Question about NEC LCD
On screen thin yellow and blue vertical lines.
Whilst upgrading security software, my other half's notebook screen developed a thin vertical blue line and then a few weeks later another thin vertical yellow line. Is this a possible software fault on the part of the security software provider? I wouldn't have believed it if I hadn't seen the second yellow line appear from nowhere!!
  • riverdaught Jan 29, 2009
    A thin blue line suddenly showed up on my monitor. It's always there on the left side of the screen.
  • NEC Master
  • 12,061 Answers
Unfortunately the LCD is going faulty.. one or more of the "Driver" transistors that operates the LCD elements RGB, have faulted ON.. perhaps this link may help fix it. Otherwise :( http://www.wikihow.com/Fix-a-Stuck-Pixel-on-an-LCD-Monitor
Posted on Aug 01, 2007
SOURCE:
Horizontal Band of Thin Red and Blue Lines on Screen
Sound like your Y-Sustain board has one foot in the grave. The Y upper buffer and Y lower buffer boards go when the Y Sus Goes too...
Mar 22, 2014 | Panasonic TCP46C2 46 in Plasma TV
Thin vertical blue ink bleed line from bottom of Malaprop screen - Fades over time
Yes, it's a screen problem. It could be a loose connection of the LCD and the motherboard or the lid lights gone bad. You can fix that by either resetting the connection of the screen and the motherboard or replacing the whole screen. You would need a technician to do that.
David
May 27, 2013 | HP Pavilion Computers & Internet
Thin vertical yellow line and a white vertical line appeared on ibm thinkcenter r52
What is happening to your laptop is the power line connecting a row of pixels is failing so only partial colors are showing up causing the vertical lines. Usually screen replacement is the only answer to fix it. You can usually find replacement LCD on Ebay.
Jan 10, 2011 | IBM ThinkPad R52 Notebook
Two thin lines (vertical) one blue one yellow permenantly on screen.
Try to check first if the video card cause these lines..
Turn off your computer, replace the video card and check if the lines still display..
If you still see lines, check the cable connected on your monitor to the video card, see if its properly secure and not loose.
If you still see it... then my suggestion is you bring your monitor to a credible technician..see also if your monitor still have its warranty
May 26, 2010 | Apple iMac Flat Panel Fan (p/n 922-4677)
Vertical lines appear permanently on the screen
your display is going out you can contact Dell for a replacement.
Nov 01, 2009 | Dell Inspiron 2200 Notebook
My Sony bravia 40" LCD has developed a thin vertical line to the left center of screen. how to fix?
other than a software upgrade. it probably a graphics chip malfunction and will need replacement.
These can be replaced but costly. Does it do the same if you use screen as a pc monitor?
AndystUK
Aug 31, 2009 | Sony BRAVIA KDL-40S2000 40 in. LCD HDTV
Left Half of the screen is not working
you have a problem with your "buffer" boards inside your tv. there are several different ( 4 or 5
) ones inside. it may also be your controller board, only a tv service technician will be able to answer this question after a look see
Jan 22, 2009 | LG DU-42PY10 42 in. Plasma HDTV
Thin blue line
Hi!
This is a phisical hardware problem with the screen.
If the system is under warranty better take back so your vendor replace the screen.
I think is the only solution.
This is a progressive problem, day a day you will be seen more and more lines until the screen become death.
Jan 19, 2009 | HP Pavilion dv8000t Notebook
Vertical lines in my laptop screen
Try connecting an external monitor to the Dell Inspiron 9300 and see if the vertical line is also present on the monitor. If the monitor display is fine, then your laptop’s LCD display panel is defective. If the monitor also displays the vertical line, then your problem is with either the video card or motherboard located inside your laptop.
Not sure if the Compaq Presario has an external monitor plug, but if it does the above procedure can be applied to that one as well.
Your responses are intended to improve the level of service provided. Please rate your experience.
Thank You.
Oct 19, 2008 | Dell Inspiron 9300 Notebook
Vertical line on LCD screen
hi unfortunately you'll have to replace the lcd display
Aug 09, 2007 | HP Compaq nc6000 Notebook
NEC LCD Logo
837 people viewed this question
Top NEC Computers & Internet Experts
Steven Wander
Steven Wander
Thomas F. Schneider
Alun Cox
Are you a NEC Computer and Internet Expert? Answer questions, earn points and help others
