
Mower is old and not run for ages. now i can get it to start, but it cuts out after reaching top revs (about 2 secs0 victa panther 4 stroke
remove carb and clean it out. it may have dirt and grime in it. if need be clean fuel tank and put in new fuel, also check condition of air filter then you should be fine. have a good day !!
Mar 12, 2011 | Hammering
I have a Victa tornado 2 stroke lawn mower a VSX160 that would not start. i have replaced the spark plug and it is still not starting. I have been told to check the air filter but for the life of me i can...
Hi Mary, the air filter is on the carburator.There is a cover over it that just snaps off or is held on by a couple of screws. The carburator is where you can adjust for low or high speed with a lever or have a cable going to it to adjust the speed. It might also have a primer on it. That is the carburator. Remove the air filter take a look at it for dirt, grass clippings, etc. especially in the bends, clean it as best you can with air or tapping it on the ground. After doing that see how much is left on it. Air has to go through it so decide if you should replace it, they are not very expensive so I would buy a new one. Hope that helps you out. Best regards and good luck.
Jan 09, 2011 | Garden
Victa 2 stroke mower will not start
It may have a blown crankcase seal. How did you check the plug for spark?
you can remove the carbi and spray 2 stroke fuel directly into the chamber and try to start it.
If it starts you have a problem with the carbi or the fuel supply.
Take out the air filter as it may be blocked and restricting the air supply.
The float in the carbi may be full of fuel due to a hole in it or the fine fuel filter in the carbi may be blocked
Apr 04, 2009 | Garden
Masport Lawnmower won't start
you likley will need a new air filter and a carb cleaning. when mowers are turned on their side. oil will seep past the piston and if your intake valve was open it can pass thru into the carb and also spoil your air filter. I am assumeing you have a paper air filter. start by taking off your air filter. then you should also pull the spark plug, place a rag covering the hole. then pull the cord a couple times. chances are that you will blow the oil out of the cylinder.
Mar 31, 2009 | Garden
Lawn mower does not start up
Lots of thing can stop a victa working!!!!!!!!!. Ok your plug is wet. Turn the fuel off. R&R tank renew fuel(no more than a month old it goes stale)Check for spark, be very careful it could catch a light.
Get the new plug open the gap to about 5mm.earth the hex of the plug to the head, away from the plug hole ,the fuel will come out.
If it jumps gap when pulled it has enough spark to fire under load.If lots of fuel comes out its flooded.if so leave plug out remove a/f ,leave tap off, put throttle to full and pull till most fuel is gone.Refit plug and try. let me know how that goes. do this in well vented area. Fumes can build up in shed.
Dec 22, 2008 | Garden
Troy Bilt 5.5hp Self Propelled Mower Logo
2,720 people viewed this question
Top Troy Garden Experts
Jim Parker
Jim Parker
Matt Olenzek
Matt Olenzek
DROPNDEAL
DROPNDEAL
Are you a Troy Garden Expert? Answer questions, earn points and help others
