Question about Microsoft Xbox 360 Console
Xbox 360freezes up
I have had e68 and e79
  • 1 more comment
  • keithheisser Dec 22, 2008
    also can't get my xbox to see window media player
  • keithheisser Dec 26, 2008
    i never said anything about any lights you just want my $$$ for your premium plan take me off your list
    i have already fixed my box it has been playing now nonstop for 1day and ahalf and the fix well ill leave that a ?????????
  • 20 Answers
E68 = Turn off system, take hard drive off, put hard drive back on, turn system back on.
I don't know about E79
Posted on Feb 20, 2010
Tip
XBOX 360 Error Codes
There are several error codes you can get with an XBOX 360, the first step to resolving any problem is finding the root cause. The fault codes are primarily shows on the "ring" on the front of your console (this is the ring split into 4 segments that shows when controllers are connected and what player position they are).
  • 1 SEGMENT FLASHING RED - Thisindicates a displayable error code, the specific error code will bebeing displayed on the TV you have it connected too.
  • 2 SEGMENTS FLASHING RED - The console has overheated.
  • 3 SEGMENTS FLASHING RED - This is the somewhat infamous RROD (Red Ring Of Death).
  • 4 SEGMENTS FLASHING RED - AV cable not detected.
If you have 1 segment flashing red indicating a displayable specific error code then you can identify the fault from the list below.
  • E45 - Update Error.
  • E64, E65, E66 - DVD Drive Error.
  • E67, E68, E69, E79 -Hard Drive Error.
  • E71 - Update Error.
  • E72 - Unknown.
  • E73 - General Hardware Error.
  • E74 -AV cable error.
  • E76 - Unknown.
This is a basic overview of all the fault codes for the XBOX 360, for more in depth information on the faults and how to repair them please see my other tips!
Thanks!
on Mar 25, 2010 | Video Game Consoles & Games
How do i fix x-box 360 e79 error permanently
Error code E79 on an Xbox 360 means you may have a faulty hard drive. This may be due to the hard drive not being connected correctly and can be fixed in a few steps. If, after following troubleshooting steps, the error does not resolve itself, you may need to purchase a new xbox 360 hard disk.
Mar 11, 2012 | Video Game Consoles & Games
Was receiving E68 code on Frigidaire GLEQ2152ES1, replaced circuit board and am still receiving the e68 error code. What else will cause this error?
Hi yoyosam66...
Your e68 error code means:
Please take time to rate me
E68 - Push button does not function
Cause:
Push button held too long or wedged in the control panel. Solution:
Press buttons lightly and release.
Disengage button.
Aug 17, 2011 | Frigidaire GLEQ2152ES Electric Dryer
What does E79 code mean?
E79 is an harddrive error, it may be with the memory unit its self or an internal problem, try removing the harddrive and play a game without it.
Remember thumbs up if this is what you wanted to know.
Jan 28, 2010 | Microsoft Xbox 360 Console
Error codes 68,73,79 games freeze red light lower right corner
<a href="http://xbox-experts.com/errorcodes.php">http://xbox-experts.com/errorcodes.php</a> for the error code list <br /> <br /> e68 <br /> This error occurs when your harddrive is defective, it might still work sometimes.... It can also happen because of a bad eeprom or a wrong security sector.It can also be a problem with the internal connection of the harddrive to the mainboard...According to XBH: Hard drive not DMA configured<br /> <br /> <br /> e73 <br /> This error is caused by a cold solder joint under the GPU, (H)ANA-chip or in between.<br />Mostly it is one of the outer solder balls on the side facing the (H)ANA chip so a shim increases the chanced of success quite a bit.<br />Can also be a component that is missing or damaged so look for missing parts near the GPU and the (H)ANA chip.<br /> <br /> <br /> e79<br /> This error occurs when your harddrive is defective, it might still work sometimes....<br />There is also a small chance that it is a cold joint under the Southbridge causing problems with the I/O of the HDD.<br />It can also be related to wiring the diodes while JTAGGING.<br />Couldn't start xam.xex<br />
Apr 24, 2009 | Microsoft Xbox 360 Arcade
Code E36 and Code E68
hello e36 means control board problem E68 means current leakage to ground on heater or fuse opened
shaun
Jan 12, 2009 | Frigidaire ATF6000ES Front Load Washer
Bought a new hard drive for the xbox 360 ,and after running the upgrade all I get when I turn it on is a system error and a red light flashing on the console
Take a look at the screen you should find a number for the error code there like E80 or E79.
If it is E80 this means that the update went wrong and that the consoles kernel wasnt flashed completely.
This can often be fixed with an NXE update recovery disc, search for it on Google, you can download it from Xbox.com.
If you are getting an error like E67, E68 ,E69, E79 or something similar it will be harddrive related very likely, disconnect the harddrive and try to power the console if the problem is gone get a harddrive replacement, call Xbox Support they will take care of that...
If you should be getting a different error code take a look at this error code list this will tell you whats causing this certain error and how it can be fixed: http://xbox-experts.com/e/errorcodes.php
I hope this helps.
Kind Regards,
Wilhelm@Xboxexperts.com
Dec 25, 2008 | Microsoft Xbox 360 Console
Nooooo
Here is what I found for error code e79:
E79: Hard Drive Error... It could be a problem with the Hard Drive itself or a problem with the internal connection to the hard drive, Try removing the hard drive and playing without it.
According to tmbinc: E79 is the error code if xam.xex could not be started, i.e. probably a file system corruption.
You might want to get in touch with microsoft and see what they suggest to fix this problem.Here is a link to their support site:
http://www.xbox.com/en-US/support/?WT.svl=nav
Apr 08, 2008 | Microsoft Xbox 360 Console
E79
hello Mostafa the E79 means : Hard Drive Error... It could be a problem with the Hard Drive itself or a problem with the internal connection to the hard drive, Try removing the hard drive and playing without it. According to tmbinc: E79 is the error code if xam.xex could not be started, i.e. probably a file system corruption. I whish this solution will solve your problem. MOHAMED AMINE
Aug 25, 2007 | Microsoft Xbox 360 Console
Microsoft Xbox 360 Console Logo
77 people viewed this question
Top Microsoft Video Game Consoles & Games Experts
Stormi  Paulk
Stormi Paulk
Stu Morris K
shaun taylor
Are you a Microsoft Video Game Console and Game Expert? Answer questions, earn points and help others
