Question about Water Heaters
Lighting Instructions for a Bosch Junker Water Heater
The instructions have faded and I dont have a manual.
  • Ray Coon May 11, 2010
    Is this a tankless gas water heater?
    Which Model #
    Model number and serial number should be somewhere on the unit.
  • Philip Scarborow
    Philip Scarborow Aug 17, 2014
    it is a tankless automatic flow ignition water heater
  • 88 Answers
Go to this site, have your model number at hand.
http://www.boschhotwater.com/HelpfulResources/BrochuresManuals/
Posted on Apr 18, 2009
Setting clock on greenstar 24i junior optional programmer
Following manual has set up instructions:
http://waterheatertimer.org/pdf/Greenstar-12-24i-set-up.pdf
Starting at Page 31 of following manual has same instructions:
http://waterheatertimer.org/pdf/Greenstar-12-24i-Installation-Service.pdf
If you need further help, I’m available over the phone at https://www.6ya.com/expert/gene_9f0ef4df2f9897e7
Oct 25, 2017 | Water Heaters
How Do I Make A Dippy Egg On My Cliford James Egg Boiler I Dont Know How To Use The Measuring Device As I Dont Have A Manual
Google the Make/Model number of your machine and you can probably find the owner's manual online.
Nov 04, 2016 | Water Heaters
Can i get a manual on a bosch gruppe water heater
Having problem finding one. Is there a model #?
Also what are you trying to find out? as sometime googling the problem finds a solution faster than googling manual.
Nov 25, 2015 | Bosch Water Heaters
Ignition problem
Sometime the batteries in the drawer fade (yes even new ones). I am asking, is that after the flow initially stops, the Automatic Start will not fire up when there is a demand for hot water (Is this what you meant when you say "The water is turned off" and "Then on again". Check the batteries for being the right way around (I Have installed them 1/2 forward and 1/2 back ward as a set, the one cancelled the other one out....my Bad....Ooops) The battery should be only needed if the power fails, but not sure about this model. Does the Owners manual say anything about no hot water? IF that was tried, you may need to call the heating / cooling techs that are familiar with this unit.
Nov 30, 2014 | Marey Heater Corp Marey Natural Gas 2.0...
I have a honeywell rth110b thermo and the other day I noticed that the display was fading and it looked like the battery icon was showing so I changed the batteries and now the display is completely blank...
The manual does not have troubleshooting steps.
Check the battery polarity, and clean points of connection.
Otherwise honeywell.com has customer care number
Oct 07, 2017 | Water Heaters
Hi... im at a friends home and am in need of help with the water but cant find an operations manual. The top pilot switch was set to off and the bottom temp control was on vacation. Am i able to just...
Identify gas control valve, with instructions for lighting each type... these instructions also show on side of water heater.
http://waterheatertimer.org/How-to-troubleshoot-gas-water-heater.html#intellivent
Knob rotated to off...means pilot light is off, and water heater is off.
Read instructions shown with each gas control valve shown on link above.
Don't forget that gas supply to water heater has to be ON. Gas shut off valve must be parallel with gas line.
http://waterheatertimer.org/images/Gas-water-heater-89a-350.jpg
Gene
h
Sep 19, 2013 | Water Heaters
Can I replace the igniter on my rheem water heater RHLP
1) Rheem does not post service manuals for their brands of tankless, or tank-type water heater:
http://waterheatertimer.org/Troubleshoot-Rheem-Tankless-water-heater.html
Replace the thing:
http://waterheatertimer.org/How-to-install-gas-water-heater.html#install
2) Probably you can call Rheem and give model and serial number and they will send part.
However, based on responses at fixya, Rheem most likely will not send instructions.
Rheem does not want customers repairing gas appliances.
http://waterheatertimer.org/images/Exploded-house3.jpg
3) Go to Bosch website, and track down their service bulletins for possible assistance
http://www.bosch-climate.us/bosch-hot-water/aquastar-service-bulletins/
Mar 17, 2013 | Water Heaters
AE-9.5 Bosch Tankless Water heater - no manuel or installation instructions
This is a "point of service" tankless water heater that was manufactured by BOSCH. BOSCH is now Bosch-Climate.us. Technical support is available at 866-330-2729. P.S. check this site: http://tanklesswaterheaterz.com/bosch-ae-9-5-powerstar-1-5-gpm-point-of-use-indoor-tankless-electric-water-heater-reviews/
Feb 02, 2013 | Bosch AE-9.5 Electric PowerStar PowerStar...
7-25-11. Purchased Reliance 909 model 950 GKRT 200 natural gas hot water heater. 7-31-11, installed said hot water heater according to instructions and code, filled with cold water and checked for gas and...
The problem requires looking at manual and service handbook, except handbook doesn't show most recent water heater.
My first check point would be gas supply, and then vent draft, and then air supply.
Take off front cover and try lighting again to make sure air supply is not problem.
Review lighting instructions.
If there is no gas, and gas is turned ON, then gas control valve is suspect.
On-line manual for Reliance 909 gas
http://www.reliancewaterheaters.com/lit/om/manuals/186486-002.pdf
Reliance 2006 service handbook:
http://waterheatertimer.org/pdf/Reliance-2006-Service-Handbook.pdf
Other resources:
http://waterheatertimer.org/How-to-install-gas-water-heater.html#troubleshoot
http://waterheatertimer.org/images/Test-water-heater-vent-1400.jpg
http://waterheatertimer.org/images/Water-heater-in-attic-800.jpg
Jul 31, 2011 | Reliance Natural Gas Water Heater Control
How do you relight the pilot light after it has blown out or the gas supplied has been turned off.
Instructions for relighting pilot on Tankless water heater are in the product manual:
Model number is on label located on side of unit.
Open following link to help identify product and download possible manual:
http://waterheatertimer.org/Troubleshoot-Bosch-Tankless-water-heater.html
For tank-type water heater, the lighting instructions are usually printed on side of tank in addition to the product manual.
Find the model number and re-post question with as much information as possible for more assistance.
Jul 30, 2011 | Bosch Water Heaters
Water Heaters Logo
3,106 people viewed this question
Top Water Heaters Experts
Paul Carew
Gil Shultz
Are you a Water Heater Expert? Answer questions, earn points and help others
