Question about Epson DFX-8000 Matrix Printer
Dfx 8000 not printing
Two beeps and the printhead getting stack.
    Novelist:
    Champion:
  • 254 Answers
Check the printhead guide bar for proper lubrication- light oil similiar to 3 in 1 will work. Check for any printhead cabling catching on something as the printhead moves back and forth. If error beeps are occuring immediately after turn on, and unit will not print, this might indicate a sensor problem, such as paper sensor, head home position sensor or another error condition of some sort.
Posted on Apr 09, 2007
Printer jams, printhead gets stuck and won't slide back or forth
try getting some machine oil and put a small amount on a tissue and rub onto guide bar .
Mar 28, 2016 | Epson DFX 8000 Matrix Printer
Printer dot matrix epson dfx 9000
Wonder if it needs oil on its moving parts like to bar it travels back and forth . try a small amount of machine oil on a tissue and rub tissue on bar
Oct 15, 2015 | Office Equipment & Supplies
My DFX8000 printer not printing, but head is moving and giving printing sound all so. i Chang ribbon, and printer head all so but problem is still same, and i Chang my DFX 8000 printer head to one of my...
Hello, do you know how many text characters did the printhead printed? It may have been printed over 15 million characters and the pins are worn out.
A refurbished printhead is about 320 US$
Regards.
Dec 29, 2017 | Office Equipment & Supplies
My DFX 8000 Printer head is moving, but it is not printing, ribbon and head is OK. i change the head and ribbon but problem is same.
Thanks, I Try it. but it is still not printing, because printer head pins
are not coming to the paper. Head pins printing sound is coming.
thanks
Aug 13, 2013 | Epson DFX 8000 Matrix Printer
Prints one side faded one sige legible the other side as if the printhead has a problem
Epson Dot matrix DFX 8000
Due to printer head firing is not proper.
The Prnter need servicing and once serviced it will be alright.
Sometimes the Printer Ribbon might have not rotating and the print will not be visible on the left and at right side it is bright.
Better consult the local printer hardware enigneer and settle this iseeu.
Put the original and best gsm paper in the printer, when prining job is iniated.
Jul 20, 2009 | Epson DFX 8000 Matrix Printer
Print heads for dfx 9000
if you replace the printhead and dont change the alpha an beta value, your printheat was damage shortly
Feb 05, 2009 | Epson DFX-9000 Matrix Printer
Canon ipf 8000 print head problems
You need to boot the printer into service mode.
Hold down the roll/source button and the info button while you are powering on the machine.
This should get you booted into the service menu where you can then access the replace printhead function
When you have successfully replaced the printhead, reboot the printer to get out of service mode,
You may also want to check the firmware version of your printer and update it.
Updates can be found on the Canon website
Dec 22, 2008 | Canon imagePROGRAF iPF8000 Printer
Line feeds
Hi-
When you said line feed do you mean the Top of form?
hope this helps
1. Make sure the printer is turned on and the desired tractor is selected (the corresponding tractor arrow should be lit).
2. Open the upper cover.
3. Press the Top of Form button to enter top-of-form mode. The printer beeps once, and the Top of Form light turns on.
4. Use the Micro Feed buttons to feed the paper to the desired top-of-form position. The “A” on the ribbon protector shows you where the bottom edge of your first line of text will print. This position is based on the first printable line of text. If your software inserts a top margin of five lines, your text will actually print five lines below the top-of-form position.
5. Press the Top of Form button again to exit and save your new top-of-form position. Then close the top cover.
Keep me posted if you have inquiries, thanks!
Jun 18, 2008 | Epson DFX-9000 Matrix Printer
Request
This error OE is linked with the Print Head Driver.
2 solution:
1- Check the print head cables (continuity, shortcircuit, connection etc..
2- Print head Driver on the Main Board is out of order > Change the Main Board.
Mar 17, 2008 | Epson DFX-9000 Matrix Printer
Epson DFX-8000 Matrix Printer Logo
214 people viewed this question
Top Epson Office Equipment & Supplies Experts
Inky Fingers
Inky Fingers
Clive
Clive
Alun Cox
Are you an Epson Office Equipment and Supply Expert? Answer questions, earn points and help others
