Question about ASUS VW192T Monitor
Connecting DVD player to ASUS vw192t monitor, get 'out of range'
Am trying to connect Pioneer DV-410 v-k DVD player to an ASUS monitor via a HDMI to DVI cable. Briefly get image of Pioneer greeting and if fast enough on the DVD player's controls can get its OSD to appear. This all disappears to be replaced by 'out of range' message on screen. Cannot access the monitor's menu. Suggestions please.
    Sergeant:
    New Friend:
  • 153 Answers
Are you using an adapter with amplifier built in?...or just cables. You cannot just connect hdmi to video in
Posted on Nov 11, 2017
  • 2692 Answers
SOURCE: I recently purchased an ASUS VW193T and the picture is streched
Download and install the driver:
http://www.asus.com/products.aspx?l1=10&l2=87&l3=545&l4=0&model=1686&modelmenu=1
Posted on Jan 24, 2009
SOURCE: I have a ASUS VW192T
I too have the same problem, the only way i found to go around it is too remove the power cable e plug it in again..But anyways, im taking it to assistance today
Posted on Jan 31, 2009
FoxSysTech
  • 23 Answers
SOURCE: input select button to switch between hdmi/dvi/vga
Unless there is simply some dirt or dust caught in it, I would imagine that the button has lost its 'spring' or bounce-back ability which means that either you can take the big risk of attempting to fix it or come up with some other clever way to give it bounce.
Posted on Jul 03, 2009
  • 192 Answers
SOURCE: will not let me update driver for VGA connection
Hi there, welcome to fix ya.
Have you tried updating your mobo/chipset drivers?
Tim
Posted on Aug 28, 2009
lserni
  • 466 Answers
SOURCE: My Asus PG221 monitor suffers from frequent issues
I'm afraid this looks like an electronic fault. Some component, most likely a capacitor, has degraded, is overheating and going out of spec.
You just might be able to squeeze some more hours of work - but the monitor is still likely to drop dead any moment now - by rigging a computer fan on the backside to extract hot air from the inside.
Possibly, the problem might have a noise factor - try adding a ferrite shielding on the cable (unless one is already there, as it often is) and see whether the thirty minutes' grace period extend somewhat.
A probably unsatisfactory solution might be to drive it at a lower resolution, so that the more relaxed frequency constraints do not stress the component so much.
When the capacitor finally blows, you might be able to recognize it and have it replaced; it's likely a US $1 component and is probably in the LCD driver section. Perhaps, just perhaps, you could already be able to see it with the naked eye looking for a component that looks "wrong" - a small cylinder that looks bloated, with electrolyte leaking, whitish powder around the base, etc. But you would still need some solder work to get it replaced - and, if it's a SMD component, chances are it can't be done at home.
Sorry for the bad news...
Posted on Oct 22, 2009
I keep a no connection between DVD player & TV
what is your input connection from DVD player to t v hdmi or avi etc .
Mar 17, 2015 | Pioneer DV-220V-K DVD Player
Tip
Pioneer DVD-400V HDMI Reset Model: Pioneer DVD-400V To switch your Pioneer...
To switch your Pioneer DV-400V DVD player back to an interlaced video mode after selecting a progressive scan mode and losing picture, follow these steps:
  1. Switch everything off.
  2. Switch the player to standby.
  3. Press and hold the Standy/ON button while pressing the |<< button.
This resets your Pioneer DVD-400V player HDMI output format to 480p.
I hope that helps.
_____________________________________
Pioneer DVD-400V Manual Download
Pioneer DVD-400V Interlace Reset
on Jun 06, 2010 | Pioneer DV-400V DVD Player
Tip
Pioneer DVD-400V Interlace Reset To switch your Pioneer DV-400V DVD player...
To switch your Pioneer DV-400V DVD player back to an interlaced video mode after selecting a progressive scan mode and loosing picture, follow these steps:
  2. Reconnect using the supplied video cable (standard RCA Red White & Yellow).
  3. Switch the player to standby.
  4. Press and hold the Standy/ON button while pressing the |<< button.
This resets your player to default video output, allowing you to reconfigure your HDMI settings to 1080i, and then reconnect your HDMI cable.
I hope that helps.
Pioneer dv 333 dvd player HOW TO CONNECT TO PC ?please do reply @ raz1932000@gmail.com
If your PC has an HDMI in/out you should be able to connect it very easily. If you are already using the "out" to go to a monitor, then you may need to get a switcher. Alternatively, depending on the connectors available on the receiver on your Pioneer and the AIO computer, you may be able to use other cable.
Apr 13, 2014 | Audio Players & Recorders
Out of range error
Out of range message means that the video resolution signal the monitor is receiving is not supported by the monitor. How do you hook up the DVD player to this monitor since it does not have composite ot component video inputs?
Spec: http://techwiki.hardwarecanucks.com/product/1NjEyNzUxMzgzMzE/ASUS-VW192T/#spec
http://s807.photobucket.com/home/budm/allalbums
Jun 28, 2010 | ASUS VW192T Monitor
Reconnecting player directly to different TV
Does your TV have input options in the menu?
Dec 21, 2009 | Pioneer DV-366K DVD Player
How to connect BLU-RAY DVD player to Pioneer Plasma TV via HDMI
The best possible solution to your problem is :
Connect your blu ray player directly to the HDMI input of you Plasma and watch HD video....
and connect the 5.1/7.1 sound thru the optical or the coaxial link directly to your AVR 3805.
You will not loose anything on the Blu-Ray.
The sound is best processsed by the AVR3805, while the video, which is the real upgrade (BluRay) in terms of resolution of picture would be processed by your plasma.
Connect and Enjoy
Dec 16, 2008 | Denon AVR-3805 Receiver
Pioneer dv-400v via ethernet?
No, it is not possible to connect a personal computer to the DVD player.
http://www.manualnguide.com/dl/4791/ Page 31
Apr 08, 2008 | Televison & Video
ASUS VW192T Monitor Logo
199 people viewed this question
Top ASUS Computers & Internet Experts
Alun Cox
Marvin
Marvin
Are you an ASUS Computer and Internet Expert? Answer questions, earn points and help others
