Question about Sony Playstation 3 (PS3) Console
Hd tv as no hdmi plug
My hd tv as no plug in area like the hdmi cable for ps3 needs i only have like the red, green and other color plug in like a av cable,i do not have a usb slot like the hdmi and i can't seem to find one with my plug in slots
There are PS3-components cables available out there (the Red/Green/Blue one) you can use to connect your PS3 to your TV and still get HDTV on your TV system. You should be able to get it where you bought your Playstation. Got one for 39.99$ CAN
Cheers
Posted on Dec 22, 2008
Trying to hook up av combo cable to an emerson tv for a ps3 and xbox using components not hdmi red white yellow blue green red
What do you need? what they are? Yellow is video, red is right audio, white is left side audio. the others are for HD. Good luck. ^^
Mar 29, 2013 | Video Game Consoles & Games
Hooked up hd cable to ps3 and tv, now have no sound
Be sure to check the cables. You may need to replace them.
Try the cables with another component, if possible.
Also, try using AV cables to verify that it is not the TV and to simply troubleshoot:
To get back to default AV settings:
Press and hold the power button until the systems shuts off. (wait 2 seconds)
Press and hold the power button again until it shuts off again.
Once you have verified that AV is working, turn off console, take out AV cables.
Plug in HDMI cable and turn system back on. Switch TV input to HDMI and it will ask you if you would like to use the HDMI cables, select yes again and verify.
If you cannot get sound, again, check the cables..
If new cables do not work, then your HDMI output is going bad, not from use rather normal wear and tear of the motherboard.
To get the best non HD picture, you will need to get some 'component' cables, rather than the standard AV (red, white, yellow).
Good luck
Jan 27, 2011 | Sony Playstation 3 (PS3) Console
How do you hook up a playstation to my vizio tv
depending on the age of your play station you may or may not have an hdmi output on the playstation. if youi do then its simple. one hdmi cable from the tv to the playstation and yoiur done. if not, you should have some round color coded plugs on the back of the tv and the same ones at the playstation. they should be just larger than a pencil eraser. these are called RCA plugs or phono plugs. the cables will have the opposite end with pin sticking out. you can go to google images and type rca plug to see a picture.
Dec 24, 2010 | LG 42LC2D 42 in. LCD HDTV
Connected to a sat. we have no sound when we put the T.V. to H.D
What cabling are you using? component? (blue red and green) or HDMI? if you are using component then make sure you also plug the red and white RCA cables in the "audio in" inputs. People commonly think that the component cables do it all but they only carry a video signal. If you are running HDMI through an AV reciever you may need to run an optical cable as well as most AV recievers (unless you buy top of the range) can only switch HDMI video but not sound.
Jul 05, 2009 | Televison & Video
My ps3 has no picture or sound...
if there's absolutely nothing on the TV screen, then most probably the video output is different then the cables you are using (eg: video output HD and you are using AV cables). Are you sure your TV is set correctly? like using HD cable you have to choose HDMI or AV cable choose AV. Anyway, When the PS3 is on, turn it off by pressing and holding the power button on the front (so the light turns red) you will hear beep sound ( I can't remember how many but not once). This should reset the Video output to AV. Swithch to AV cables (if you're using HD). Usually if the system is set to AV output and you switch to HDMI cables, the system recognizes that and swithches to HD output. But if it's set to HD output and you are using AV cables, it doesn't switch back; that is what my system does.
Jan 22, 2009 | Sony Playstation 3 (PS3) Console
Connecting ps3 to cinema system
There is no substitute for HDMI. However, the 'digital in' cable connection that you want to use is still digital and will sound almost exactly the same. The differences are barely noticeable to the human ear. Here is a list for you to see the pecking order of each type of connection.
Audio connections from best to least go in this order:
1. HDMI (digital)
2. Fiber optic (digital)
3. Coax - Digital (digital) <--- The one you want to use.
4. Component (analog)
5. RCA/AV (analog)
Video connections from best to least go in this order:
1. HDMI (full HD digital)
2. Component (Blue, green, red, white, red - HD analog)
3. S-Video
4. RCA/AV (Yellow, white, red)
Good luck!!
Sep 28, 2008 | Sony Playstation 3 (PS3) Console
Full HD picture NO SOUND from ps3 to lg42hd using HDMI
Maybe your TV is not made for HD from the Sony Console. Try calling Sony Customer support, then your TV's brand Customer support. That will tell you if your TV Model allows the HD from the PS3. Remember though, PS3 Uses Blu-Ray. So you need Blu-Ray for your TV. Hope this helped.
Jul 11, 2008 | Sony Playstation 3 (PS3) Console
Sony Playstation 3 (PS3) Console Logo
85 people viewed this question
Top Sony Video Game Consoles & Games Experts
shaun taylor
juanmireles1
Damen Wong
Damen Wong
Are you a Sony Video Game Console and Game Expert? Answer questions, earn points and help others
