Question about Kenwood Audio Players & Recorders
I have a kdc-x759 it worked fine for a while and then i pushed the eject button . the face came down and lost all power. and pushing the reset button doesnt fix it
    President:
  • 624 Answers
These have ribbon cables that go from the display to the main board that must be replaced. If you would like the part numbers let me know and I will post them here. Or you could take it to a service center and have them do it for you. This may be your best option since it will require soldering a connector on the cable which is a very delicate job. It is easy to damage the cable if not done right.
Posted on Feb 06, 2009
Need to get the security code for Kenwood KDC-608OR
ok I just found this info online and they say it came from the service manual for that stereo so I hope it helps:
You will need a Kenwood RC-410 remote control. This remote works on KDC-519, KDC-X859, KDC-319, KDC-4019, KDC-MP919, KDC-X759, KDC-419, KDC-X459, KDC-MPV619, KDC-MPV7019, KDC-2022, KDC-2022V, KRC-435, KRC-535 and KDC-X959
To reset the code do the following:
1) Turn on the car.
2) The faceplate rotates out and the CODE - - - - prompt appears.
3) Press >>' and Auto keys simultaneously on the faceplate and hold for 4 seconds. (If the faceplate rotates back into the console push on the upper left top edge of the faceplate and it will flip back around. Press the Eject button and then try it again.)
4) The screen will still say CODE, but the - - - - will disappear! When this happens press the 5 key on the remote twice and it enters a K on the display on the faceplate. Hit the >>' key on the faceplate.
5) Press the 2 key on the remote three times and it enters a C on the display on the faceplate. Hit the >>' key on the faceplate.
6) Press the 2 key on the remote once and it enters an A on the display on the faceplate. Hit the >>' key on the faceplate.
7) Press the 7 key on the remote twice and it enters an R on the display on the faceplate. Hit the >>' key on the faceplate.
8) The radio goes into All Off mode and you are set! Hit the SRC button on the faceplate to select CD, Radio, etc.
Above information source = http://techbybucky.blogspot.com/2008/01/how-to-reset-security-code-on-kenwood.html
Jun 19, 2011 | Kenwood Car Audio & Video
The kdc-x759 i have one of the wires that the face plate swivels back to for power got bent then broke off. So idont know how to fix it and im not sure what the replacement part would be called? Help...
Just do soldering the broken wires. Check the wires colors ( it should same). Get it re insulated using electrical tape and retry your appliance. Regards, Jay
Jan 23, 2011 | Kenwood eXcelon KDC-X759 CD Player
Head unit will not power up it was working fine and just stopped. Eject button still works?
If its a flip down, or a detatchable face, you can always try cleaning the terminals on the back of the face. If these are dirty, they can causebad connections.
Jan 12, 2011 | Kenwood KDC-MP4028 CD Player
CD will not eject from unit.Word'IN' keeps
you can try either pushing the reset switch (which will be a small indentation either on the face or the subpanel behind the face) or disconnect power to the radio for a few seconds.
Nov 30, 2009 | Car Audio & Video
My car radio jvc won't eject my cd? an need to kow how to?
this is a common problem with this model radio. if it wont eject by pushing the eject button. you can do a hard reset by holdin the SEL button & the POWER button at the same time until the until ejects your disk. OR pushing the SEL button first, then the POWER and holding both until it resets.
hope this helps
Sep 14, 2009 | JVC AM FM CD DET FACE CAR STEREO
Kenwood KDC-119 car stereo problem
There is a small hole at the bottom of the stereo face that will reset the system. I pushed a pen tip into the hole and it turned the stereo off. When I removed the pen, the system turned on and the CD ejected. Problem solved.
Jul 02, 2008 | Kenwood KDC-135 CD Player
CD won't eject....
you need cleaning and maintenance on your radio if you want to eject the disk theres a little tiny button on the face you will need a pin push it in and this should eject your disk
Sep 27, 2007 | Kenwood KDC-215S CD Player
KDC.716S Mech error issue
Try the tiny reset button on the front just below the volume down button.
Nov 10, 2006 | Kenwood KDC-716S CD Player
52 people viewed this question
Top Kenwood Audio Players & Recorders Experts
 Grubhead
Grubhead
Don Hart
Are you a Kenwood Audio Player and Recorder Expert? Answer questions, earn points and help others
