Question about Whirlpool Calypso GVW9959K Top Load Washer
F5 error on Whirlpool Accubake Range
When turning on the oven, Whirlpool Accubake Sytems Super Capacity 465, the oven shuts off after 3 minutes and gives me an error message of F5. How do I correct this problem and get my oven working?
  • 25 Answers
1. If door latched:
a) Disconnect power from unit.
b) Check wires and connectors from control to door switch,
then from door switch to control. If no damage to wires
and all connectors okay, proceed to step c.
c) Replace door switch.
d) Re-apply power to unit and verify operations.
2. If door not latched:
b) Check wires and connectors from control to latch switch,
then from latch switch to control. If no damage to wires
c) Repeat steps a) and b) for door switch.
3. Measure door switch (door open = switch open small low
voltage terminals).
4. Measure latch switch (unlatch = switch open. NOTE: Oven
light contacts are closed).
5. If corrections are made in any step, reconnect control to
verify correction.
6. Check door alignment.
7. If failure remains, replace control.
Posted on Dec 22, 2008
Whirpool gas stove super capacity 465 the stove works but cant get the oven to work
whirlpool super capacity 465 accubake system gas stove with auto starter - oven worked fine the previous night the next day will not do any thing any help out there?
Jan 16, 2010 | Ovens
My Whirlpool Accubake super capacity 465 self-cleaning oven does not work. When started E1 -F5- appears on screen. Model# RF 386 PXGO. Serial# RJ0525903.
The E1- F5 error is a door lock error.
The control (TIMER) has likely failed in this instance - BUT...
Sometimes when you disconnect power to a range and reconnect it the electronic range control gets confused.
You should disconnect power again for 15 seconds and reconnect and see if that helps.
If it doesn't cure the E1- F5 error hold the bake button in until E0- F2 appears in the display.
This is the error for a stuck button on the keypad and is the way to clear the memory of the electronic range control.
Sometimes these work, but if the control has failed it won't make any difference.
Thanks for using FixYa - a 4 THUMBS rating is appreciated for answering your FREE question.%#FDG
Jan 02, 2010 | Whirlpool Accubake RF362LXTT Electric...
Have Whirlpool Electric Range super capacity 465 with accubake system. Turn off power to stove to clean oven and back of stove. Finished cleaning and turned power back on and get this beeping sound every...
Thanks for using FixYa - a 4 THUMBS rating is appreciated for answering your FREE question.$%^TF
Sep 24, 2009 | Whirlpool 30" Self-Cleaning Freestanding...
Whirlpool Accubake Super Capacity 465 gas range. Oven won't light
Some gas ranges may take 10 or so minutes to light.
Other than that you may have a defective glow bar ignitor.
If it glows and does not light the reistance in the ignitior has failed.
Feb 25, 2009 | Ovens
i dont know want is wrong with it when i turn the oven on it keeps saying e2 and f3 i dont know what that mean please help me one on .... :(
Dec 05, 2008 | Whirlpool SF357 Gas Kitchen Range
Whirlpool Super Capacity 465 Gas-pilot light won't stay lit
I have a whirlpool accubake system / super capacity 465 oven ... the top burners do fine...but my oven pilot went out... and I don't know how to re-lite the pilot... the owners manual doesn't help ... it doesn't show anything a layman could understand ... no visual illustrations ... when I turn on the oven ... the display shows that it's been activated... it clicks a couple of times but does not light ... what is a simple way to re-light the pilot? thanks, A
Nov 25, 2008 | Whirlpool SB160PEE Gas Single Oven
LOCKED
Try unplugging it, wait for one minute and plug it in and try to start it up. Good luck.
Sep 06, 2008 | Whirlpool SB160PEE Gas Single Oven
Whirlpool Accubake oven super capacity series 465
Press and hold the Broil button for 5 seconds. You will see the c change to f. THen change the temp to what you need.
Dec 21, 2007 | Whirlpool Calypso GVW9959K Top Load Washer
Whirlpool Calypso GVW9959K Top Load Washer Logo
611 people viewed this question
Dan Webster
Dan Webster
Sal De GO PATS
