Question about RCA TruFlat 27F520T 27" TV
RCA 27F520 Shutdown after a few seconds
I've seen many of these problems posted here, but none quite exactly like this.
I got this TV from my inlaws as they couldn't get it to work and just went out and bought a new set.
The TV will come on, however, as the picture warms up you only see a horizontal strip about 1 to 2 inches from top to bottom right in the middle of the screen. I'm guessing there's a "curtain effect" as the set turns on because I can see something spreading out starting in the middle. About as soon as the "opening curtain" gets all the way across the screen, it'll start to go back in. Once the "curtain" meets back in the middle the set will power off.
I've found that if I hit the channel change button I can delay the TV from turning off, but once the "closing curtain" effect starts I can't stop it.
I can read the Volume bar if I start pressing the Vol + or Vol - buttons, but it will not stop the set from turning off.
After reading how to get in the service menu I tried this, and to my surprise it worked, but I still can't read anything as the screen never expands from top to bottom, it only stays in the middle in a strip left to right. The set will not turn off by itself once in service mode but I can't read any of the menus. I can see static or snow as I don't have any cable hooked up to it, but again, compressed down from the top and bottom.
I've tried making an adjustment to the "Screen" and "Focus" settings, which I can see make changes, but do not help this problem.
I found the service manual for this set but I can't really find something to relate to have a "squished" screen and it powering itself off after a few seconds.
TIA for all the help.
  • grannybear37 Dec 23, 2008
    1. tv turns off after a few seconds.when turned on , all different colors are on screen.
  • 905 Answers
You have lost the vertical ic and maybe resistor or capacitor.
but you also maybe loosing the horizontal ic
you will also have to check the voltages on the flyback transformer that go to those circuit's to see if they drop or are correct
Posted on Dec 22, 2008
Universal remote for RCA tv channel 1
Something missing here. There is no channel 1 on a TV set. None of the universal remote instructions I have or have seen specify that as a first step. From your post, I believe you want to use some kind of universal remote to control an RCA flat panel TV, Can you tell me the brand of universal remote you are trying to use? The answer to the last line of your post is you don't need the original remote to "reprogram". That's what universal remotes do
Jan 04, 2013 | RCA Televison & Video
I need the code to get rid of the region code error on my RCA L26WD26D
I had exactly the same issue, and after a week of searching the web for the answer to this question. I posted a pdf of the page from the service manual that helped me fix the issue here: http://www.highdefjunkies.com/showthread.php/1817-The-Official-quot-Service-Menu-Access-Codes-Request-Thread-quot?p=353717#post353717
To fix mine, all i did was turn the volume on the tv to zero, then on the tv set itself, hold down the volume down button and on the remote control hold the number 4 button down both at the same time for 2 seconds. The screen will say "initialization of factory dvd data." and my dvd player started playing my dvd's no problem. I wasn't able to set the region code to a specific number like some people need, but maybe the answer to that question is some where else in the manual I posted above. I've spent too much time on this already :-D Hope this was a help and good luck!
Sep 08, 2011 | RCA L26WD26D 26 in. LCD TV
I have a 60" RCA D56W02B rear projection TV. I've
Yes,the power supply board,where the actual power a/c cord plug into it,are most of the causes of power LED light blinking problems.
Feb 17, 2011 | RCA D52W20 52" Rear Projection HDTV-Ready...
When i turn my toshiba tv model #46h84 the green bulb lights up the screen but then shuts off and there is no picture! please help me out!!!
I have the same exact problem...for a few weeks the TV would turn off and the red power light would blink. Then the other day I started having exactly the problem you describe...green screen for a few seconds and then total shutdown.
Feb 08, 2011 | Toshiba 46H84 46" Rear Projection...
My rca 27F520 has the front buttons locked, and I don't have a remote to unlock it.
Hello
Without its remote it will be difficult to unlock it. Just try to get its remote control by contacting RCA authorised service center or any other way. Universal remote controls will not activate the following said proceedings.
Most RCA and GE TV sets use a four digit code to control the v-chip. The code reset is different depending on the model. Try each number until you find the one that works for you.
  1. Hold down the MENU button on the remote and VOLUME DOWN button on the TV it's self at the same time for at least 4 seconds. The set won't say so, but the lock will be unlocked
  2. Hold down the 0 (zero) button on the remote and the VOLUME DOWN button on the TV itself at the same time for at least 4 seconds. The set won't say so, but the lock will be unlocked
  3. Hold down the MENU button on the front of the TV and the TV button on the remote at the same time for at least 4 seconds. 4- Hold down GO BACK button on the remote and MENU button on the front of the TV at the same time for at least 4 seconds.
  4. Hold down EJECT button on the front of the TV and the MENU button on the remote at the same time for at least 4 seconds. Depending on the model, one of the methods should unlock the V-chip. Now, if desired, you can change the settings on the V-chip by going to the MENU and going to PARENTAL CONTROLS, or on some sets, going to MENU and then going to TV SETUP, then to V-CHIP SET.
OK.
Jan 09, 2011 | RCA TruFlat 27F520T 27" TV
After watching TV for a few hours it will turn off by itself. Then the light will blink 3 times. If this is the lamp door switch where is that located?
THERE ARE 2 SWITCHES IN THE TV THAT WILL GENERATE 3 BLINK SHUTDOWN ONE FOR THE LAMP DOOR AND ONE FOR THE LAMP ITSELF. I HAVE SEEN GENERIC LAMPS IN THE PAST THAT DON'T FIT QUITE RIGHT AND CAUSE THIS PROBLEM. OTHERWISE MAKE SURE THAT THE LAMP DOOR IS SECURE COMPLETLY.
Dec 16, 2010 | Sony Televison & Video
Need solution
Appreciate the direct "Ask Me".
Your concern with an RCA D52W26 is when you attempt to turn it on, it powers up as indicated by the LED lights but they then power OFF a few seconds later? or it powers on then you get to see bright line(s) left to right, then the TV powers OFF? or it powers on but only bklinking LED lights? If yes on the last any sequence to the flashing/blinking?
Hope that this be of initial help/idea. Pls post back how things turned up or should you need additional information.
Good luck and kind regards. Thank you for using FixYa.
Oct 28, 2008 | RCA D52W20 52" Rear Projection HDTV-Ready...
I have a RCA tv in my house; believe it is a 36 inch. I have been trying for two days to get it working. When I turn it on, I get no power or sound whatsoever. All I get is a small green light on the front...
The set has gone into protective shutdown. This is to prevent further damage. The most common part failure is hte horizontal output transistor. This is a 3-legged part attached to a heat sink close to the flyback transformer (part with large red wire coming out of the top). Try replacing that part.
Keep us posted.
Dan
May 01, 2008 | RCA 36F530T 36" TV
Switching my tv from tv setting to video setting to play vcr
Should be a button on the TV or remote that says Video or Mode. Make sure player is on before hitting the button and wait a few seconds.
Mar 21, 2008 | Televison & Video
RCA TruFlat  27F520T 27" TV Logo
242 people viewed this question
Top RCA Televison & Video Experts
jason
matt martin
matt martin
Are you a RCA Televison and Video Expert? Answer questions, earn points and help others
