Question about Intel Gigabyte 8I845GVM-RZ 82845GV GMCH chipset 533MHz FSB DDR333 Socket 478 mATX Motherboard with L... (MB47GB5GVMRZ)
Required drivers for running games
I have formitted my system . and don't have motherboard CD .How can i get drivers installed in my system to run games
  • 1,179 Answers
Go to the board manuafacturer's website. They have drivers available for download in the support section. Hope this helps.
Posted on Dec 24, 2008
I'm using asus p5sd2-vm mother board. i don't have mother board drivers cd. so i connot play games in my system, while playing the game is running very slowly could you please help me
Hi, you can download the drivers here:
You just have to select your operating system.
Then select the driver and click on global for download.
Maybe you have to add more memory:
Single-channel DDR2 ram 667/533
The driver is a zip file so it have to be unziped
before installation.
You probably also need this software:
Hope this will help you playing games
How to install games on computer?
It just like other programs installed in your computer. You need a program/software of game installed on your PC ( PC games software usually packed in CD). Put your CD game on optical drive and has it installed on your PC. Then run your game, done.
Note that Some PC games need specific PC requirements ( See your game requirement before run it on your PC).
Aug 10, 2011 | Computers & Internet
This problem appears when game is installed from CD. Try installing the game from DVD.
Jun 27, 2010 | Rockstar Games Grand Theft Auto: San...
Cant install game
that makes your software void i am sorry, you should buy a new copy of the game.
almost all games now require CD-KEY's to run the cd key is the actual license to run the software (game)
Aug 06, 2009 | ASUS P4S533-MX MB, DDR+SDR/ VGA/ Audio/...
Cannot play computer games and sounds
First thing ,for any game to be run, Windows need directx software, a better graphics card for an complex games .
Try to download directx10.0 series for windows xp and check ur game, else format the system and then install directx.
Jul 10, 2009 | Microsoft Windows XP Professional
Video driver on Motherboard cd is not running
Your RAM capability is LOW....
If u can upgrade it to minimum of double the previous value..
Results will be best..
Jun 11, 2009 | Intel DG31PR Motherboard
The drivers for the integrated video controller is on the CD that came with the motherboard, but that is most likely not the problem. Most newer hi-res games require much more sophisticated graphic chips than are normally used on motherboards. It may require hardware support for shading and other calculation-intensive operations that would require an add-in video card designed specifically for those purposes. Many also require a minumum of 256MB (or more) of video memory. You should check the documentation that came with the game to find out exactly what its video requirements are.
If that isn't the case, report back with the exact error message you are getting.
Apr 07, 2009 | Computers & Internet
I have sound driver problem & I want 256color configration.
All the sound drivers, graphics drivres for your motherboard will be there in motherboard CD.
Use that CD to install the drivers.
Feb 04, 2009 | Gigabyte GA-MA790FX-DQ6 AMD Phenom Socket...
I start LEGO Star Wars but then says lego starwars stop wrking
LEGO Star Wars II for PC requires the following minimum system requirements:
Operating System
Required: Windows 2000, XP, or Vista
Required: 100% DirectX 9.0c compatible computer
Required: Intel P3 1.0 GHz or AMD Athlon 1000 MHz
Recommended: Intel P4 2.0 GHz or AMD Athlon XP 2400+
Required: 256 MB RAM
Recommended: 512 MB RAM
Graphics Card
Required: 64 MB 3D Graphics card with Vertex and Pixel Shader (VS/PS) Capability
Recommended: 128 MB 3D Graphics card with Vertex and Pixel Shader (VS/PS) Capability
Sound Card
Required: 100% DirectX 9.0c compatible Audio Device
Required: 8X Speed CD-ROM drive
Recommended: 16X Speed CD-ROM or DVD-ROM drive
Input Device
Required: Keyboard and mouse. Gamepad and joystick supported
Recommended: Gamepad
Microsoft DirectX 9.0c (April 2006 Edition) is included on this CD. You will be prompted to install DirectX during the installation of this game if this or a more recent version is not already properly installed on your system.
NOTE: DirectX may require the "latest" updates for your operating system. This may also include the latest drivers for your motherboard, sound, and video hardware.
Installation: Installation requires 3.5 GB of free hard drive space. We recommend that you have an additional 500 MB of free space available after installing the game for the Windows swap/page file.
You must have local Administrator rights to properly install LEGO Star Wars II and update Dire
No other programs should be running in the background.
System resources should be at least 85% free.
To check this:
Press CTRL-ALT-DEL once, choose Task Manager, choose the Performance tab, and check CPU Usage.
There should be at least 500 MB of free hard disk space after installation.
If you experience performance issues when running LEGO Star Wars II, we recommend that adjust the following options in the Video Options menu:
Lower the video resolution.
Set Antialias to Off
If this option is set to Antialias from Control Panel, you will need to set your Antialiasing Setting to Application-Controlled in the Windows Display Properties for your specific graphics card.
Disable Bloom Effect.
Please close all other programs before running LEGO Star Wars II. This includes virus-scanning, word processing, and Internet programs. Simply disabling these programs will not always help, as the programs still use resources that are needed to run LEGO Star Wars II. If you experience problems completely closing programs that are running, consult the documentation for those individual programs. This is a common problem when trying to completely disable virus-scanning software.
Jan 18, 2009 | Origin Lego STAR WARS 2 for Windows, Mac
New p c game will not launch
If you installed from CD - Have you tried it with the CD in? Many games do not install completely to the hard drive and require the CD to run. If you downloaded it from another source, try installing it again.
Dec 13, 2008 | Intel Motherboard
Computers & Internet Logo
29 people viewed this question
Top Intel Computers & Internet Experts
Alun Cox
Are you an Intel Computer and Internet Expert? Answer questions, earn points and help others
