Question about Dell Inspiron 1501 Notebook
How do you use the question mark
3 things on the same button back slash and plus sigh and question mark
  • Dell Master
  • 998 Answers
The numeric keypad functions like the numeric keypad on an external keyboard. Each key on the keypad has multiple functions. The keypad numbers and symbols are marked in blue on the right of the keypad keys. To type a number or symbol, press <Fn> and the desired key after enabling the keypad.
Your responses are intended to improve the level of service provided. Please show your appreciation by rating your experience.
Posted on Dec 22, 2008
Question mark key and slash plus 2 keys above it have turned to eee with accent above - I suggest you check out this article - or you can google yourself - How do I change my Keyboard Mapping? and then see what comes up.
I would appear that you have somehow setup something on those keys - e with an accent above is most likely French
May 28, 2016 | Logitech Computers & Internet
How do I get the question mark punctuation to work...
When you were typing something you probably hit the left shift key along with ctrl. Hold down the left shift and ctrl for about 2-4 seconds and you should get your question mark back.
To make it so it never happens again, go to control panel / region and language / keyboards and languages / change keyboards. Remove every language except for English (us) or whatever region you want to use. Before you accept verify that your keyboard is on your preferred language before you do this. check and make sure you are getting the proper slash when you push slash, to change it if you're not getting the slash use the (left ctrl + left shift for 3-4 seconds) if that doesn't work then try alt and left shift.
Sep 13, 2014 | Lenovo Keyboard
What button displays a back slash
No button does that, nor a CATALOG command. But do check in the CATALOG (2nd 0).
May 10, 2014 | Texas Instruments TI-84 Plus Calculator
Get Ee when trying to type foreward slash
Blue functions are common now but usually only on laptops. They are accessed via a blue button normally labelled Fn down in the left corner near CTRL and SHIFT. Hold the Fn button and press the desired button to acheive the function.
Jul 01, 2013 | Computers & Internet
How to delete answer machine calls
While listening to the message, press the delete button (just above the message number, marked with a circle with a slash through it).
Apr 06, 2012 | Uniden DECT 6.0 Cordless Phone ID
I have and old Peavey Mark IV bass head. I want to know if it is possible to remove the crazy 8 or 10 pin footswitch input and replace it w/ a 1/4 in plug. There is only two wires running to this craz
2 wires plus ground needs a stereo 1/4 plug. Don't know Mark 4, but Mark 3 has 2 button fs with 3 wires plus ground. Schematic here:
shows 3 wires plus ground. Stereo plug does not have enough connections, only ground plus 2 wires.
Count the pins of socket and find DIN plug with proper pin-out for socket. Search google for DIN plugs.
May 02, 2017 | Music
Iam trying to get the black slash and question mark what keys do i use to get them
Depending on setting, assuming that the keyboard is set to United States, the ? and / key are next to the shift key on the right side, bottom row. For a question mark hold down the shift key.
I hope this is helpfull
Jul 27, 2011 | Computers & Internet
How can I turn off auto flash in my canon sd 600 camera?
Press the flash button (right-arrow on the control panel, marked with a lightning bolt) repeatedly to cycle through the flash settings. To turn the flash off, select Off, marked by a lightning bolt in a circle with a slash through it.
Don't forget to turn it back on when you're done.
Jun 22, 2010 | Canon PowerShot SD600 Digital Camera
I want to use the forward slash or the question mark but cant seem to figure out how.when i press the button it does this é or if I press Fn and that button it does this + .
Try checking the language settings in the keyboard settings?
sometimes if its set to U.S or another language some of the keys may do different things
Apr 09, 2010 | Acer NSK8458AN Keyboard
Excel lookup - match index array
The best solution may be to re-define the named columns, or to add new names to multi-column arrays, then use the VLOOKUP function.
Note that the "indexed" named cells must be sorted by the index column.
Test (this is a 2 year old question)... Please ignore ths following. The plus symbol does not display.
Upper key plus symbol displays:
Right plus symbol on number pad displays:
[Shift] Right plus symbol on number pad displays:
[Alt] [4] [3] displays:
slash/slash/plus displays: //
slash/plus/slash displays: / /
Plus Plus Plus displays:
upper Plus Plus Plus displays:
Shift Right plus plus plus displays:
end of plus test.. thanks.
Dec 09, 2008 | Microsoft Excel for PC
Dell Inspiron 1501 Notebook Logo
274 people viewed this question
Alun Cox
