Question about Zebra TLP 2844-Z Thermal Label Printer
TLP2848Z blinking red, will not print
I have a 2005 Zebra TLP2844 printer which is new but I can not get it to work. It won't even print a test page. It ends up with a red blinking light no matter what I try. I have made sure the lid is closed tightly, re-loaded the labels several times, powered down, turned it on while holding the button but it always ends up the same. It will give me a double blinking green light when I first load the labels but if I push the button it will advance the label around an inch and stop with a blinking red light. I can push it again and get the same result. When I push it a third time, the label will advance to the next seam between labels and stay green until I press it one more time which it goes back to the blinking red. Any ideas?
Part # 284Z-10300-0001 (new old stock?)
  • funnychuks20
    funnychuks20 Jan 30, 2013
    Plz have been having a great challenge with my TLP 2824 Plus when i want to print 1-10 it prints the first 3 then it stops and shows a red light what can i do to make it print the 1-10 instead of 1-3 plz very urgent mail funnychuks2000@yahoo.com
    Scholar:
  • 62 Answers
1: Is it a TLP2844 or a TLP2844Z.
Operationally they are completely different printers. TLP2844 uses ELP (Eltron Programming Language. but TLP2844Z uses ZPL (Zebra Programming Language). You need to calibrate the printer to the labels.
Calibration:
If its a TLP2844. Load media. Connect power.
Hold down feed key, power on, count one, two, release feed key. The printer will go through a calibtation routine and print config label. IMPORTANT - When it prints this label you must press the feed key and see the message OUT OF DUMP. Your printer will now be calibrated. Check this by hitting the feed key a few times and printer will feed one label each time feed is hit.
Calibration:
If its a TLP2844z.
Load media. Turn printer on and wait for green light (Approx 1 minute)
Press feed key and keep it pressed until green light blinks once, then twice, now release feed key.
Posted on Jul 13, 2009
  • Jim H Aug 01, 2009
    If your printer is a 2844Z you don't calibrate it by holding down button while powering up. That is how you calibrate a 2844.
    1: is the printer a :2844Z??? YES!!
    dont press any buttons. Power on and wait for a solid green light.
    2: Press and hold the feed button.
    3: Wait for it to flash the light.
    release key when led flashes 4 times.
    This will reset printer and perform a calibration routine.
  • Mario Jan 12, 2012
    on my Zebra TLP 2844 When I hold down the feed button and turn on the printer, wait for the first blink and release, runs through two lables (Prints nothing) then half way through the third label it stops and have a orange light.
    Scholar:
  • 185 Answers
Firstly make sure the ribbon is installed correctly. Secondly press and hold the Green Feed light until it flashes 4 times and let go, it will then reset to the factory defaults and do a calibaration.
Posted on Dec 20, 2009
We can't get our Zebra TLP2844 to print on the left matgin. It only prints in the middle of the label, which messes up the barcode. Our IT Dept has the manual and they can't seem to fix it. It was working...
reset the printer to factory defult ( from the driver( download segull driver) www.seagullscientific.com
check if the driver that you using have the correct Length and the With from the labels that you use.
Print a test page (should come with windows logo plus the text in all label. clean the printhead.
Aug 18, 2010 | Zebra LP 2844 Thermal Printer
Losing half of top line when printing
Label definition in printer driver may need adjustment. Try calibrating printer, printer on solid green light, hold down feed key & release after light blinks 4 times, (blinks once, twice, three times then 4 times) Download the Zebra setup utility and use it to configure printer.
Sep 29, 2009 | Zebra TLP 2844-Z Thermal Label Printer
Hi there! I work with Zebra TLP2844 through
If you are using Bartender, Make sure to use the Seagull Scientific Zebra Driver. The zebra driver works (but not properly) with bartender. Download the driver from Seagull Scientific site. You can also email bartender tech support, their contact details are available from the help screen on the main bartender design screen. I have always found them to be extremely knowledgeable and helpful.
Jul 01, 2009 | Zebra LP 2844 Thermal Printer
Zebra green light blinks continuously
It will blink when there is power. It will go solid once there is a network connection made.
Jun 05, 2009 | Zebra S4M Thermal Label Printer
Flush problem zebra tlp2844
The firmware download utility program comes on the CD supplied with the printer. Use this to download the firmware file to the printer. Check on the zebra website for the latest firmware file. (You should be able to download the Download utility program from the website also. (Steady red may indicate that the printer is set to the incorrect operating mode. Check that you have the correct setting in your printer driver - Thermal Transfer if you use a ribbon, Direct Thermal if not) Easiest way to check is to insert a ribbon and see if printer works)
Mar 31, 2009 | Zebra 2844-Z Thermal Label Printer
Zebra TLP 2844
TLP2844 does not support Line mode.
but the LP2844 does.
If you neeed to use line mode change your printer. from TLP2844 to LP2844.
I had this issue last week.
Jan 20, 2009 | Zebra TLP 2844-Z Thermal Label Printer
Zebra TLP2844 print output very light
The problem was the power adapter appeared to be not original, instead of the required 20V this one produces 15V, found the original power adapter and the printout looks fine, darkness looks ok now.
Regards,
Edwin van Hek
Oct 14, 2008 | Zebra tlp2844ps Thermal Label Printer
Help me with Zebra TLP 2844
The printer only understands EPL code. (Eltron Programming Language) If you are trying to print text from DOS it wont understand (interpret) the txt codes.
To verify that the printer is working.
Open a DOS box, start the dos editor. Type Edit. Dos editor will open.
Type a single capital letter U. and print. Send to printer. The printer will print a configuration label.
EPL code to reset printer is
^default.
If you want to print a text file. use the Zebra Universal Driver. Zebra TLP2844. Open any windows application. E,G, Notepad. type text and send it to printer. Print as normal.
Jul 24, 2008 | Zebra LP 2844 Thermal Printer
Zebra TLP2844 does not print the barcode label
Can you print the barcode using the software that come with the printer. Zebra TLP2844 come with basic Designer software. Test whether it's printing the barcode or not.
IF it prints the barcode via its software, then you might be having barcode font problem between your application/os and the printer.
May 21, 2008 | Zebra Eltron TLP 2844 Thermal Label...
Zebra TLP 2844-Z Thermal Label Printer Logo
1,831 people viewed this question
Top Zebra Office Equipment & Supplies Experts
Dave Busselle
Level 1 Expert
Marvin
Marvin
mukhtar21 shaikh
mukhtar21 shaikh
Are you a Zebra Office Equipment and Supply Expert? Answer questions, earn points and help others
