Question about Zebra TLP 2844-Z Thermal Label Printer
LAN problem i have problem about the LAN port, the RED led always ON. how can i fix this. thank you.
  • 1 more comment
  • Tikboy Fixya Dec 22, 2008
    with or without cable still the RED led is lighting, even if i turn ON the printer, the red led is automatically light. please need help. urgent. thank you,
  • Tikboy Fixya Feb 22, 2009
    hi preach996, thanks for giving me ideas.. but i did replace the board and now its working..
    more power!!!
  • Roy Lonsinger
    Roy Lonsinger May 11, 2010
    Do you have the cable plugged into the port?
    President:
  • 1,179 Answers
It sounds like something is incompatible. It's possible the router does not recognize the LAN card in the printer. Hope this helps.
Posted on Dec 22, 2008
SMCWGBR14 N only power led
Resolutions:
1) Power on the SMC modem / router and wait until all the lights are light up.
2) Press and hold the reset button for 15 seconds and wait until all the lights are light up as the modem / router needs to reboot.
3) Try to access to the admin page again by default login IP - http://192.168.2.1/.
4) Enter the default login password.
a) smcadmin
b) (blank)
c) barricade
Nov 25, 2013 | Edge Barricade 4 Port Broadband Wireless...
MediaPack MP114 - 4FXO Doesn't work
Install wireshark on your PC and connect yoour PC directly to the MP, once there power on the MP and see if any bootp/arp message appears on wireshark if nothing shows up, your device is bricked.
Nov 06, 2013 | AudioCodes MediaPack MP114 - 4FXO
Trying to fix router but when i put 192.168.0.1 in address bar !!!!! Unable to connect message always comes up So i cannot reset !!!! Having problem connecting to my wireless ipod blue ray @phone while at...
Are you using LAN? You can only access Administration if you reset the device through LAN (pressing reset button). You cannot access Admin config after reset through wireless... If your already using LAN, try turning your firewall off. And oh, your LAN should be plugged in to one of the LAN ports and not in the WAN port...
Jun 05, 2011 | D-Link DIR-615 Wireless Router
I have a netgear router but when i switch it on the internet light is always red and i cannot connect to the internet on my laptop
Try RESETTING your Netgear back to the default settings and configure it again.
To RESET the Netgear, power up the Netgear then press andhold the RESET button at the back of the router until all the LEDs flash. Connect a LAN cable from the Netgear to the LAN port on yourcomputer, open a browser and enter the Netgear configuration URL -
http://192.168.0.1
The default login = admin
The default PW = password You can now change the admin password and configure thewireless settings.
Go to the wireless configuration and set up the SSID and WPA or WPA2encryption.
Apply these settings to the wireless card in your laptop/computer.
To secure your wireless network from unauthorized access, please click on thislink and follow my instructions :- http://www.fixya.com/support/r3559128-wireless_router_security
May 02, 2011 | NetGear DG834G Router
I have a netgear router when i switch it on the internet light is always red
http://192.168.0.1
May 02, 2011 | Computers & Internet
Were do i plug in my broadband i cant see the jack plug
you have to plug your broadband cable which is called lan cable (network cable also) in your laptop lan port ................ you can find the image below lan port is mark with RED PEN
This will help. Thanks please keep updated. please do rate the solution positively .Thank you for using Fixya
Regards
manish
Mar 24, 2010 | Computers & Internet
I have a toshiba v000108500 motherboard, when lan cable is plug into RJ45 socket, lan work normally, problem is the yellow LED of RJ45 always on (doesn't matter two computers communicate or not), when two...
If you are not having any reception problems to the internet, worry not.
Normal is solid amber, and when it flashes that is a sign of activity on the line. This is not a indicator of a problem or potential problem.
Again if I understand you correctly the local area network is working normally. If this is not the case please write back.
Hope this helps, please leave rating. Thank you kindly
May 07, 2009 | Computers & Internet
Onboard LAN detected , drivers properly installed but not responding
The Problem is in your onboard LAN, get PCI LAN card, plug into your PCI slot, install the driver of that PCI LAN Card..
Apr 27, 2009 | Computers & Internet
For dummies
Hello, Good question..Phone line to DSL modem, Ethernet cable to WAN port on Router. If connecting a PC wired to Router, connect Ethernet cable from 1 of 4 LAN ports on Back of router to ethernet port on PC. This would be Physical connection...
It's always smart to set a restore point in case something goes wrong during installation of any program. For wireless connection from laptop or PC: install router software on computer. Reboot computer. In browser address bar enter 192.168.1.1. This brings up a window for user name and password. Enter "admin" for both. This allows you to change many settings including Changing SSID(Router Name), User name and password. Enabling WEP or WPA security. Hope this Helps, Good Luck..!!
Mar 26, 2008 | NetGear RangeMax WPN824 Wireless Router...
All LAN Ports are ON
Arunk, When you say the electrical characteristics of the new A/C adaptor are the same as the old one did you check to ensure the amperage and the polarity of the power plug is the same as well?
Apr 03, 2007 | NetGear WGR614 Router
Zebra TLP 2844-Z Thermal Label Printer Logo
127 people viewed this question
Top Zebra Office Equipment & Supplies Experts
Dave Busselle
Level 1 Expert
Are you a Zebra Office Equipment and Supply Expert? Answer questions, earn points and help others
