Sony Alpha 100 gives error message when attempting to take pic.
Hi! I just had the same problem with my Sony A100, when I tried two different CF cards. I was getting the same error message as reported above: "Unable to use card" then "Format?" then that format fails. Thinking the camera
is broken, I checked online camera repair sites and also called Sony
directly. Sony's flat rate, and that of PrecisionCamera is $228 to fix
CF card failure. Then my daughter said, "the CF card in my room works
fine in the camera" - and lo and behold - it does. The CF card that
works is brand PQI and is marked Hi-Speed 60 2Gb. The cards that do NOT
work are marked SanDisk Ultra II 1.0Gb and SanDisk 128 Mb. So my advice
is, before you give up on the camera as broken, try a number of
different CF cards first.
The second cause of CF failure is if
someone has pushed a CF card in the wrong way. That can bend one or
more of the tiny metal contact pins in the CF socket in the camera.
Look carefully to see that all the pins are straight up. [I don't know
how one can straighten these pins, or if the whole socket would need to
be replaced...but at least you can determine the cause of the CF
failure.]
Best regards - Michael
