Question about Philips PH-DVD5 Remote Control
Which buttons to press to enter tv code
As I look at the remote ..I see the TV button is that the only one I need to press to enter and set up my tv code #108
  • 259 Answers
How do I restore the factory settings on a Toshiba TV Model 32w1633DB
IMPORTANT: Different TVs may have different ways of performing the reset procedure. Refer to the Owners Manual CHAPTER 5: SETTING UP YOUR TV > RESET FACTORY DEFAULTS OR CHAPTER 6: BASIC FEATURES > RESETTING TO FACTORY DEFAULTS for your specific TV.
  • Turn off the TV and unplug the TV power cord. Leave unplugged for at least one minute. Plug it in again to complete this reset process.
  • When the TV has powered on, access the settings through the MENU button, perform the following reset procedure.
Whether your TV has Wi-Fi capabilities will dictate the steps to perform the second reset procedure. This procedure will reset all settings and channels to their factory default values.
Non Wi-Fi TVs Use one of the following procedures below to reset the TV.
Procedure 1
  • Press the MENU button on the remote (or MENU on the TV) to open the Setup menu.
  • Using the arrow keys on the remote (or volume / channel on the TV), highlight INSTALLATION at the top of the menu and press ENTER. A new set of INSTALLATION menu icons will appear.
  • Highlight the SYSTEM STATUS menu at the top.
  • Highlight SYSTEM INFORMATION below and press ENTER.
  • At the top of the SYSTEM INFORMATION window, use the arrow keys on the remote (or volume / channel on the TV) to scroll Left/Right through the menu bar to select FACTORY DEFAULTS. Press ENTER.
  • Highlight YES and press ENTER. To cancel the reset process, select NO and press ENTER.
NOTE: If a PIN code has been set, enter your PIN code. Select DONE and press ENTER.
  • A warning message will appear, select YES and press ENTER. The TV will turn off automatically after a few seconds.
  • After the TV turns off, unplug the TV power cord and then plug it in again to complete the reset process.
Procedure 2
  • Press the SETUP button.
  • Select Installation > Reset TV.
  • Enter your PIN code (if a PIN code has been set). A confirmatiom screen appears.
  • Select Yes, and then press the OK button. The TV will turn off automatically.
Wi-Fi TVs (Smart, Cloud)
Procedure 1
  • Using the arrow keys on the remote (or volume / channel on the TV), select SETTINGS > SETUP > RESET TV and press ENTER.
  • A confirmation screen appears. Select YES, and press ENTER. To cancel the reset process, select NO and press ENTER. The TV will turn off automatically to complete the reset process.
Procedure 2
Aug 30, 2017 | Toshiba Computers & Internet
I have a universal remote systemlink 3 RCA. I need the code to program it. I have Goldstar TV. Thanks.
1.Use one of the following three digit codes for your TV set:
004, 005, 006, 012, 019, 056, 057, 058, 155, 156, 171, or 1722. Manually turn on the TV set.
3. Press and hold the CODE SEARCH button until the indicator light is lit. Then release the CODE SEARCH button. (The indicator light is located above the TV button).
4. Press and release the TV button. (The indicator light will blink and then remain lit).
5. Enter a three digit code found at step 1 using the Number Buttons.(After the code is entered the indicator light will turn off).
6. Aim the remote at your TV. set and press the OFF/ON button. If your TV. set turns off, then proceed to step 7. Otherwise, repeat step 3 to 5 using the next code on the list. Press CHAN up button to double check for accuracy of the code. the programming is complete if the TV set responds by going up a channel. Otherwise repeat steps 3 to 6 using the next code on the list.
7. Press CHAN up button to double check for accuracy of the code. the programming is complete if the TV set responds by going up a channel. Otherwise repeat steps 3 to 6 using the next code on the list.
8. If none of the codes work, you will want to use the following to go through the codes manually (this will take some time):
Code Search for the right TV code on a Universal Remote (systemlink 3 RCA)
1. Turn on the TV.
2. Press and hold the CODE SEARCH button until the indicator light lights. Then release the CODE SEARCH button.
3. Press and release TV button. The indicator light will blink once.
4. Repeatdly press and release the OFF/ON button until the TV turns off. It may be necessary to press the OFF/ON button up to 200 times before the TV turns off.
