Question about Dell Latitude C400 Notebook
Dell c400 loading xp
You said to load XP but not the drivers, how do you do that since it seems to want to load them automatically? I tried loading the HDD into another laptop and loading xp but when I moved it back to the dell it kept getting stop error. Now I want to try what you are saying, please any help would be appreciated.
  • wdiddy Dec 22, 2008
    okay I don't have the OEM copy of XP, I bought my own. Here's what I think you are telling me to do.
    1. put hdd into a different laptop and load xp onto it with limited drivers
    2. modify registry with dell drivers
    3.download sysprep and do what you stated earlier
    4. put drive back in to dell
    Now please provide some clarification
    1.How do I control what drivers it installs when loading XP?
    2.Sounds like I install XP on the non-dell laptop in order to modify the registry, is this correct?
Did you sysprep the system?
You should only load the drivers that are needed to make the system run the basics. Don't worry about the network card unless you wish to install windows updates. I recommend just installing the OEM version of XP and modifying the registry to add drivers.
HKLM Software Microsoft Windows CurrentVersion "DevicePath"
Leave whatever is in there and add all the drivers to that folder. Make sure to include the motherboard drivers for the Dell laptop followed by all the other drivers. Some drivers will contain sub folders and you need to specify those as well spaced out by semi colons.
This should be all pasted in the devise path and it should look similar to this.
%SystemRoot%\inf;c:\dell_drivers\C400\Audio;c:\dell_drivers\C400\Video;c:\dell_drivers\C400\Video\XP_32; ect ect ect... if there sub folders in the drivers that are zipped, unzip them to the directories that you created on the root of C.
Once you have finished downloading all the drivers and modified the DevicePath registry key then download SysPrep from microsofts website and select Mini Setup and Shut down check boxes. Once the system shuts down then put the drive into the other laptop.
The system will be setup to install XP on the C400 with the drivers you included from the registry and the paths you pointed them to pole. On newer systems with Sata drives and other specific types of hardware like RAID you will need the hardware ID and adding that to the answer file for sysprep but that is way more complicated! For a DellC400 you will not need to do that.
Posted on Dec 22, 2008
  • VA_DC_MD Dec 24, 2008
    Yes you install XP on the non dell machine and modify the registry to add the drivers for the dell prior to syspreping it.
    However without the OEM cd you may need other files that are required from that disk that are not included from the one you have.
I have dell laptop latitude c400. Ican't reinstall the windows xp from external dvd writer. How can install the windows xp pls tell me?
This laptop will not give you an option to boot from a usb device or even from an external cd rom/dvd. You need to do a network install only for this particular model DEll c400. It is a long process and requires some skill of setting up a RIS server. You will also need a switch or hub to connect your laptop to it. Once your server is setup with dns, dhcp and ris you need to do a network boot and install the os. Get in touch with a professional to do it if your not familiar with this. I tried calling dell as i had a similar issue and they couldnt help me over the phone so they sent over a technician. Technician tried in vbain including removing my hdd and installing the os on his laptop and then putting the hard drive back into mine. It still didnt work. I then researched the net and figured out the only way to do it was via a remote installation.
Jun 13, 2010 | Dell Latitude C400 Notebook
I upgraded my laptop Dell C400 to windows XP but now can not change display resolution. Only option is 640x480. Went to http://support.dell.com/support/download. and got a bunch of drivers for C400;...
Please use following link for drivers :
http://support.dell.com/support/downloads/driverslist.aspx?c=us&cs=19&l=en&s=dhs&ServiceTag=&SystemID=LAT_PNT_P3_C400&os=WW1&osl=en&catid=&impid=
You just download it and install.
Regards
Ashly
Feb 02, 2010 | Dell Latitude C400 Notebook
I have a Dell Latitude C400 Laptop. it will not load Win XP
Try to make sure that all the cables are connected properly and that your hard drive has enough memory. Then make sure that your Windows XP DVD is not corrupted. Another thing you should try is loading a different OS like Vista or Windows 7.
Oct 03, 2009 | Dell AMD 386/33 Desktop Computer 333S/L...
Poor resolution and no sound for dell latitude c400. used xp.
http://www.user-guides.co.uk/cddownload/Dell/DellLatitude/Dell-Latitude-C400-XP-Driver-Recovery-CD-Restore-Disk-1420.html
at this location you will find and be able to download an cd in image format ..probably ISO ..you have to burn it on a cd ..and use it al the time you reinstall ..I understood that there are all the drivers you need for your model Good luck!
Apr 06, 2009 | Dell Latitude C400 P3 Notebook
After upgrading my c400 to XP, the screen resolution is not right
try logging into support.dell.com get a driver for windows 2000 for the video card you have. Sometimes that driver will work for the XP session OK (XP will gripe about loading it but continue anyway.)
Good Luck
Jan 08, 2009 | Dell Latitude C400 Notebook
Dell c400 upgraded to xp now it won't boot up
you have toboot xp in the dell they are not interchangable you have load xp withit inthe dell or the dell wont work
sorry to be the bearer of bad news
Dec 21, 2008 | Dell AMD 386/33 Desktop Computer 333S/L...
WALTER I NEEED YOUR HELP!
You can watch a bios screen load up maybe even tinker around with it, even boot something off a cd, but you still need an operating system( Like windows) To really use your computer
Oct 24, 2008 | Dell Latitude C400 Notebook
Dell latitude c400 sound probel
First check the sound settings, it could just need adjusting. If the settings are correct, then you have a driver glitch, uninstall the sound drivers from the device manager, then reboot. The machine will find the sound card and reinstall the drivers automatically. Then check Dell's support site for updated sound drivers.
Aug 13, 2008 | Dell Latitude C400 Notebook
Dell C400 Resolution Problem
Boot into BIOS and go to the Video card setting, that sould fix it
Jan 26, 2008 | Dell Latitude C400 Notebook
DELL Latitude C400
Go to the Dell website and download the XP video and display drivers:- http://support.dell.com/support/downloads/devices.aspx?c=us&l=en&s=gen&SystemID=LAT_PNT_P3_C400&os=WW1&osl=EN
Feb 22, 2007 | Dell Latitude C400 Notebook
Dell Latitude C400 Notebook Logo
197 people viewed this question
Alun Cox
