Propane heater wont work
I have a coleman propane heater model5080a751 and it will not work. the propane tank is full. there is a little flame when you push the ignitor button but as soon as you let go it seems like the propane stops flowing. it just wont get to the full flame like it is suppose to. it was working for about ten minutes and then it just shut off,almost like there is a problem with the propane staying flowing. any ideas?
  • Redsea1961 Dec 22, 2008
    The propane heater will not ignite.
Sounds like a dirty pilot orfice. Or you may need to replace the thermocouple. The thermocouple generates voltage from the heat of the pilot and energizes a magnet in the gas valve and when you release the button it should stay on. Once the pilot is established, the main burner should work...There is no primer function....cheers.
Posted on Mar 26, 2009
I'm not sure about that model, but I think you have to hold that button down for a minute or more to "prime" it.
I have a different model coleman propane heater that sits on the 20# tank. Mine is probably getting rusty, last time I used it I had to hold that button down for a long time.
I'm looking for a new heater now myself, as mine won't stay lit outdoors in much wind.
Posted on Jan 21, 2009
How to turn on the propane heater in a coleman pop up camper
Hi Robert,Make sure you have gas in the tank ,first turn on your propane tank, the knob is at the top of the tank with a small arrow showing you the way to turn it on.Then on the heater you should see a red knob with the words-pilot-on-off.Turn to pilot then light it,you may have to push the red knob in-wards at the same time as you light it to let the gas come in.Now if you see a small flame stop pushing in the red knob and let it go slowly.the small flame should stay lit, now turn the knob to the -on-position and set your thermostat. If this did not help you please have a heater repair person help you to see if you may have a problem. remember you are dealing with gas this is dangerous.
Jan 05, 2014 | 1994 Pop-up
My Coleman gas furnace turns on, ignites and the flame will keep going out. The entire time the blower motor will stay on humming until its hot to the touch. If I tap the gas pipe I can get the pilot to...
IT could be the temp is too cold at night and the tank cannot make vapor ie gas, The liquied has to boil inside to make the gas you can get a heat blanket to warm your tank. Ask you gas suppier if they have one.
Mar 17, 2011 | Coleman Propane Forced Air Heater...
Coleman heater model 5445c700 propane camp heater wont light. It did work fine. When I hold the knob in the light position you can hear gas but it barely ignites then goes out. I've tried new gas and...
If you're using a 20lb propane tank (Gas Grill Tank), that may be the problem. Turn off the propane tank at the tank valve and disconnect it from the tank. Wait 5 minutes and reattach the heater hose to the tank. Turn the propane tank valve on very,very slowly until it's all the way open. Try lighting your heater now. If the pilot flame height returned to normal, that was the problem.
FYI - The Thermocouple has nothing to do with the length of the pilot flame. It's a safety feature that stops the gas if the pilot flame goes out for any reason.
Hope that solves your problem. Please let me know.
Rich
Feb 07, 2011 | Coleman Heating & Cooling
A lot of air comes out of firebox when lighting then flame goes out coleman heater
What do you have your heater hooked up to? A 20# propane cylinder? Are you using a red high pressure regulator or a silver low pressure regulator? Is this the original regulator that came with the heater? I could be a regulator pressure problem or a dirty flame sensor that simply needs to be lightly cleaned with sand paper. It's also possible your igniter is faulty or your brain box has a short. I've come across a few that just needed the brain box pushed a little in a certain direction to make good contact and work again, using a small wedge behind it. Sometimes just fiddling with it and cleaning it is all it needs. Good luck. Douglas
Oct 06, 2010 | Coleman Propane Forced Air Heater...
Propane convection heater won't maintain full flame
Seems like the valve is not opening up fully or the adjustment is out of adjustment. Try adjusting the flame.
Feb 15, 2009 | Mr. Heater Mr Heater Portable Buddy...
Wall heater not working properly--sputtering blue flame
Ok, either your fuel pressure is too low or too high.. When you light the unit, Light it in low, then turn it up slowly Just crack open your tank valve.about1/4 turn. The air in the tubes has to be displaced with gas before you get a good flame
Dec 02, 2008 | Reddy Heater RLP100 Portable Forced Air...
Reddy propane heater RLP100
Try a little longer, sometimes it takes a full minute to heat the thermocouple. Check and make sure thermocouple is in flame. If all this is ok. then your going to have to change the valve.
Nov 29, 2008 | Reddy Heater RLP100 Portable Forced Air...
Reddy heater rlp 100
Sounds like the thermocouple is not working or the flame is not hitting the thermocouple. It may take 30 seconds of flame or longer to keep it on. Check for a loose connection at the gas valve.
Either a 30# or 110# tank of propane will work. You might even get by for a short period of time using a gas grill tank, depending upon how cold it is outside.
Oct 26, 2007 | Reddy Heater-30,000 BTU Propane Forced-Air...
Heating & Cooling Logo
624 people viewed this question
Top Heating & Cooling Experts
Paul Carew
Mack Baxter
Marvin
Marvin