5. When the TV turns off, press the ENTER button. Now the Device is programmed for the TV set.
Aug 05, 2011 | RCA 3-dev Universal Remote Remote Control
Need codes for programing a hitachi tv
The codes are, 0145,1145,...Step 1. Turn the TV on. 2. Press the TV button. 3. Press and hold the SET button until the LED blinks twice, then release. 4. Enter one of the four digit codes, the LED will blink twice. 5. Aim the remote at the TV and press the POWER button, if your remote does not have a power button, press PLAY, the TV should turn off, if not, try steps 1-5 again using a different code....hope this was helpful...
May 22, 2010 | One For All URC-3021 Remote Control
Need code for asda remote model#URC20-D1F for use with my sony tv
URC20 D1F
Set up by Automatic Search
1. Turn TV on
2. Point the remote at tv and Hold SET and TV buttons at the same time and keep pressed for 3 seconds.
3. The LED flashes and the remote control starts the automatic search.
4.The OFF signal is automatically sent to the tv from the remote control.
5. Once the TV switches off press any button except SET to stop auto search.
6. Switch your tv on using the POWER button.
Sony TV codes
010,011,028,030,031,077,107,128,131,166,203,237,302,309,367,444,445,446,449,160
To enter. Just hold SET and TV at the Same time.
The red led light stays on you are in set up mode.
Enter the first code on the list and try power button.
Keep following the steps untill you can turn the tv off.
Then its set.
Feb 08, 2010 | Televison & Video
Code problem
With the TV on, press the TV button once and then press and hold the SETUP button till the TV button blinks, then enter the code.. After you enter the code push the PWR button. Tv should turn off. If it does, the code is set..Good luck to you
Nov 06, 2008 | Universal Remote Control Remote Control
RadioShack Universal Remote (Cat. 15-2147) - to use with JVC TV
programming a device: make sure batteries are installed correctly. Turn device on(for ex., your TV). Press TV button next to Power button on your 15-2147...Press and hold the little P button until the red LED lite blinks twice...enter the first four-digit code for your device(in your case,JVC TV...first set of #s is '0463' ) note: the LED will blink once as each number is entered. If the number is correct the LED will blink 2x. Note if the LED doesn't blink twice after entering the 4 digit code, begin again with the next set of numbers. For JVC the codes are 0463 and 0053. Once your remote blinks twice after entering in your TV code, press the power button. This should turn off your TV. Just use like any other remote. Hope this helps you.
Oct 11, 2008 | Radio Shack (15-2147) Remote Control
Need code for remote control
To program a TV you can use the code search option. You do this by making sure the TV is turned on then point the remote at the TV then press the TV button once, then press and hold down the set button until you see the RED l.e.d light blink twice, then enter the code 991. Next press the power button then the TV button continue doing that until the TV turn off, when it does press the set button. Press the power button and the TV should turn on again.
Sep 17, 2008 | Televison & Video
Hitachi CLE984
The code you need is 0145
1) Switch on the TV set
2) Press the TV button on the Sky Remote
3) Hold down the select and red buttons for 2-3 seconds until the LED blinks twice
4) Press the TV button on the Sky Remote again
5) Enter the 4 digit code for your make of TV
6) The LED should blink twice, if not recheck the 4 digit code used and go back to 1
7) Press the standby button on the Sky Remote (The TV should go to standby)
8) Press select to store this setting
If the TV does not go into standby press the TV button then the standby button, then TV then standby, keep repeating this until successful. This will scan the codes used for a particular make of TV.
Jul 01, 2008 | Hitachi CLU-5713TSI Remote Control
Need remote control codes for the JVC Multi Brand Remote Control Unit, LP20303-018
It took me a week to find the right instructions and codes on how to do this so I am posting it everywhere I can to help out folks with the same remote. Pay close attention to the instructions, for instance when programming the remote for TV use make sure you hold the TV button down while you enter the code and then press OK, You also have to hold the TV button down while you use the volume and channel controls or it will just change the VCR channel.
A
Turn on TV
Turn on the TV using the Power button on the TV or its Remote.
B
Set TV brand code
A
Press and hold TV.
B
Press MBR SET.
C
Press the Number keys to enter your TV.s brand code.
D
Press OK, and release TV. The TV should turn off.
C
Operate TV
While holding down TV, press one of the following buttons:
POWER 1, TV/VCR, TV CH+/., ^(TV Muting), TV VOL+/.,
and the Number keys.
For some brands, you must press ENTER after having pressed the
Number keys to enter a channel number.
