Question about Whirlpool MH1170XS Microwave Oven
Remove cooktop bulb
The cooktop bulb just blew on our less than 3 month old MH1170XS Whirlpool Microwave\Hood combo. First, isn't this unusual? Second I am not quite sure how to get the bulb out. I have removed the cover but the bulb doesn't appear to just pull or screw out. I have scoured the web and manual but everything simply says "remove bullb" like it should be self-explanatary...what am I missing? Help will be much appreciated even if it is pointing out the obvious.
Thanks in advance!
  • Whirlpool Master
  • 9,098 Answers
First of all, be sure to unplug the microwave before removing or installing the bulbs.
Second, the bulbs may be tacked in place with contact cement or hot glue, and sometimes there may have been enough moisture to corrode and seize up.
I would suggest that you use a hair dryer to heat up the area where the bulb and base (socket) meet. But look out for any softening of the socket.
Once you have replaced the bulbs, don;t be surprised if they either don't come on or won't shut off, or if you have such a problem with the hood vent exhaust fan.
We see (and repair) this control board problem a lot.
William E. Miller
prototech@usa.net
http://www.microwavedisplay.com
Posted on Dec 25, 2008
TYPE BULB FOR PANASONIC NNP295 COOKTOP LIGHT
Halogen Cooktop/Night Light Replacement
Be careful as the Cooktop Light Cover and the bulb may be
hot.
1. Unplug microwave oven or disconnect power.
2. Loosen the screw to open the Cooktop Light Cover.
(Be careful not to lose the screw.)
3. Replace the old bulb with a new one.
(use Max. 125 V, 30 W, Wide Pin Capsule Type/GY8.0~9.0
recommended)
do not touch a new Halogen bulb with bare hands.
Fingerprints may result in shorter life. Remove fingerprints
with alcohol.
If this bulb is not available locally, contact your local
Panasonic dealer. Part number is F612E6Z00AP.
4. Reinstall the Cooktop Light Cover with a screw
Dec 02, 2014 | Panasonic Microwave Ovens
Powers off immediately after starting
My immediate reaction would be to cut your losses and buy a new unit as sooner or later you will run into a part that is no longer available.
Nov 03, 2012 | Whirlpool Microwave Ovens
Whirlpool microwave mh1170xs no power
Sometimes you get lucky with just changing the fuse, the most cost effective way to fix a microwave oven.
Jul 01, 2012 | Whirlpool MH1170XS Microwave Oven
Changed bulb and still not working
Try turning the bulb a little tighter.
Aug 21, 2010 | Whirlpool MH1170XS Microwave Oven
The range-top light blew and now replacement bulbs
My Whirlpool/Roper microwave/hood combo has the same problem. I replaced the bulb twice, checked the bulb and it works, but not in the microwave. I wrote to Whirlpool asking about the problem. Haven't heard from them yet.
Apr 02, 2010 | Whirlpool MH1150XMQ Microwave Oven
Range light bulb will not work. changed bulb and still will not work
i''''''''''m sure that the light is in right . but i go out on many micro and friges and they just need a little more twist . remove the light and spray with pam ( no butter and reinstall it . ) if that does not work re ck the lite to make sure it good .. ****
Jan 04, 2010 | Whirlpool MH1170XS Microwave Oven
Stuck light bulb in micro wave hood.
Be sure the oven is unplugged from the wall first.
In many cases, you have to break out the glass from the bulb and then use small needlenose pliers to unscrew the bulb base.
Once you get the lamps replaced, if they won't turn on or turn off, then you also have a damaged circuit board, which we regularly repair nationwide for $39.95 postpaid.
Details are at our site, linked is at our listing here on FixYa: http://tinyurl.com/yzjozk
We're happy to help and we appreciate your thoughtful rating of our answer.
Jan 08, 2008 | Whirlpool MH7135XE Microwave Oven
Whirlpool MH1170XS Microwave Oven Logo
126 people viewed this question
Top Whirlpool Microwave Ovens Experts
William Miller
William Miller
Chuck
Are you a Whirlpool Microwave Oven Expert? Answer questions, earn points and help others
