Question about Protron PLTV-32 Television
Speakers are clicking all the time
Clicking
  • ssayles2 Jan 20, 2009
    I recently moved to a new location and suddenly my Protron 32 inch LCD started to have loud static (or clicking) sounds. It only occurs when I first turn on the set for the HD channels but the loud static noises remain for anything outside of those channels. I really do not want to purchase a new TV. What is the cause and how do you fix it? What do you mean "a new power source?" I have cable, a surge protector and a plug--what's to change?
    Thanks for your time
    Problem Solver:
  • 7 Answers
Needs a new power supply
I have for sale
Posted on Dec 27, 2008
Fault F96kHz
turn the audio down from the TV seems as if its overdriven, disconnect speakers , if no clicking, you have a speaker problem
Mar 04, 2014 | Kenwood Audio Players & Recorders
I would like to reinstall my speakers to my dell computer somehow they have been removed? Bar Code CN0D3431 48220 49T 06J3. I know longer can locate the installation disk?
There are a few simple things to check first:
Make sure your computer has a sound card.
You must be logged on as an administrator to perform these steps.
  1. Open Device Manager by clicking the Start button 4f6cbd09-148c-4dd8-b1f2-48f232a2fd33.png, clicking Control Panel, clicking System and Maintenance, and then clicking Device Manager. 18abb370-ac1e-4b6b-b663-e028a75bf05b.png If you are prompted for an administrator password or confirmation, type the password or provide confirmation.
  2. Expand the Sound, video and game controllers category. If a sound card is listed, you have one installed. If no sound card is listed, You will need to install one. See Install or remove a sound card.
  3. If there is a yellow question mark next to the name of the sound card, there might be a problem. Right-click the name of the sound card, and then click Properties.
  4. Click the General tab, and then look in the Device status box to identify problems with the sound card.
  • Make sure your speakers are plugged into a working power source and turned on.
  • Make sure your speakers are correctly connected to the computer.
    On your speakers, find the cable that plugs into your computer. Make sure that the speaker cable is plugged into the speakers and the correct jack on the computer. For example, if the cable is a 1/8 inch cable, there should be a round jack for it on the back of the computer. If it is a universal serial bus (USB) cable, it will plug into any USB port on your computer.
  • Make sure that the speaker volume is not muted or turned down too low.
    1. Open Volume Control by clicking the Start button 4f6cbd09-148c-4dd8-b1f2-48f232a2fd33.png, clicking Control Panel, clicking Hardware and Sound, and then, under Audio Devices and Sound, clicking Adjust system volume.
    2. Under Main Volume, move the slider up or down to raise or lower the volume.
    gl_ico.png Note
    Some mobile PCs have an external volume control on the outside of the case. If you're using a mobile PC, check the external volume control.
  • Make sure your headphones are not plugged into the line out (headphone) jack of your sound card or computer (unless you want to be listening with headphones rather than speakers). When you plug in headphones, most computers automatically cut the sound to the speakers.
Mar 14, 2011 | Dell A215 Computer Speakers
How to hook-up speakers to xp7
Here is the solution for you.Please follow the below steps and fix your problem.
1 . Click on the "Start" globe or button and then the "Control Panel" label. The Control Panel main screen will display on your monitor. Click on the "Hardware and Sound" link.
2 . Click the "Manage Audio Devices" link in the "Sound" section on the Control Panel screen. The "Sound" configuration window will then open.
3 . Click the "Speakers" label under the "Playback" tab. Click the "Configure" button to open the "Speaker Setup" configuration window and select the "Stereo" option. Click the "Next" button.
4 . Enable the "Front Left and Right" option box by clicking the check box. Once the check mark appears in the box, click both small speaker icons to test the sound from the speakers. You should hear sound from the two right speakers when you click the speaker icon labeled "R," and the two speakers on the left should produce sound when you click the icon labeled "L."
5 . Click the "Next" button and then the "Finish" button to complete the speaker setup.
6 . Adjust the volume by clicking on the speaker icon near the time and date area in the task bar. Use the slider control to adjust the volume to the desired level.
Thanks.
Dec 24, 2010 | Dell A215 Computer Speakers
Clicking sound from Dell Speakers
How "often" does it click?
Internet Explorer does a "click" everytime you access a new web-page -- turn your speakers up/down to increase/decrease the sound.
Apr 25, 2010 | Dell 5650 Computer Speakers
Makes an loud clicking/popping sound
The audio outputs are intermittently shorting to their supply and allowing DC voltage to pass - the speakers will be damaged if it continues. you can confirm this by measuring (with a dc voltmeter)at the speaker outputs for DC volts.
Sep 19, 2009 | Sony STR-DA50ES Receiver
There is no sound on my computer
1. Open Device Manager by clicking the Start button , clicking Control Panel, clicking System and Maintenance, and then clicking Device Manager.‌ If you are prompted for an administrator password or confirmation, type the password or provide confirmation.
3. Right-click the name of the sound card, and then click Properties.
1. Open Volume Control by clicking the Start button , clicking Control Panel, clicking Hardware and Sound, and then, under Audio Devices and Sound, clicking Adjust system volume.
NoteSome mobile PCs have an external volume control on the outside of the case. If you're using a mobile PC, check the external volume control. • Make sure your headphones are not plugged into the line out (headphone) jack of your sound card or computer (unless you want to be listening with headphones rather than speakers). When you plug in headphones, most computers automatically cut the sound to the speakers.
thank you
Dec 23, 2008 | E-Machines eMachines Desktop PC
Panasonic SC-PT467 Wireless speakers Clicking
I had this exact problem. The clicking is something to do with interference from the power supply cable. It seems that facing the wireless unit in the most obvious way ensures that the power cable and the right speaker cables cross. All I did was turn the unit around so that the wires no longer crossed and magically the clicking sound disappeared forever!!!
Good luck !!
May 28, 2008 | Audio Players & Recorders
Receiver making alot of clicking noises.
I Have a son STR DE 845 and the speakers make a popping sound when it is in DTS mode what is the problem.
Thanks,
Larry
Jan 20, 2008 | Sony STR-DE845 Receiver
Clicking sound
Time to change speakers speaker coils burnt
Jan 07, 2008 | Bose Cinemate Digital Home Theater System...
Clicking noise in speakers
Periodicaly I would have a clicking sound coming from my lcd about every ten- thirty seconds. I wondered why the sound go and return for weeks days or months at a time. well, the common denomenator was my offspring not using the remote to adjust the sound, so the cable box had one sound level and the tv was set at another level-- Hence the clicking. When we sequenized the volume, all clicking left for good.
hope this works for you!!!!
Nov 21, 2007 | Samsung HLN5065W 50" Rear Projection...
Protron PLTV-32 Television Logo
53 people viewed this question
Top Protron Televison & Video Experts
Jaime Hernandez
Are you a Protron Televison and Video Expert? Answer questions, earn points and help others
