Question about Dell Inspiron 9100 XPS Latitude D400 Latitude D505 CDRW/ DVD Combo - C0932 CD-ROM Drive
A hardware fault
Hi there
I have a dell 9100 xps
This laptop will run fine 24/7 when it is running on the power pack.
It has a brand new battery, but when running on battery for more
than about 5 minutes it will just shut down, like blink your eye and its off.
I hope you can help thanks
Have a nice day
  • 558 Answers
The battery may not be fully charged here is a simply fix use a toothbrush and clean the contacts on the battery and on the computer itself,check also that the blower vents are not blocked and you have good air flow.try again time it see how long it last.Failing that you might have a failing battery.
Good luck
Posted on Sep 10, 2009
Dell Xps 15 Laptop Battery Not Charging
If your battery will not charge, you need to run a test on some components on the laptop. The battery, the charger and the laptop itself. Once you detect the faulty conponent then you replace it with a new one.
To test the battery:
1.Power off the laptop,
2.Take out the battery,
3.Insert it in another laptop,
4.Check of it will charge,
If the battery holds a charge there, then it means the problem is not from the battery, but if it does not hold a charge, then it means the battery is defective and need to be replaced with a new one.
To test the charger:
1.Unplug the charger from the present laptop,
2.Connect it to another laptop to see if it will charge.
If it charges the laptop, then it means the charger is alright, and if it does not charge the laptop, then it means the charger is bad and need to be replaced.
To test the laptop:
1.Turn off the laptop,
2.Disconnect your present charger,
3.Remove your present battery pack,
4.Insert a well tested battery into the laptop,
5.Connect a well tested charger to the laptop.
If it powers on, then it and charges, then it means the laptop is working fine, but if it does not charge, then it means the connection port of the laptop is bad.Hope this information was helpful.
Dell XPS 15 AC Adapter Charger
Nov 01, 2012 | Dell XPS Computers & Internet
Battery installed power shows but not charging battery, new battery and charger. thanks.
Its a common issue for DELL Laptops usually if the battery and charger are working fine the culprit is the motherboard. If its still under warranty have them replace the motherboard and it will be good as new.Thanks
Feb 08, 2011 | Dell Inspiron XPS Series Notebook: XPS...
Check that all drivers are up to date... I had the same thing happen to me. NVidia has a newer driver that might help u out. Also unplug the laptop and remove the battery. Hit the power button a few times to ground it out.
Plug only the power cord in and open up command prompt. As administrator run a chkdsk to possibly find the problem...
For me it was the driver! Good luck
Nov 09, 2010 | Dell Computers & Internet
Black screen - Dell XPS laptop - VISTA OS
In this case I would suggest you contact Dell in case you still have a warranty on your laptop.
Sep 29, 2009 | Dell XPS M1210 Notebook
Inspiron9100 charges the battery, but does not run off it
you've got a dead cell in the battery pack. Replace the cell (there're howto's dotted around the web) or replace the battery pack.
Jul 21, 2009 | Dell Inspiron 9100 Notebook
Run MS Vista on Dell 9100
The reason they told your daughter that is because either there isn't a powerful enough CPU and enough memory to support it and also there are no vista drivers for that laptop on Dell's website.
If you decide to put vista on that laptop your going to need to make sure that whatever hardware drivers vista doesn't detect, you'll need to search on the net to find vista compatible drivers if they are out there, it will be time consuming.
My recommendation from my own experience, make sure you have at least a 2GHz processor and 1GB or memory.
May 18, 2009 | Dell Inspiron 9100 Notebook
Dell inspiron xps 9100 cpu upgrade
Highest compatible cpu for your system is the Pentium 4 3.6 ghz Prescott. Hope this helps & please rate this solution fixya. Thanks.
Here is a link to a spare parts supplier for your system:
Feb 04, 2009 | Dell Inspiron 9100 Notebook
Replacement adapter will not charge battery
Did the old one do the same thing? If true, your battery sounds like it is dead.
Jan 17, 2009 | Dell Inspiron 1501 Notebook
Acer Laptop Aspire 5050
Hi, you can do a simple check to establish which is at fault, your battery or power pack.
If your computer runs OK on the power pack then the battery is at fault. If the computer will not run on the power pack then the power pack is the cause.
Regards mistyman
Aug 14, 2008 | Acer Computers & Internet
Problems with Dell Inspiron 6000 Battery ? DELL Inspiron 6000 laptop battery is popular, why ?
You can also pick up the batteries less expensive than most computer places at batteries plus. And yes it sounds as though it is the batteries charge is getting low, especially if it runs fine when the battery is out and you have it plugged in.
Mar 13, 2008 | Dell Inspiron 6000 Notebook
Dell Inspiron 9100 XPS Latitude D400 Latitude D505 CDRW/ DVD Combo - C0932 CD-ROM Drive Logo
60 people viewed this question
Alun Cox
