Question about HP Computers & Internet
Hp pavillion power problem
Hp pavillion a700y- wont power up- power light keeps flashing
    Scholar:
    New Friend:
  • 42 Answers
Perform the following steps, in order, until power is restored or it is determined that there is a hardware failure:
CAUTION: This product contains components that are easily damaged by ElectroStatic Discharge (ESD). To reduce the chance of ESD damage, work over a non-carpeted floor, use a static dissipative work surface (like a conductive foam pad), and wear an ESD wrist strap that is connected to a grounded surface, like the metal frame of a PC.
1. Disconnect all cables from the computer, including the power cord.
2. With the power cord disconnected , press the power button on the front of the computer for five seconds.
Plug in the power cord and test to see if the computer can turn on. If not, continue using these steps.
NOTE: If the power supply fan makes an inconsistent grinding sound or stops and starts erratically, replace the power supply.
3. With the power cord removed, flip the red voltage selector switch to the opposite position. Wait about five seconds, and then switch the red voltage selector switch back to its original location. Ensure that the voltage selector switch is on the correct setting, 115V for North America.
Performing this step ensures that the voltage switch is engaged and set correctly for your country/region.
4. Remove all extension cords, power strips, surge protectors and any converters that remove ground. Plug the power cable directly to the wall outlet and test to see if the computer can turn on.
Posted on Jan 09, 2009
  • Ganesan Chandraiah
    Ganesan Chandraiah Jan 09, 2009
    Keep me posted if the problem is solved.
Power light on computer flashes..tried the trouble shooting advice w no results. Bestec power supply model atx 250-12z. Unplugged computer to clean and now wont turn on..No fan no nothing..Just a green...
If you didn't accidentally unplug the four pin connector near the CPU, you need to replace the power supply. This is actually a fairly common occurrence with the cheap ATX power supplies being tossed into systems these days.
Jun 15, 2011 | HP Bestec ATX-250-12ZD 250w HP Pavillion...
My laptop wont power up all the lights flash for one second then shut right off
It seems that the Notebook's Motherboard has failed.So needs to change the Motherboard of the Notebook and hp is providing 90 days post warranty on this and the Price for repair may come around $280 inclusive of all taxes and shipping charges.
Oct 08, 2009 | HP Pavillion ZV6000 Notebook
Power led on hp monitor flashing
mham2525, Did it have a "perfect" picture on it yesterday? You do know that if the COLD-CATHODE-FLUORESCENT-TUBES that are hung on the rear of the LCD PANEL fail to light, all you get is a BLACK screen to look at!!!!! OMG, What shall I do now???? It sure would be nice if all we needed to do was remove the cover and then screw-in 4 new CFL light bulbs into our monitors. YOUR UNIT WILL NEED TO BE TROUBLESHOOTED AND REPAIRED. MOST LIKELY A SMPS/INVERTER BOARD FAILURE. CALL HP TO SEE IF THEY HAVE A SWAPOUT PROGRAM. Bye for now. lmistyrel @aol.com
Sep 24, 2009 | HP Pavilion F1703 17" LCD Monitor
My hp pavillion will not power all the way up
What do you mean it powered on to the blue light?
Does anything show up on the screen?
Does the system usually beep when it starts? If so, does it beep now?
Jun 16, 2009 | Computers & Internet
Hp pavillion will not turn on, took battery out and put back in still not working. blue light around power cord on and blue lightening bolt flashes
Hi Iceprincess5
The three flashing lights indicate the battery is dead. Since it still wont power up with the cable plugged in I'd say the port has gone. Try wiggling the adapter about in the port to see if it begins to charge. If not then you would need to take it to a laptop repair centre to get a new dc port soldered on or buy a docking station.
May 15, 2009 | HP Pavilion dv2700t 2.5GHz Intel Core 2...
I got hp pavilion pc the problem is its not switching on there is a green light back of the pc it keep flashing what i ve to do My HP Pavillion will not come on and the green light at the back keeps...
if your network cable is plugged in it will flash green .....if it won't turn on pull the plug and wait 10 seconds or more then plug in again and see if it will start .....are the fans running and no signal to monitor?
Jan 06, 2009 | HP Media Center m1180n PC Desktop
Power supply light flashing.
Computer power supplys are modular replacement fixes. Better to replace the whole thing then try to repair.
Sep 24, 2008 | HP Bestec ATX-250-12ZD 250w HP Pavillion...
I have a hp pavillion f1723 but it wont switch on, the green led power light keeps flashing, what does this mean?
count the times the green led flashes? and how it flashes that´s an error code for your problem. it can be the motherboard or power.
Aug 13, 2008 | HP Computers & Internet
Hp Pavillion dv6000
Hi
It is indicating battery low. Power is not passing to laptop check power card or adopter....
Thanks
Jul 10, 2008 | HP Pavilion dv6000z Notebook
Computers & Internet Logo
970 people viewed this question
Top HP Computers & Internet Experts
pontelemon
pontelemon
Alun Cox
Are you a HP Computer and Internet Expert? Answer questions, earn points and help others
