Question about Mitsubishi WD-52525 52" Rear Projection HDTV
Mitsubishi Model 52525 flashing red status light
My Mitsubishi 52525 has a flashing red status light. I have been working with Sears on a repair only to find that whatever they replace does not seem to fix the problem.
the flashing has a pattern: long-short-short-short in terms of light duration
  • 1 more comment
  • joepentlicki Dec 22, 2008
    Hmmm...STKs? Help me in understanding what STKs are. They have replaced a couple of the fans only.
  • marshall87 Dec 22, 2008
    IT ALSO FLASHES 3 SHORT AND 1 LONG.
  • marshall87 May 11, 2010
    THE LAMP WAS REPLACED ABOUT 4 MONTHS AGO AND I HAD THE BOARDS REPLACED ALSO.
  • Mitsubishi Master
  • 5,138 Answers
Have they replaced bothof the STKs in TV?
Posted on Dec 22, 2008
  • ladywinn
    ladywinn Dec 22, 2008
    Ok this set must be DLP Lamp ? If it has a lamp set does not have Tubes,Has the lamp been replaced? If so how long ago?I would try another Lamp.
Mitsubishi WD-62525 3 fast red lights then 1 long repeating
Not sure if they can be swapped out....you may want to get the schematics or service manuals and check
Apr 29, 2013 | Mitsubishi WD-62525 62" Rear Projection...
Flashing lamp light on mitsubishi 52525
The lamp cover is not installed properly or the lamp door switch isnt working thats what causes the 32 error.
Apr 08, 2013 | Mitsubishi WD-52525 52" Rear Projection...
WD-52525 will not turn on, Flashing Red light.
if that is a dlp tv . not shure just by model. but if it is then they do have a lot of problems with vented filtor capacitors on power supply and other boards. magor work unless you replace chassis. but the very first thing to try is lamp and make shure cooling fans and vents are clean. J.D.W.
Jun 25, 2010 | Mitsubishi WD-52525 52" Rear Projection...
Hello Need expert advice on the above problem - status light is constant red- we unplugged power and reset, tv green light comes on and then shuts off when red status light comes on. No picture at all. I...
The 18 code does not exist. To read the code press device/input button and menu button at the same time on the tv. count the LED flashes 1st digit short pause 2nd digit long pause, repeats.
The red status lamp indicates there is no communication between the format board and the DMD board (light engine). The most common problem for this is capacitors on the Format board that require hours of labor and possibly sending the entire electronics package to Mitsubishi if the caps don't do the trick. Expect a very large bill, contact you local Mitsubishi Authorized repair facility about this, DO NOT take a chance on your corner repair shop to know how to accomplish this.
Dec 19, 2008 | Mitsubishi WD-52525 52" Rear Projection...
Flashing status light
Wow I may have just fixed the flashy yellow status light problem. It's so siple yet so difficult. Looking at the front of your T.V. on the left hand side bottm there is a door for a filter. SMACK IT. if the door isn't shut all the way that status light will flash. Mine is turning on now, just have to work on the major problem now :) Hope you have the same simple problem.
Mitsubishi WD-62525 Red Status Light After Cap Replacement
which caps did you replace? As the normal repair for the first generation dlp is to replace the (4) 1000 uf caps. the (2) 2200 uf caps and the (2) 3300uf caps on the power pwb when you get the 34 error code.
Sep 09, 2008 | Mitsubishi WD-52525 52" Rear Projection...
WD-52525 Red lamp Indicator
usually with that model when you get a 34 eror code for lamp abnormality, its directly related to the capacitors on the Power Pwb. You can get the V26 Power PWB repair kit at the following link which repairs that issue. It contains the replacement High temp capacitors with the board location numbers and PWB identification as well as the service manual on CD. Heres the link its under their repair kit ctegory.
http://servicemanuals.vstore.ca/
Sep 04, 2008 | Mitsubishi WD-52525 52" Rear Projection...
Mitsubishi WD-52525 Status Light --- blinking red constantly.
possible that over night your set took a power surge ,possible power supply fault.
Sep 12, 2007 | Mitsubishi WD-52525 52" Rear Projection...
Mitsubishi WD-52525 52" Rear Projection HDTV Logo
457 people viewed this question
Top Mitsubishi Televison & Video Experts
matt martin
matt martin
Jaime Hernandez
Are you a Mitsubishi Televison and Video Expert? Answer questions, earn points and help others
