Question about Dryers
I have a broken blower blade I want to remove from Kenmore dryer.
I have a Kenmore 600 electric dryer. The blower blade is broken. I would like to remove it from it's housing if possible. It is larger than the opening. I have not yet detached it from the motor. There are 3-4 nuts attaching the housing to the frame, but how can you access them with the blade on?
  • 61 Answers
You cannot remove the blower intact with the motor. The motor has to be accessed from the front the motor shaft has to be held still with vise grips and then the blower has to be twisted off. This repair is trickey and should be done by a service tech.
Posted on Dec 22, 2008
Have a kenmore electic dryer just changed out the heating element about 2 months ago dryer is not heating up properly taking 2 times to dry a load of clothes
check for a blockage in the evacuation hose (four inch tubing)
also, check to make sure the blower blades are turning (they can wear out and slip on the motor shaft). assuming the new element is still good, it is probably a blocking of air flow which will inhibit drying properly. or the blower fan blades are broken or worn. good luck. jay
Jan 04, 2010 | Kenmore Dryers
Uncontrolable shaking and noise, Kenmore 600 electric dryer. the thing is shaking like crazy! im scared to use it.
check the blower wheel,if that comes loose the wheel will cause the problems you are discribing
Nov 08, 2009 | Kenmore 600 7962 Dryer
Heating element and blower work but clothes still damp
Sounds like it's operating on only one leg of the 220v. Reset breaker and try. I think you will find that this is all thats wrong.
Please rate solution
Aug 27, 2009 | Kenmore 600 6963 Electric Dryer
Dryer is hot, clothes arnt getting dry. blower? less that 1 year old Kenmore
Remove the vent hose from the dryer and dry a load of clothes . If they dry , then dryer is pushed too far back , kinking vent hose , or the vent from the dryer to the outside is blocked somewhere . A dryer either heats or doesn't heat (except for maytag associated dryers ) in which the blower wheel could be stripped out . But Kenmores don't have blower problems .
Aug 09, 2009 | Kenmore 600 7965 Dryer
Trying to access the blower fan on a Kenmore 80
Remove the rear panel.
Then remove the screws that secure the blower fan vent on the left side to access the blower wheel.
Mar 08, 2009 | Whirlpool LER4634J Electric Dryer
Remove blower wheel
Put a good fittting wrench on the blower nut and hit it with an impact wrench(left handed threads righty lucy). OR do it the tried and true redneck way get a friend to hold a pipe wrench on the pulley inside the dryer, around the back slide a small hammer handle or piece of wood in between two blower blades at 3 o'clock position and slam downwards to pop that mutha loose. The threads are left handed(backwards). That blower does not wanna go easy.
If you need further help, reach me via phone at https://www.6ya.com/expert/dan_73bbd84fe1d95b61
Feb 17, 2009 | Kenmore 63942 Dryer
Whirlpool Electric Dryer Model GEQ9800PW1 - No Heat
Well your high limit is blown. It mounts up top of the heat element chamber.
Jan 31, 2009 | Kenmore 62602 Electric Dryer
Kenmore 64942300 Electric Dryer runs, no heat
This may seem too simple of an answer based on your extensive troubleshooting thus far, but the most common reason for cold air running of any electric dryer is a broken heater coil. This is simply a coil of wire that is heated to warm the air in the fan duct. These often overheat and break if the vent duct is blocked, too long, or has odd bends that can restrict flow. Recommend replacing heater coil and use smooth wall vent pipe. Avoid coil type flexible duct.
Jul 03, 2017 | Kenmore 64942 Electric Dryer
Kenmore blower wheel
hi is the blower broken that would be the only reason to replace the blower or is the dryer noisy if its noisy and not the blower the drum repair kit is available you get 2 drum rollers 1 idler pulley and a new belt the appliance doc
Sep 02, 2008 | Kenmore 63012 Electric Dryer
Kenmore Ultra Care Electric Dryer
You have to go in the back.. take loose the blower cover and pencil is probly in parts after hitting blower fan.. check fan for broken blades ect.
Sep 17, 2007 | Kenmore 659 Electric Dryer
Dryers Logo
73 people viewed this question
Top Dryers Experts
Marvin
Marvin
