Question about Cuisinart Brew Central 12-cup Coffee Maker
What is the water filter for. and where could I purchase such
Small coffee filters. I need instructions
  • 8,596 Answers
The charcoal water filters improve the taste of the coffee, although they are definitely optional. You can get replacement filters at Bed, Bath & Beyond; Williams-Sonoma; and sometimes Lowe's.
Posted on Feb 15, 2009
I have a model K40 (the fifth Keurig I have purchased). This one now barely drips water, takes forever to make about a third of a cup of coffee
There are instructions on youtube for the proper procedures to clean a Keurig. If you ever ran anything but clean water through the coffee maker, like reheating a cup of coffee the grinds in the bottom of the cup clog the system. Watch the video it is usually done with a small paper clip.and vinegar
Aug 30, 2014 | Keurig Elite K40 Black Coffee Maker 1 Cup
I just broke the glass carafe for my Toastmaster Espresso Coffee Maker, Model TEM4022C. Do you know where I can purchase a replacement carafe? Also, I need an instruction pamphlet for the same coffee...
Carafes are available at hardware stores and cook's supply stores. To get you by till then (providing your coffee maker doesn't have a 'sneak-a-brew' stopper at the bottom of the filter cone) you can use a small saucepan and reduce the recipe, (water and coffee).
Mar 29, 2011 | Toastmaster TCM10 Coffee Maker
My tassimo brewer is by Bosch and it has a filter with it, will I still need to descale also?
definately, follow the mfg suggested cleaning in you booklet. the filter will not filter out hard water particles.
Oct 04, 2009 | Braun Tassimo Coffee Maker
Water leaking
The silicon seal inside the coffee maker tends to disintergrate. Bunn Inc. does not sell parts for the inside of the coffee makers, but a seal kit can be purchased through a small appliance repair center or repaired for a small cost. Kit is about $8.00 at most places.
Oct 24, 2008 | Bunn Cuisinart Coffeemaker: Pour-Omatic...
Where do I purchase replacement charcoal water filters for my coffee maker?
Cuisinart DGB-600 replacement charcoal water filters is Cuisinart DCC-RWF 6 pack charcoal water filters, 12 filters.
Oct 17, 2008 | Cuisinart DGB-600 Coffee Maker
Coffee is weak / Is pump supposed to kick on and off during brewing or run steady
On percolated (filter) coffee machines:
Check water temp, if water temp is insufficient , most common is scale heating element , faulty element, faulty thermostat.
Check if water is dripping right at the center of the filter, if it is dripping on one side because the orifice is clogged, that can result in weak coffee.
Coffee blend not well distributed on filter basket.
On Espresso machines:
Check water temp, same as filter coffee machines (thermostat element, scale on heating chamber).
Ensure that coffee is filled correctly in the filter cup (fill at level), and well pressed.
Ensure that the coffee mixture that you are using is not too coarse, buy the apposite one for espresso.
Ensure that you are not leaving the machine brewing for a time that is too long, and Italian coffee cup is very small, approximately one regular shot.
On the hob moka pots (espresso, Moka and Bialetti type):
This are the trickiest ones, you need art and practice to get a good espresso with a Moka, but when you learn, the result is better than what you may get with an home electrical espresso maker.
The frame on the hob must be not too strong, and the mixture coarse but well pressed, with water at level tag, or you will get a weak coffee.
On Mokas a good strategy is keeping hob at minimum, and turning up the flame at top when coffee starts coming out.
Note: insufficient pressure and clogged lines on electric machines never give you a weak coffee, exactly the opposite.
Not pressed mixture always gives weak coffee, but too much pressed mixture may give you coffee with bad taste.
Aug 26, 2008 | Krups XP4030 Espresso Machine
Coffee overflows
I have a 1600 with the same problem. The problem is due to a poorly designed fit between the carafe and the drain plunger in the coffee basket. If you lift the carafe slightly, you will see the plunger has a long way to go. If you have the tendency to push the carafe fully to the back of the hotplate it makes this worse. OK, so now the fix, which worked for me. Find a small piece of plastic to glue to the top of the carafe lid. You just need a small dimple to push the coffee basket spring in further when you in sert the carafe on the hotplate. You should experiment a little first to see how thick it needs to be. Overall it's a poorly designed combination and someone needs a lesson in tolerancing.
Jun 06, 2008 | Cuisinart DCC-1200 Coffee Maker
Water filters
Cuisinart does sell them. You will have to call the Canadian line or go to
Oct 13, 2007 | Cuisinart DCC-2200 14-Cup Coffee Maker
Kenmore Elite coffeemaker water filter
Try here. Hope this helps.
Oct 08, 2007 | Coffee Makers & Espresso Machines
Open Questions:
See all Cuisinart Brew Central 12-cup Coffee Maker Questions
Cuisinart Brew Central 12-cup Coffee Maker Logo
140 people viewed this question
Top Cuisinart Coffee Makers & Espresso Machines Experts
Greg Cann
Greg Cann
Level 1 Expert
Michael Galve
Michael Galve
Are you a Cuisinart Coffee Maker and Espresso Machine Expert? Answer questions, earn points and help others
