Upper right - where green light comes on when you hit "caps lock"
I have a green light that stays on. It is the first in the series.
    President:
  • 1,179 Answers
Depending on your keyboard it could be scroll lock, caps lock, or num lock is on. You can turn them off by depressing the appropriate keys on your keyboard until you find the one that turns the light off. Hope this helps.
Posted on Dec 22, 2008
Why do all indicator lights come on when i hit a bump in the road?
check wiring where you was replacing items make sure everything you unplugged is back right and not melted to motor
Jul 22, 2014 | 1999 BMW 5 Series
Logitech MK300 Keyboard Ido not know when CAPS are on or off
there should be three lights just to the upper right of the keyboard. experiment abit with your caplock key and watch the lights. Caplocks on for my particular keyboard is the center light as it seems to be on must keyboards.
Jun 22, 2011 | Computers & Internet
There are three lights on the upper right hand side of the keyboard. I know number lock and caps lock, what is the third light and what keys did i hit that made it go on? How do I turn it off?
The third light on your keyboard is normally the scroll lock, the key to enable/disable this function is the Scroll Lock key which is located above the Home key.
Mar 03, 2011 | GE Power Keyboard (97798)
Turn monitor on and the light stays yellow will not turn green and screen stays black
When it lights up the yellow light instead of the green one, that means that the monitor is not getting a signal from the computer.
The things to try (from simplest to most complex) are:
  1. Make sure the computer is on and not in "sleep" mode -- press the "Caps Lock" key and see if it lights up the caps-lock light on the keyboard.
  2. Make sure the video cable is connected from the computer to the monitor (that the cable hasn't come loose on either end)
  3. If your monitor has multiple inputs, make sure it's set to the right (probably analog VGA or DVI) input
  4. If your computer has more than one video output (like a laptop with it's internal screen plus the external monitor) then make sure the external monitor is enabled
If none of those solve it, post a comment back here and we can dive in to the more complex tests
Sep 06, 2010 | Computers & Internet
Hello, When typing on my Mo Droid if I want my caps to stay on how do I get that to work.....I tried holding it down but maybe I am not doing it properly?
If you are typing using the touchscreen, the upper-case arrow, touched once, will upper-case the next letter you type and then back to lower case. It you touch the upper-case arrow twice in a row, you should see a green light come on directly over it. That keeps the caps lock on.
If you are using the slide-out keyboard, touch the upper case key once and you should see a triangle underneath the cursor on the screen. That will upper case the next letter you type. To get it to stay in upper case, hit the upper case button again and the triangle should change to a > symbol, point up, underneath the cursor. That should keep it in upper case mode. Don't hold the upper case button down, as that won't do anything. A third press returns it to normal (lower case).
Jun 14, 2010 | Motorola Mobility Droid (2 GB) Cell Phone
Don't know how to unlock caps lock
There shoudl be a Caps Lock button on your keyboard....look on the left side of your keyboard between the Tab and Shift buttons.
Also, one way to see if your Caps Lock is on is to look on your keyboard, typically in the upper right hand corner and look for a light eminating from your keyboard and it should look like the letter A inside of an image of a palock, if the light is on then Caps Lock is on, just hit the Caps Lock key to turn off.
Apr 24, 2010 | Microsoft Troubleshooting Your Web Page...
There is no Caps Lock light on the keyboard. The instructions say there should be a symbol on the Windows taskbar for keyboard modes such as this but I can't see it.
off to the right on the top. if u press your caps lock on the left in the middle of the keyboard. light should come on at upper right above the number keys.
Mar 09, 2010 | Compaq Keyboard
Top right of keyboard next 2 the green light that comes on when ian in caplocks is another green light thats on whats it 4 ty
The lights are as follows from the left... Num(ber) Lock, Cap(ital) Letter Lock, Scroll Lock.
Feb 11, 2010 | Computers & Internet
Maytag Quiet Series 300 Legacy Series Dishwasher
Mine was doing the same thing and I just pressed and held down the heated dry button until the light went off. Then I was able to start my machine as usual. Hope this works for you.
Mar 12, 2009 | Dishwashers
Lock switch stays on
The light goes on to indicate that the shift lock is engaged, so all letter type in upper case (capital) letters, or on machines with "spell check" to indicate a mis-spelled word. It should go out when you hit eithor left or right shift keys, correct the mis-spelled word or just continue typing.
If it just stays on all the time no matter what you do, there is a problem with the main board.
Oct 06, 2008 | Smith Corona Wordsmith 100 Typewriter
Computers & Internet Logo
868 people viewed this question
David Payne
David Payne
