Question about Kenmore Elite 22.4 cu. ft. Bottom Freezer Refrigerator with Adjusta Cube Ice Maker
Hello? I have a new Eclipse Kenmore being installed Tuesday 12/23. What do I need to provide for a water supply?
    Scholar:
  • 31 Answers
I see your installation date has come and gone, but if you still need to hook up the water you can find an "ice-maker kit" from almost any home improvement store (such as Lowes, Ace, Home Depot etc....) This includes 1/4" bendable copper tubing and a valve that will tap a near by cold water supply pipe. If you find a kit with plastic tubing, I would steer clear and find the bendable copper. Plastic tubing kits are notorious for springing leaks. Buy some extra compression nuts and washers for the tubing while you are there, it may take more than one try to get a waterproof seal if this is your first time hooking up water and ice dispenser.
When hooking up the tubing to the back of the refridgerator, leave a couple coils of slack to allow the refridgerator to be pushed in or pulled out without straining the connection. There is usually a small clamp on the refridgerator back to hold the tubing steady, make sure you use this. This will help ensure a leak free connection. After you have the tube hooked up, push the refridgerator all the way back, then pull it back out and check for leaks. Sometimes the tube will start dripping a bit after the refridgerator is moved, so this step helps ensure you won't have leak problems.
Posted on Jan 08, 2009
No water
Try replaceing the water filter, and / or check the water supply for adequit volume and pressure, by disconnecting the water supply line from the back of the refrigerator and run a couple of gallons of water into a bucket just to make sure the line is clear.
If the water supply volume and pressure is good, reconnect the water supply line, install the new water filter and try dispensing water, this should fix it, or check that the water supply silenoid valve for proper operation when dispenser lever is depressed.
GOOD LUCK !
Aug 20, 2010 | Kenmore 57029 Side by Side Refrigerator
How to install a stainless steel evolution pool heater
Hello. Most pool owners use natural gas or propane to heat their pool water through a gas boiler. Call your gas provider and they will come out and give you a free estimate on a perfectly sized pool heater. You can then install it your self or have them do it. Joe
Apr 05, 2010 | Home
I need details on how to install Maytag built in dishwasher
Hello Ted, Without the exact model number, it is difficult to provide the correct installation instructions for your specific Maytag dishwasher.
I can provide you with a link to the Maytag site where you can enter in your model number and download an owners manual and installation instructions/guide that will provide you with the step-by-step needed to properly install your dishwasher.
http://www.maytag.com/support/manuals_literature.jsp
The installation instructions will provide the proper wiring, water supply inlet plumbing and connection of the water discharge line, as well as all of the dimensions needed for clearances for the countertop and cabinets.
If you're trying to install an older dishwasher, you can also give them a call at 1-800-344-1274 and have your complete model number available, so they can provide you the correct manuals and instructions.
I hope you find this Very Helpful and best regards!
Nov 23, 2009 | Dishwashers
I have a kenmore dishwasher but no kickplate. How
Hello cantrell_m,
Sears appliance parts can supply you with the part you need. You will need to provide the model #. Here is their phone # (800) 252-1698.
I hope this is helpful for you. Positive feedback for me is appreciated. Thank you! NormanZ
Jul 14, 2009 | Kenmore 24 in. 16462 / 16464 / 16469...
Need to know how to install new radio in a 2001 mitsubishi eclipse
call 1888mitsu2001 and hit option #4, then hit * (star), give them the last 8 digits of your vin and they will provide the code for FREE.
DO NOT PAY FOR THE CODE ONLINE OR GO TO A DEALER (they will also charge).
May 09, 2009 | 2001 Mitsubishi Eclipse
Kenmore Coldspot Model 70162990 - not making ice
You've either got a bad timer on the ice maker or the water valve is defective. You need to verify that the timer is moving first. If it isn't try pushing in on the dial on the end of the ice maker. It is under the white square cover at the end of the ice maker, usually towards the door, but in some units it points to the left side wall. If it begins to run when you do that, then the timer is broken. If not then I would say that the valve is defective.
Feb 01, 2009 | Kenmore 53642 / 53644 Side by Side...
Uninstall headlight & tail light assemblies for a 2008 eclipse GT
well you have to remember that you have retainers on top and bottoms of bumpera nd on the sides you have bolts or screws on around the ends adn should jus tpull right off for you.
Jan 23, 2009 | 2001 Mitsubishi Eclipse
We have a new washer. It is flashing F29 and won't drain.
communication between ccu board and mcu board check and push on all wires. to and from motor controller board[mcu] &[ccu] board top in rear usally this code i found loose wire at mcu
Oct 24, 2008 | Kenmore Elite 45986 Front Load Washer
Ice maker not making ice and water dispenser
your freezer must be at least 8 degrees before it will make ice, so check the temperature..
also you may need to change your water valve
Apr 02, 2008 | Kenmore 55612 / 55614 / 5561 / 655619 Side...
Kenmore Elite 22.4 cu. ft. Bottom Freezer Refrigerator with Adjusta Cube Ice Maker Logo
95 people viewed this question
Top Kenmore Refrigerators Experts
Sal De
Jim Goldsmith
Jim Goldsmith
Arnel
Arnel
Are you a Kenmore Refrigerator Expert? Answer questions, earn points and help others
