Question about Dryers
My whirlpool dryer starts when you shut the door
  • Dryers Master
  • 8,220 Answers
Replace the start switch. It is stuck.
If you need further help, reach me via phone at https://www.6ya.com/expert/dan_73bbd84fe1d95b61
Posted on Dec 22, 2008
My whirlpool dryer wont start, I replaced the start switch and the door switch seems fine. I hear a ticking noise
The door switch may not be making contact. All dryers also have a High Limit thermostat that shuts down the dryer when too hot. The high limit thermostat should reset when the dryer is cooled off but may be defective. If the dryer is electric, 110 volts run the drum motor, and the other leg of the 220 line is for the heating element.
May 05, 2014 | Whirlpool Dryers
Whirlpool dryer LER7646E02 will not turn on
Could be something as simple as a broken belt or door switch is broken. Open top and check if the belt is still in tact. If yes, then check door switch to see if electrically closing when door is shut (check resistance with power off).
Jan 11, 2014 | Whirlpool Dryers
My whirlpool duet dryer will not start. Power
You have to slam the dryer door shut. Sounds silly... but it worked. Guy said it has to do with it being stacked??
Jan 11, 2010 | Whirlpool GEW9250 Electric Dryer
I press the start button, but the dryer will not start.
ok open the dryer door look for a button inside where door shuts against hold that button down with other hand spin the dryer have some one push start button let it run for a sec then shut door and it should start
Dec 23, 2009 | Whirlpool LER4634J Electric Dryer
Whirlpool LER8620 electric dryer, shuts off at random. When it
Whirlpool Dryer Won Start
Sounds to me like a thermal fuse. The link gives you multiple scenarios and you can even order replacement parts. I have used it myself with success on washers and dryers. Good luck!
Sep 13, 2017 | Whirlpool LER7646E Dryer
Dryer wont work!
A couple suggestions: (1) The switch in the front may be bad. It's the switch that turns the dryer off when you open the door. (2) Make sure the door latch keeps the door shut. If it is worn and the door isn't shut tight, the switch will not let it start. Hope this helps.
Oct 15, 2008 | Whirlpool LER5636P Electric Dryer
Dryer starts on it's own when timer is turned or door is shut
its the door switch more than likely are less likely the push start button stuck
Mar 16, 2008 | Dryers
Dryers Logo
Top Dryers Experts
Marvin
Marvin
Craig Butler
Craig Butler
