Question about Dimplex DS5598 Mid-Size Heater
No Heat or fan on model DS4411 Or 6901050100
Light works but no heat or blower.
  • Anonymous Jan 01, 2009
    I have the same problem - The heater and fan stopped working.
I had the same problem. One or more of the switches for the stove have melted and broken. You need to call Dimplex and request new switches. They should ship you out a 3 pack for free, and the pack will come with easy instructions for removing the bottom panel and replacing the switches.
Posted on Jan 25, 2009
Dimplexs' phone number is 888-346-7539
Posted on Mar 08, 2012
1977 Buick blower / fan comes on however NO heat blower / fan also blows very low.
Buick LeSabre Heater - RepairPal
repairpal.com > Problems > Buick > LeSabre
Buick LeSabre Heater blows only cool air...even w/ defroster on. This is a ... Heater fandoesn't come on . ... The blower works but there is no heat coming out.
Blower Motor Problems ' Auto Repair Help - YouTube
? 4:22
https://www.youtube.com/watch?v=2vmfxYg8LoY
Sep 27, 2009 - Uploaded by mgittelman
The blower motor is a common heater/AC repair within the skill level of ... However if the power wire is a single light purple wire and the ... for blower motor and fuel and relay good but no powercoming on both any ideas? ... my o5 seira, when i start the engine with the air switch on it blows my blower fan ...
Car Air Not Blowing, Heat & Air "How to" Test Testing ...
? 6:22
https://www.youtube.com/watch?v=hgar6Q1lV6A
Apr 5, 2013 - Uploaded by Fixbook
Here I show how to determine the problem if your air, or blowermotor is not ... Click here to check out the the "Car Runs on 2 cylinders" series: ... How to Fix Over-Heating engine & No Heat in car - Buick (2000 yr) Park Ave . ... Car fan / AC only works on high - Replacing the Blower Resistor - Duration: 4:24.
Buick Park Avenue Questions - NO HEAT!!! - CarGurus
Jan 30, 2016 | 1977 Buick Electra
Fan doesn't work in heat mode it works on all other functions. Heat does come out but fan doesn't kick in. Outside unit is operating
AC inside fan doesn't come on AUTO - DoItYourself.com Community Forums
www.doityourself.com > ... > Air Conditioning and Cooling Systems
Jul 21, 2004 - The inside FAN doesn't run when in AUTO mode. If I leave ... Is the thermostat not working correctly or something in the AC unit causing it to do this? Thanx ... The unit is electric central air-conditioning(heat and cool). It made ... Carrier A/C condenser fan not working
Jul 27, 2012
Heater Fan Doesn't Work on AUTO
Jan 23, 2006
Blower doesn't work in ON position after repair
Mar 25, 2005
Central AC/Heat, Blower Doesn't work on Auto
Nov 30, 2004
More results from www.doityourself.com
Nov 01, 2015 | Heating & Cooling
How do I wire a induce fan motor
Induced fan motors on older units are wired through the high limit safety on the stack - in series. When the furnace calls for heat, the induced fan motor comes on and after a time the furnace will light.
Older units have a temp switch in the stack that rotates to bring on the burners and blower motor. . When there is a call for heat, the induced draft fan motor comes on and then the burners will light.
After the heat exchanger is warmed up the limit switch will bring the blower motor on. That's basically how it works - there are two circuits - one for the induced draft motor and the burners and the other for the blower and high limit.
New units have a plug on the board you just plug in.
A
Oct 04, 2014 | Heating & Cooling
Amana heat pump emergency heat comes on but blower will not start. The call for heat comes in and the heating element(s) glow red for a few seconds and then there is a "click" and the heating...
Check the blower motor capicator. It should be mounted close to the motor with 2 wires to it (brown,brown/white).
Turn the blower on the thermostat and spin the squirrel cage by hand and see if it runs after by itself. If it does then definitely the capicator is bad .If it still doesn't run then check to see if there is voltage going to motor.
If thermostat is calling for fan and there is voltage present at the motor terminal then the motor is bad
Jun 01, 2017 | Heating & Cooling
I have an intertherm electric furnace FEH-A020, with multispeed blower installed when A/C added. My problem is blower operation. at the end of the cooling season with fan set to auto operation the fan ran...
The model of T-stat you gave comes up as a discontinued model on Honeywell's web site, but it looks to be a manual stat that type of stat would have to be wired with a summer winter switch with electric heat, allowing it to turn on the fan with a call for heat. If yours is a programmable T-stat you would need to select electric heat or in the installers set up change the default setting for fan from unit controls fan in heat to thermostat controls fan.
Oct 17, 2009 | Intertherm P3RA-048K Air Conditioner
Blower fan will not come on when set on Auto in heat mode.
the fan is controlled by a fan center or a stack switch. as burners light and heat up the spring sensor on the bulkhead above burners heats up and turns and a a point energizes the indoor fan if it gets to hot the burners go out on safty. sounds like a fan control is bad tap on them gently and they sometimes break loose but if not then have a pro replace fan control and test heat exchanger.
Oct 24, 2008 | Ruud UBHC Air Conditioner
Heat
No heat or no air volume? No heat may mean no coolant! check it now! Your 4.2 wont stand for being overheated. No volume, check the fuse, if ok then turn on you fan and check for voltage at the electrical connector at the blower motor (under the glovebox). If you dont have a test light, tap the blower motor . If that kicks it to life you need a blower motor.
Oct 05, 2008 | 1998 Ford F150 Regular Cab
Fan keep,s blowing
Your thermostat is calling for blower, your fan relay is stuck, or that model had a time delay blower solid state board on it which had the blower relay on it, and it could be bad. I would turn the power off to all of your system for a few minutes and see if this could make something happen.
Nov 20, 2007 | Heating & Cooling
Amana ac/heating unit model PGD60C1152E
I need more info. Is this a split system, packaged, or ptac. Heat pump or electric heat strip?
Nov 18, 2007 | Amana Haier AP125HD Air Conditioner
Dimplex DS5598 Mid-Size Heater Logo
1,143 people viewed this question
Top Dimplex Heating & Cooling Experts
Paul Carew
ashburton
David Burbee
David Burbee
Are you a Dimplex Heating and Cooling Expert? Answer questions, earn points and help others
