HOW DO I TAKE MY DESK TOP COMPUTER BACK DWN TO FACTORY SETTINGS?
  • CyberdorkX
    CyberdorkX May 11, 2010
    There are several different types of factory settings.
    What exactly are you trying to achieve?
    President:
  • 2,692 Answers
If you are talking about the  BIOS settings, go into the setup routine  and change the settings to the default or safe settings and then save them. If you are refering to software go to the Windows  RESTORE and restore your computer to the earliers date that it will alow you to do. If your computer came with a restore disk, or restore function Run it.  I hope this helps.
Posted on Dec 22, 2008
How to go back to factory settings for my HP Pavilion Desk Top computer p6-2020a. and use my original *********** for windows 7 Home Premium OA
That might not be possible if the restore partition has been deleted or removed.
Press F8 as the computer is just about to boot and if it is intact, select restore.
Feb 10, 2017 | Miscellaneous
Want to know how to take desk top back to factory settings
hi! refer to this link:
http://www.ehow.com/how_4926884_restore-dell-dimension-factory-settings.html
Nov 23, 2013 | Dell Dimension B110 PC Desktop
I installed the following graphics card in to my Dell Optiplex 620 desk top after connecting the computer back together i was given the following error "READON X600 SE P/N 620 113-a26044-108 BIOS". I was...
Enter the bios by pressing F2 during the first seconds of the boot. Then look for "restore to factory settings".
If that doesn't work the look for the graphic/monitor settings and try to change settings.
Good luck and let me know how it goes
Oct 18, 2013 | Dell Computers & Internet
I forgot my password on my desk top computer its an older gateway running windowsxp. how do I reset my password or restore the computer to factory settings?
Just take out its bios battery [back-up lithium battery; disc type]; thus disable the bios memory. The re-insert the battery. All bios settings will be lost, but no data loss will occur. You have to re-set the bios settings, by holding F1 button during startup.
Aug 23, 2013 | Gateway Computers & Internet
Why won't my COMPAQ PRESARIO SR2032X desk top
Please turn off the computer, start hitting F8 at the start-up and then choose last known good configuration. If this does not work, choose Safe mode options.
If still does not work, please try to restore the computer to factory settings. You can try to hit F11 or F10 at the startup to initiate recovery.
If not working, please tell me what error message you get on the screen.
Jun 01, 2013 | Computers & Internet
Reset sony vio pcv f11m to factory settings
Sony desktop computers can be placed into factory restore mode by shutting them completely down, and then pressing the VAIO Assist button to turn it back on. Follow the on-screen menu to get to the restore mode that resets to factory state.
Mar 01, 2012 | Sony VAIO PCV-RZ44 (PCV-RZ44G) PC Desktop
I have D-link router hooked up to desk top computer and then the wireless laptop has not problem but my son has a netbook that when he goes on line I lose my connection to D-link and have to reboot in...
Take away your son's netbook.
The final solution is a factory reset of your router. You can do a factory reset by logging into the router using you browser. Go to the settings and perform a factory reset
If you forgot the router password, you ill have to do a factory reset by locating a small hold on the back of the router and insert the tip of of paper clip for about 10 seconds while the power is on. The router will be reset to out of box status and then you can set-up form scratch.
Feb 13, 2011 | D-Link Dlink DI-514 Air Wireless 2.4 GHz...
I could not get my sylvania netbook to connect to my wifi so i download the update from their website to a SD card then opened on the netbook and it deleted everything on the netbook. how can i restore it...
I do not know why your icons disappeared by running the Download, but your programs are still in the on board ROM memory and what you are missing are your desk top icons. I have tried to duplicate your download problem but so far have not been able. I know that using a SD card will not download a usuable file so I used a thumb drive.
Any way please read the following solution that I wrote to another poster.
If you have deleted the icons for those programs on your desk top, then they may be in your Recycle trash bin. double click on Recycle Bin look for the icon for recorder, right click on recorder and select restore. You really cannot delete the programs from your machine as they are retained in a ROM chip , hard coded into the chip and are loaded each time you cut your machine on. The only thing you can do is delete the icons on the desktop, which are sent to the recycle bin.
To retore the machine to factory settings, there is a small hole just about an inch down from the data plate on the back. Using a pencil point or a straightened paper clip, insert the bject into the hole and hold for about 5 seconds. Your deleted icons are not replaced.
A second method to restore your icon is to click on my computer right click on the recorder, select copy, dismiss my computer, find a blank spot on your desktop and right click on that spot, select paste, and a dos type icon appears as your recorder button. When you cut the machine of and back on the Dos type icon is replaced with a CE type icon
To restore all icons:
You can: If you can click on start, click on run, type desk top into the open space and ok it. your icons should be shown. you will have to copy and paste each one back to your desk top, or select edit and then select select all, then click on file, select send to, and select desk top as short cut. Reply
Dec 12, 2010 | Sylvania G-Netbook
Bios setting problem
This happens because Windows is corrupted.
You need to start the computer with a windows install disk, or a factory recovery disk inside to reinstall the system.
Get a windows install disk and reinstall the system.
Nov 17, 2008 | Computers & Internet
Computers & Internet Logo
Alun Cox
David Payne
David Payne