TV BRAND CODE TV BRAND CODE
JVC 01, 03
SONY 07
HITACHI 10
SAMSUNG 12
MAGNAVOX 02
SANYO 13
MITSUBISHI 03
SEARS 13
PANASONIC 04, 11
TOSHIBA 08
RCA 05
ZENITH 09
SHARP 06
Cable Box or DBS Receiver Brand Setting
A
Turn on cable box or DBS receiver
Turn on the cable box or DBS receiver using the Power button on
the unit or its Remote.
B
Enter brand code
A
Press and hold CABLE/DBS.
B
Press MBR SET.
C
Press the Number keys to enter your cable box.s (or DBS
receiver.s) brand code.
D
Press OK, and release CABLE/DBS.
C
Operate cable box or DBS receiver
While holding down CABLE/DBS, press one of the following
buttons: POWER 1, TV CH+/., and the Number keys.
To change the cable box.s (or DBS receiver.s) channels, press TV
CH+/–
or the Number keys. (The CH+/–
button can be used to
change the VCR.s channels only.)
CABLE BOX BRAND CODE
ARCHER 01, 05, 17
CABLETENNA 01, 17
CABLEVIEW 15, 16, 17, 21, 25
CITIZEN 15, 16, 17, 21, 25
CURTIS 02
DIAMOND 01, 17
GC BRAND 15, 16, 17, 21, 25
GEMINI 15
GENERAL INSTRUMENTS 01, 04, 06, 11, 12, 15, 28
HAMLIN 10, 18, 23
JASCO 15
JERROLD 01, 04, 06, 11, 12, 15, 28
NOVAVISION 02
OAK 07
PANASONIC 13, 14
PULSER 15, 16, 17, 21, 25
RCA 13, 14
REGAL 10, 18, 23
REMBRANDT 01, 16, 17
SAMSUNG 05, 16, 24
SCIENTIFIC ATLANTA 02
SIGMA 07
SL MARX 05, 16, 17, 24, 25
SPRUCER 13, 14
STARGATE 05, 15, 16, 17, 21, 24, 25
TELEVIEW 05, 16, 24
TOCOM 01, 04, 16
UNIKA 01, 17
UNIVERSAL 16, 17, 25
VIDEOWAY 03, 09, 22
ZENITH 03, 09, 22
DBS RECEIVER BRAND CODE
JVC (DISH Network) 51
ECHOSTAR (DISH Network) 51
SONY (DSS) 41
RCA (DSS) 40
Changing Remote Control Code
This Remote is capable of transmitting two control codes; one set
to respond to A code control signals and another set to respond to
B code control signals. This Remote control is preset to send A
code signals because your VCR is initially set to respond to A code
signals. You can easily modify your VCR and the Remote to
respond to B code signals. When using two JVC VCRs, set two
VCRs and their Remotes to different codes, so that you can
operate these VCRs separately.
A
Set remote control code for Remote
A
Press and hold A/B.
B
Press the Number key .2..
C
Press OK, and release A/B.
The Remote now can transmit B code control signals.
B
Check remote control code for VCR
Press and hold 4
on the VCR for more than 5 seconds while the
VCR is turned off. The code currently set appears on the display
panel.
C
Change code for VCR
Press any key on the Remote. The VCR now responds to B code
control signals.
To set the Remote and the VCR back to A code control signals,
repeat the same procedure as shown above except pressing the
Number key .1”
in step B
of 1
1111.
To control two VCRs with the same Remote
You can control two JVC VCRs by switching the remote control
code for the Remote between A and B (.
step A
AAAA), keeping two
VCRs to different control codes.
To change only the remote control code for the Remote, DO
NOT perform steps B
BBBBand C
CCCC.
Mar 19, 2008 | JVC RM-C18G-1H Remote Control
I NEED THE CODE FOR ALBA TV MODEL NO. ALCD15TV8M
There are two code types for sky remotes, Brand Codes & Direct Codes.
The codes for Alba are:
Brand - 0043
Direct - 037, 065, 246, 399, 263, 064, 446
There is a small difference in the way they are set.
To program using the 3 digit code - Direct Code
4) Enter the 3 digit code
5) Press the select button to store
Press TV and any number to test, If this does not operate the TV set try below.
To program using the 4 digit code - Brand Code
Feb 18, 2008 | Televison & Video
Philips PH-DVD5 Remote Control Logo
Top Philips Televison & Video Experts
matt martin
matt martin
Steve Allison
Steve Allison
Are you a Philips Televison and Video Expert? Answer questions, earn points and help others
